On my computer EOS (Gnome) runs in German (de). Is it possible to switch quickly between German and English (en)? For example to generate generally understandable outputs here in the forum? Thanks a lot!
parameter then country and language
man date # deutsch
LANG=C man date # english
What about …
$ locale
LANG=en
The question was
quickly.
and not locale
locale
LANG=de_DE.utf8
LC_CTYPE="de_DE.utf8"
LC_NUMERIC="de_DE.utf8"
LC_TIME="de_DE.utf8"
LC_COLLATE="de_DE.utf8"
LC_MONETARY="de_DE.utf8"
LC_MESSAGES="de_DE.utf8"
LC_PAPER="de_DE.utf8"
LC_NAME="de_DE.utf8"
LC_ADDRESS="de_DE.utf8"
LC_TELEPHONE="de_DE.utf8"
LC_MEASUREMENT="de_DE.utf8"
LC_IDENTIFICATION="de_DE.utf8"
LC_ALL=
Wenn es permanent geändert werden soll dann mal
lesen.
Thanks for your advice. But no, I don’t really want to change it permanently. Thanks for your advice. But no, I don’t really want to change it permanently. I am an absolute Linux beginner and therefore I want to know what I am doing to learn something from it.
If some output in terminal is german then put
LANG=C
in front and the output change, quickly , to english.
Sample
man date # deutsch
DATE(1) Dienstprogramme fĂĽr Benutzer DATE(1)
BEZEICHNUNG
date - Ausgeben oder Setzen von Systemdatum und -zeit
ĂśBERSICHT
date [OPTION]… [+FORMAT]
date [-u|--utc|--universal] [MMDDhhmm[[CC]YY][.ss]]
BESCHREIBUNG
Die aktuelle Uhrzeit im angegebenen FORMAT anzeigen oder die Systemzeit setzen.
Die obligatorischen Argumente fĂĽr Optionen sind fĂĽr deren Kurz- und Langform gleich.
-d, --date=ZEICHENKETTE
Die in ZEICHENKETTE beschriebene Zeit anzeigen, nicht »jetzt«
DATE(1) User Commands DATE(1)
NAME
date - print or set the system date and time
SYNOPSIS
date [OPTION]... [+FORMAT]
DESCRIPTION
Display the current time in the given FORMAT, or set the system date.
Mandatory arguments to long options are mandatory for short options too.
-d, --date=STRING
display time described by STRING, not 'now'
Great! I haven’t tried it yet, but that’s exactly what I was looking for.
I know
Now you can mark post #3 or #8 as solution
Summary (@SGS has helped me a lot):
I have to log into the terminal as superuser (su) first and then enter the password hidden (as usual under Linux). Then I enter LANG=C (“C” probably stands for “Common”). Then I start my job in the terminal, for example “pacman -Syu”.
All pacman traffic is then handled in English. I can communicate this very well for our mostly english speaking users. At the end you must not forget to log off as superuser with the command “exit”.
Afterwards @SGS suggested a simplification to me which works well: It also works everything in one line:
LANG=C sudo pacman -Syu
Then the respective command, in this case pacman, starts immediately with the instruction to attach appropriate notes in English. You can communicate these hints here, where most people are English speaking or understand English.
This might also be interesting for other people who write in German, Dutch, Spanish, Russian or other languages.
Not afterwards , in short words, I give the answer in post # 3, but it was to short for new
terminal users.
One small thing to help you with that a bit more.
You might want to write that command as a bash alias:
alias update='LANG=C sudo pacman -Syu'
and copy the above line into the end of file ~/.bashrc.
Then start a new terminal (and close possible “old” terminal windows).
Then, to update your system in English, just command:
update
