How is kernel 6.4.4?
Wanted to update because it may have a fix for amd gpu, but found this on the arch forums some IO-wait issue https://bbs.archlinux.org/viewtopic.php?id=287343
Do you guys have this with ext4?
No, all is fine.
NP
6.4.4 had a rather big change log, so issues are not unlikely. However, I run it for about 6 hours now and no issue so far (ext 4 KDE system)
No issues. ext4 , Plasma
I don’t know why you need a fix for amdgpu? I have lots of amgpu hardware and have zero issues.
Edit: Using Kde and Wayland also.
Ext 4, gnome, zen 6.4.4. No issues with IO-wait.
Kernel: 6.4.4-zen1-1-zen
23.05.43     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
23.05.43     all    1,64    0,05    0,83    0,07    0,13    0,02    0,00    0,00    0,00   97,26
23.05.44     all    1,64    0,05    0,83    0,07    0,13    0,02    0,00    0,00    0,00   97,26
23.05.45     all    1,63    0,05    0,83    0,07    0,13    0,02    0,00    0,00    0,00   97,26
idk there been a lot of issues since 6.3.9 Black Screen on Boot Up that Never reaches Login screen - #60 by s88
this is the patch https://gitlab.freedesktop.org/agd5f/linux/-/commit/b391007884c2a4ffd7e7e1cd45de98a7e4136739 I just updated, restarted a few times looks like it’s finally fixed, it’s been going on for a month now.
Also it boots a few seconds faster, it hanged a bit when it loaded gdm then gnome, now it’s smooth.
Was it happening with onboard amd graphics? Hybrid setup? I have an AMD RX 590 Gpu and have not ever had any issues with amdgpu.
I only have a 5700g. They changed a lot of things the last few months, the latest gen ryzen chips were overheating or something.
No worries here…
Yes this is onboard graphics. Like i say i have desktop with Ryzen 3800X and AMD RX 590 Gpu with no issues with amdgpu.
that was a BIOS problem, that only affected systems with RAM overclocking enabled (EXPO is already overclocking)
No kernel changes were made due to that problem.
