But…why?
Extra file in ~/.config
won’t have any material impact on the performance of your system…
But…why?
@dalto
I like it to have a clean folder structure an only the necessary needed files. It’s more about me. Too much disturbance give me an “out of control” feeling.
Your system, your rule!
– @Shjim
Having followed through this thread, your best bet seems still to be to delete them manually on a as per case basis.
If you want to delete, make sure to backup before deleting
Are there really 1913 files in the Vivaldi config folder??
The browser cache is probably being kept there.
Mine’s sitting at ~600mb, ~23k files, and that’s with the cache under ~/.cache/vivaldi
and linked to tmpfs. That being said, Vivaldi does have cache under ~/.config
. This directory contains about half of the storage: ~/.config/vivaldi/Default/Service Worker/CacheStorage
du -s .config
7.6G .config
I guess this means I have to open it and check the culprits
Thanks for you contribution. So I will clean it by hand.
In the same time it will be a learn process, witch files are used for what. Sadly in the .config folder there are “cryptic” file where I not really now from witch application they are.
but ecosia, is my friend.
My ~/.config
size is 569 MiB. If I exclude Discord and Chromium it’s only 7 MiB…
This is a problem I hated on Windows, and it’s still a (albeit less) problem on Linux:
Various programs install config files and data into non-standard places and it infuriates me. Videogames especially have a bad habit of adding new unwanted directories into your home directory.
Currently I don’t really “use” my /home, after I got all my data organized into new ZFS filesystems. So the datasets from those filesystems are currently mounted in /mnt, and if anything is actually important to me, it goes there and not into /home. This will probably change as it’s not the most ergonomic; I might add symlinks in my /home to what I think of as my “real” directories, but I am paranoid of some random program coming along and putting files into one of those directories without me approving. It feels safer to keep them in /mnt.
Some of the top-level directories I have in /mnt right now:
data-exports
documents
downloads
ebench
games
library
media
music-prod
project
sysadmin
work
Nothing here gets muffed up, and nothing gets added that I don’t want.
For ~/.config
I use a tool called Chezmoi to manage them. If you have config files you want to back up, and be able to sync to other machines, I would run chezmoi add ~/.config/spectacle/conf
, which copies it to a Chezmoi directory. You turn this directory into a git repository, then you can run chezmoi apply
and it will update all your config files from the Chezmoi directory (and prevent accidentally overwriting changes). You can also set it to just symlink conf files. When you want to set up a new computer with all your config files, you can do it all in just 1-2 commands; it will pull your git repo and apply all the files.
This isn’t great for any config files that change very often, if keeping them in sync with other computers is important. More complex programs like FreeCAD, Cura, etc. have conf files that change a little bit almost every time you do work in them. Depends on how important it is to not lose changes, and you can do your best to pick and choose to sync only the most important conf files.
About twice a year I check ~/.config, ~/.cache and ~/.local/share, I have an alias for a command that list the 15 biggest directories by size.
alias bigdir="du -hsx */ | sort -rh | head -15"
For example :
cd .config && bigdir
45M mpv/
7,7M jamesdsp/
4,5M transmission-daemon/
4,1M libreoffice/
3,9M deadbeef/
3,8M GIMP/
2,0M Transmission Remote GUI/
1,8M startpage_dracula/
1,5M ulauncher/
840K mednaffe/
700K gtk-2.0/
508K ghb/
352K radiotray-ng/
312K xfce4/
148K VirtualBox/
In ~/.local/share/applications, you may find some .desktop files that need to be removed manually.
Not a solution, but I turn blind eye on this and set shell default folder to /home/user/home
Programs to /home/user/home/bin my configs to /home/user/home/etc
Current state of user home directory is like managing a zoo…
Anything that lives in .config
is whatever; as long as it’s not cluttering my top level HOME directory. It does irritate me when programs store data and not just configuration in there, but I’ve learned to accept that this those standards will not be properly followed by programs in the foreseeable future.
xdg-ninja is an excellent tool that looks for programs storing data in places not following XDG specification, and will try to tell you the corresponding env var or config setting to make the program store to the proper location if possible.
I also use chezmoi to manage my dotfiles (mostly in ~/.config) and sync them across machines. It uses a git repository to store your files, and you can pick and choose which files you want to track and save (eg. chezmoi add ~/.config/spectacle/spectaclerc
I use a dyson and a swiffer mop. Works great
Edit: Seriously, though, I just back up important files to my NAS regularly and couldn’t care less about keeping my /home squeaky clean because at some point I will likely do a clean install anyway to keep things FRESH. Just a habit I have from using Windows for so many years.
like a few here the 20 mb of /.config
and 20 mb of /.mozilla
negligible for now imo.
the occasional ocd part of my brain will crack open .config
a couple times a year and take a gander with your eyeballs at all the folders of apps you played with for a day/stopped using/or uninstalled. they go to the trash immediately and I hunt down the remains (search) of them wherever else they had their tentacles and delete those files too.
to answer your title question: manually with a big stick
2 cents
20 MB for .mozilla
You must not even have bookmarks in that thing. No cookies, no add-ons, no nothing.
I’m at 10 times that amount at minimum - specifically when I only have one profile. But because I have multiple profiles, it’s at 1.1 GB.
