You can always just grub chainload OpenSuse from EndeavourOS.
Modify /etc/grub.d/40_custom and add custom entry for OpenSuse.
menuentry "OpenSuse" {
set root="hdX,gptY"
chainloader /EFI/OpenSuse/grubx64.efi
Root is the OpenSuse efi partition.
hdX is the disk number (zero based), /dev/sda would be hd0 … and so on.
gptY is the partition ID, /dev/sda1 would be gpt1 … and so on.
Use chainloader with path to OpenSuse grubx64.efi within efi partition. Check the actual path, above is just an example.
This will create a separate grub entry which will launch OpenSuse grub.
Much simpler, especially for encrypted systems or setups where os-prober is inconsistent or just useless.
isak
September 21, 2020, 12:28pm
22
manuel:
Strange that it doesn’t generate anything about openSUSE even though os-prober shows it exists. Is the os-prober showing the correct UUID for it? Try command lsblk -fm.
Here’s a workaround idea (that may or may not help):
You can copy a menuentry from openSUSE’s grub.cfg into EndeavourOS file /boot/grub/custom.cfg . It will show itself as a new menu entry at boot time.
If you do that, could you show the contents here?
I tried adding t he menuentry from openSUSE’s grub.cfg but that didn’t work. openSUSE shows up alright but can not boot it, it cannot find the kernel or initrd files.
manuel
September 21, 2020, 12:32pm
23
Is your EndeavourOS or openSUSE encrypted?
You could also use the chainloading idea presented by @otherbarry above, but instead I’d add that to file /boot/grub/custom.cfg.
Why?
40_custom is what entries like this are for, they will be included whenever grub-mkconfig is run to generate grub.cfg.
isak
September 21, 2020, 12:54pm
25
manuel:
Not encrypted either. Will try the chainloader option when I get home. But since my efi partition is on /dev/sdc1 I guess I have to point it there?
isak
September 21, 2020, 1:45pm
26
otherbarry:
set root="hdX,gptY"
I created the menuentry in /etc/grub.d/40_custom.
menuentry "openSUSE" {
set root="hd2,gpt1"
chainloader /boot/efi/EFI/opensuse/grubx64.efi
But when trying to boot it grub claims that it can not find the path. This is the correct path:
isak@motherbrain /e/grub.d> sudo ls -al /boot/efi/EFI/opensuse/grubx64.efi
-rwx------ 1 root root 315392 14 sep 18.48 /boot/efi/EFI/opensuse/grubx64.efi
But looking in efibootmgr -v the path is /EFI/opensuse/grubx64.efi I find this odd. My EFI partitions is mounted at /boot/efi.
What am I doing wrong here?
chainloader /EFI/opensuse/grubx64.efi
/boot/efi/ is a mount point, /EFI/opensuse/grubx64.efi is the path within the efi partition.
manuel
September 21, 2020, 2:57pm
28
It is otherwise a good place, but whenever package grub is updated, that file will be overwritten gets a new version. It won’t be overwritten directly, but may require manual intervention.
/boot/grub/custom.cfg is free from that.
It won’t create a .pacnew file?
manuel
September 21, 2020, 3:21pm
31
Menuentry already “knows” your EFI partition, and the chainloader is given a path inside the EFI partition.
(But @otherbarry already said the same thing…)
isak
September 21, 2020, 7:36pm
32
Thanks all who have been helping me figuring this out! Much appreciated! The chainloader solution worked!
zoli62
September 22, 2020, 3:30pm
33
The main thing is that the problem is solved.
I just wish that they would standardize the implementation of Grub settings and ucode and dual boot so it all works the same on ALL Linux distributions.
isak
September 22, 2020, 6:16pm
35
Is there any downside to clean up my EFI partition?
# efibootmgr
BootCurrent: 0005
Timeout: 0 seconds
BootOrder: 0005,0003,0004,0000,0002,0001
Boot0000* EndeavourOS
Boot0001* Hard Drive
Boot0002* UEFI OS
Boot0003* opensuse
Boot0004* grub
Boot0005* EndevourOS-grub
This is what I got. What are your thoughts?
I keep mine clean with only what i need.
#efibootmgr
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0000,0005
Boot0000* Windows Boot Manager
Boot0001* EndeavourOS
Boot0005* UEFI OS
Mine boots from Grub on EndeavourOS
