How to use country names with spaces in reflector-auto?
How can one use country names with spaces in reflector-auto?
Using an /etc/reflector-auto.conf file containing:
-c 'United States' -c Canada -c Poland -f 15 -p https -a 2
will not work and returns this error:
Reflector.py: error: unrecognized arguments: States'
But using US instead of 'United States' will work correctly.
-c US -c Canada -c Poland -f 15 -p https -a 2
Note that using 'United States' in the normal reflector command like the following does work.
sudo reflector --country 'United States' --country Canada --country Poland --age 2 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
Thanks for the report, I’ll check this as soon as possible.
That is indeed an issue for reflector-auto.
Until it is fixed, an alternative way (workaround) is to use country codes like US.
To see the supported country codes, look at the output of command:
    reflector --list-countries
Fixed in reflector-auto version 1.1.1-1.
Just tested reflector-auto version 1.1.1-1 and it works as it should. Thanks @manuel.
