How to check for bad priv setting
find . -perm /4000 2>/dev/null
this finds system files and bins which can used non root to gain root
here is a list of bin and how users can use them to gain root and attack a machine using bad configs on perms https://gtfobins.org/
a good example is if sudo is chmod 777 you can run sudo sudo without password
