How does hibernate works on EndeavourOS Laptop
Im about to sleep (irl) and want to figure out how to save as much battery as possible. Saw some posts about hibernate and other stuff, still cant get my head around that. Does it hibernate automatically or i need to do it manually?
Did you set it up when you installed? If so, click on hibernate (assuming your DE has that, but without significantly more information of your computer and setup, I can only assume you have that, provided you did set it up upon install.)
im using Hyprland, so i dont have that.
If you are using Hyprland you will have to set up hibernation manually.
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Hibernation
