I installed EndeavourOS, and the initial setup of home, such as wallpaper, transparency for Xfce-terminal, etc. are just beautiful.
My real home folder is on a second drive, so I switched it over it /etc/fstab, rebooted, and it works, but it’s back to plain black background, and the other tweaks from the Endeavour team are gone.
I tried selectively copying flies from the Endeavour-created home into my home, rebooted, to no avail. It’s still plain, no background. Changing the background from the EOS welcome screen doesn’t work.
Is there a way to set my home back to its former EOS beauty?
Thanks!
Edit: forgot this:
OS: EndeavourOS Linux x86_64
Kernel: 6.1.27-1-lts
Uptime: 18 mins
Packages: 1050 (pacman)
Shell: bash 5.1.16
Resolution: 2560x2880, 3840x2160, 3840x2160
DE: GNOME 44.1
WM: Mutter
WM Theme: Adwaita
Theme: Adwaita [GTK2/3]
Icons: Qogir [GTK2/3]
Terminal: xfce4-terminal
Terminal Font: Source Code Pro 14
CPU: 13th Gen Intel i9-13900K (32) @ 5.500GHz
GPU: NVIDIA RTX A4500
Memory: 2274MiB / 128520MiB
Yes, I’m using Gnome. Installed Gnome, Xfce, and i3 to try them out. I discovered that I like the aesthetics of Xfce-terminal (which runs fine in Gnome). My mention of it above was a distraction though.
