Hi,
I installed i3 on my plasma instalation to try it out and I can’t find out how to remove the little orange battery applet on the panel. It’s a desktop pc not a laptop
Hi,
CONFIG FILE = ~/.config/i3/i3blocks.conf
Just comment (#) the section for battery, log out and back in again, to see if it works.
The EnOS i3blocks.conf
file contains some comments, worth reading…
Thank you, I searched in .config/i3/config without luck
You’re welcome.
b t w … …
this is shown on fresh installs inside firefox twhat is autostarting for that reason… (to show how to change settings)
