i really appreciate your community. so much so that i want to take my current install and join it to EndeavourOS. what’s the best way to do that without reinstalling?
this install was Antergos once upon a time, but when Antergos closed down, i followed their guide to make it a straight Arch distro. i’d like to now take this “arch” distro and make it EndeavourOS. i think you use the same basic repos though, yes? as main Arch?
any thoughts are appreciated. i just much prefer your community.
That is quite impressive! I take it that you don’t like installing frequently a distro from scratch. Although eos is quite easy to install, might be worth the refresher.
thanks, zircon! well, as dalto says, the system is nice and stable already, and very flexible within the arch sphere. i won’t reinstall unless i really, really have to. XD
@dalto thank you! everything went smoothly! so i guess i’m in the EndeavourOS family now!
i’ve had my wife on it for some time, and i’m happy to finally officially join in myself!
I’ve moved my topic-derailing intervention in its own new topic. so we can keep this one focused on the OP’s theme.
3 posts were split to a new topic: XFCE libappindicator bugs and other XFCE misshaps
