How to create shortcut to stop and minimize media player
Also not recommended. These specific buttons like the HOME, END, ESC buttons have their own functions. It is best to define custom shortcuts with modifier keys like the Windows key, so Win + something
oh ok
Good. Then the shell script should work without you having to re-login.
Open the vlc window, and make sure vlc is the active window. Press the keyboard shortcut you just assigned, and the script pause-and-minimize-vlc.sh will run and minimize the window + pause the vid.
For example, the HOME key will usually return the cursor to the beginning of a line when you’re typing something, right? If you bind it to something else, next time you press HOME key, it will run the script instead of returning the cursor to the start of a line.
So did you manage to get it to work?
Yes it worked perfectly
i binded Win+i key and it is working fine
