Right now, I’m on my fresh EOS installed and configured. To take care of it, I’ll start by doing 2 things:
First:
Second: yay once a day!
First:
Just don’t sudo yay
, or you’ll be this meme:
Also, with sudo
, it’s very easy to break @fbodymechanic’s rule no. 1. Use it cautiously and never when you can do the same thing without it.
I love that meme!
And yes, that’s one of the first things I’ve learned while testing EOS on Virtualbox, maybe I’ve should explained those 2 steps:
sudo
only when it’s needed; I know I can search a package in pacman without sudo
, it’s as easy as pacman -Ss <package_name>
