How to get NFS client to work
I am using the latest version of EndeavourOS and I try to connect to my FreeNAS / TrueNAS using NFS. I am a Debian / RedHat user trying out somethings else :slight_smile:
showmount -e 192.168.192.2
Export list for 192.168.192.2:
/mnt/pool2/dataset2/myname-storage2 (everyone)
/mnt/pool1/dataset1/myname-storage1 (everyone)
sudo mount -t nfs -o vers=4 192.168.192.2:/mnt/pool1/dataset1/myname-storage1 /home/myname
/storage1
[sudo] wachtwoord voor myname:
mount.nfs: Protocol not supported
I installed NFSutils but no luck.
Any idea?
Welcome to the forum! :smile:
What happens if you drop the version option? It should automatically negotiate the proper version.
See: man nfs
sudo mount -t nfs -o nfsvers=3 192.168.192.2:/mnt/pool1/dataset1/myname-storage1 /home/myname/storage1
Created symlink /run/systemd/system/remote-fs.target.wants/rpc-statd.service → /usr/lib/systemd/system/rpc-statd.service.
Yes that does it. THX
Curious, works for me without that linkage
[xxxxx@ryzen7 ~]$ sudo mount -t nfs raspberrypi2:/export/users /mnt
[sudo] password for xxxx:
[xxxxxx@ryzen7 ~]$ df -h
Filesystem                  Size  Used Avail Use% Mounted on
dev                         7.8G     0  7.8G   0% /dev
run                         7.9G  1.7M  7.9G   1% /run
/dev/nvme0n1p3               99G   65G   29G  70% /
tmpfs                       7.9G  166M  7.7G   3% /dev/shm
tmpfs                       7.9G   27M  7.8G   1% /tmp
/dev/nvme0n1p1              511M  8.1M  503M   2% /boot/efi
/dev/nvme0n1p2              500G  269G  229G  55% /exthome
/dev/sda1                   932G  819G  110G  89% /media/Music
tmpfs                       1.6G   60K  1.6G   1% /run/user/1000
raspberrypi2:/export/users  6.9G  3.5G  3.1G  54% /mnt
[xxxxx@ryzen7 ~]$ ls /run/systemd/system/remote-fs.target.wants
ls: cannot access '/run/systemd/system/remote-fs.target.wants': No such file or directory
BTW, I use autofs to avoid the sudo shenanigans
[xxxxx@ryzen7 ~]$ cd /net/raspberrypi2
[xxxxx@ryzen7 raspberrypi2]$ cd export/
media/ music/ users/
[xxxxx@ryzen7 raspberrypi2]$ cd export/media
[xxxxx@ryzen7 media]$ df -h
tmpfs                       7.9G  165M  7.7G   3% /dev/shm
tmpfs                       1.6G   64K  1.6G   1% /run/user/1000
raspberrypi2:/export        6.9G  3.5G  3.1G  54% /net/raspberrypi2/export
raspberrypi2:/export/media  6.9G  3.5G  3.1G  54% /net/raspberrypi2/export/media
For this to work seamlessly in terms of permissions, I ensure that user ids on all my machines are the same.
Maybe this version option (like below in blockquote) can be left out and than it will automatically find the right version?
vers=4
