Well these usb sticks are sometimes strange things , I have one that I can not boot from unless I put it on a extension cord, really weird.
i was getting a cheap usb stick in a supermarket a sof needed one fast.. was sold as 64GB and i wa swondering why it always failed to write data .. checked it and it was fake capacity.. had only 16GB in real..
The problem is, when you copy over huge files you get a message it’s done. When you click on unmount it says it copies files. So i unplugged it anyway because i thought that was a error.
Turns out the drive locked it self out. Now i just wait when i get approval
and sometimes it takes minutes after you hit the unmount icon.
That is why I made this function. It doesn’t release until everything is done (including the writing on to USB)
Thanks, will look into this later ![]()
Thanks for all your help. Unfortunately nothing helped.
Now searching for a Hammer ![]()
That happens a lot.. always check it with F3 as @joekamprad already suggested.
As long as I’ve been using usb drives I’ve never had one fail. ![]()
pure luck ![]()
I think so. ![]()
i do not remember that i got many USB drives fail here too but i tent to buy known good brands too.
But sdcards omg they die like one day flies here..
You can’t even use gparted and create a new partition and then format it?
No. It always says read-only.
Same story like i had. Nothing works. I tried terminal/gparted and so on. I even found commands to force read/write but even that got rejected.
I am afraid your usb is dead.
I think so too. Anyway, lesson learned
Never put an ISO 9660 image direct via dd on a stick.
Conclusion
If
ddcannot write to an unmounted/dev/sdX,
then no software method exists to make the drive writable again.
The stick has locked itself permanently.
If you want a final verdict, provide:
dmesg | tail -n 50
lsblk -o NAME,RO,MODEL,VENDOR
That’s enough to say with certainty whether there is any hope left.
USB Drive Became Read-Only After Writing Wrong ISO – Can It Be Rescued?
Short answer:
Yes, this can happen — and very often the drive is permanently locked.
There is no software “+w flag” you can force if the kernel reports the device as read-only at the block-device level.
Why This Happens (and Why dd Is Not the Culprit)
If even dd fails on an unmounted device, this is not a filesystem or mount issue.
It means the USB controller itself has switched to read-only mode.
Hardware-Level Write Protection (Very Common)
Many USB flash drives implement a fail-safe mechanism in their controller firmware:
- Too many write errors
- Bad or worn-out flash cells
- Corrupted internal mapping tables
When this happens, the controller deliberately switches to permanent read-only mode to allow data recovery.
This happens below the filesystem level.
Symptoms:
mkfs→
fdisk/parted→
mount -o rw→
dd→
At this point, the OS cannot override it.
Kernel Sees the Device as Read-Only
Check what the kernel thinks:
lsblk -o NAME,RO,SIZE,MODEL
If you see:
sda 1 32G Generic USB Flash
RO=1 means:
👉 the device itself reports write protection.
Things You Can Still Try (In Realistic Order)
🔧 1. Try Clearing the RO Flag (Rarely Works)
sudo blockdev --getro /dev/sda
sudo blockdev --setrw /dev/sda
If it stays 1 → hardware lock.
🔧 2. Remove and Re-enumerate the Device
echo 1 | sudo tee /sys/block/sda/device/delete
Unplug the stick, plug it back in, then:
dmesg | tail -n 30
If you see messages like:
Write Protect is on
or usb-storage: device is read-only
→ that’s definitive.
🔧 3. Raw Write Test (Unforgiving but Final)
sudo dd if=/dev/zero of=/dev/sda bs=1M status=progress
If this fails with:
Read-only file system
→ the controller enforces read-only mode.
🔧 4. USB-Level Reset (Long Shot)
sudo usbreset <bus-device>
Only helps if the controller is temporarily locked (rare).
❌ What Does Not Work (Common Myths)
❌ mount -o remount,rw
❌ fsck
❌ mkfs
❌ repartitioning
❌ different filesystems
❌ different OS (Windows/Linux doesn’t matter)
Once the block device is RO, everything above it is irrelevant.
When the Drive Is Effectively Dead
The drive is beyond recovery if:
lsblk shows RO=1
dd fails on the raw device
dmesg reports write protection
Same behavior on multiple systems
👉 At this point, the drive is intentionally retired by its own firmware.
This is not a bug — it is a data-preservation feature.
thanks for the detailed explanation. Bookmarked for future use ![]()
You’re welcome. I’ve lost count of how many USB sticks I’ve attempted to recover over the years, often for other people.
These days I stick to USB-connected SSDs for backups and portable storage — slightly more expensive, but significantly more reliable.
This might sound like an open door but:
never use a thumb drive as backup storage ever!
