6502
December 25, 2022, 7:00pm
1
I have a fresh installed ENDEAVOUROS MATE.
I did search in internet how to install Viber on ENDEAVOUROS and found that I have to use:
yay -S viber
I just have Viber installed, because I see it appears into Menu:
Applications
- Internet
-- Viber
The problem is when I click on Icon Viber into above menu it does not run.
How to make Viber works on ENDEAVOUROS MATE ?
Try to launch viber from the terminal and see if there are any error messages.
6502
December 25, 2022, 7:20pm
3
Excuse me, I never ran a program by Terminal, so I did something I think I have to do:
$ viber
qt.webenginecontext:
GLImplementation: desktop
Surface Type: OpenGL
Surface Profile: CompatibilityProfile
Surface Version: 4.3
Using Default SG Backend: yes
Using Software Dynamic GL: no
Using Angle: no
Init Parameters:
* allow-loopback-in-peer-connection
* application-name ViberPC
* autoplay-policy no-user-gesture-required
* browser-subprocess-path /opt/viber/libexec/QtWebEngineProcess
* create-default-gl-context
* disable-features DnsOverHttpsUpgrade,ConsolidatedMovementXY,InstalledApp,BackgroundFetch,WebOTP,WebPayments,WebUSB,PictureInPicture,AudioServiceOutOfProcess
* disable-setuid-sandbox
* disable-speech-api
* enable-features NetworkServiceInProcess,TracingServiceInProcess,NetworkServiceInProcess
* enable-threaded-compositing
* enable-usermedia-screen-capture
* in-process-gpu
* use-gl desktop
xkbcommon: ERROR: Couldn't process include statement for 'gb(bas_phonetic)'
xkbcommon: ERROR: Abandoning symbols file "(unnamed)"
xkbcommon: ERROR: Failed to compile xkb_symbols
xkbcommon: ERROR: Failed to compile keymap
[16337:16366:1225/211704.408806:FATAL:xkb_keyboard_layout_engine.cc(640)] Keymap file failed to load: gb-bas_phonetic
Trace/breakpoint trap (core dumped)
It is likely that your keyboard layout is causing viber to crash. What keyboard layout are you using? Can you change the layout to us layout and try to launch viber again?
6502
December 25, 2022, 7:31pm
5
I am using :
English (UK)
I will add :
English (US) and will try again using it.
Remove English (UK) and then use English (US). Hopefully this will resolve the issue.
December 25, 2022, 7:33pm
7
OK,
I will remove English (UK)
6502
December 25, 2022, 7:43pm
8
Thanks very much,
now I have an working Viber on ENDEAVOUROS MATE
No problem. Though using a different keyboard layout shouldn’t cause an application to crash. This could be due to a bug in Viber. I suggest you bring this issue to the attention to Viber’s developers to further diagnose the issue.
system
Closed
December 27, 2022, 7:53pm
10
