I have fixed a couple of config errors in the qtile
config that ships with EndeavourOS. How do I submit the bugfix?
Create a PR or open an issue:
I have never done a PR before so I will open an issue.
I was searching GitHub with a lot of these keyword and it never showed. Sometimes GitHub is weird when searching for stuff.
you should do that … its easy and you will get the fame
On GitHub you can do that by clicking the edit option on the file, what will fork the repo and after you added/changed what you want to changes you click on adding a message about changes (comment) and finally create Pull Request…
I have already opened an issue regarding this. I don’t want fame. I am quite accustomed to not being recognized for my labors. Just want to fix the issue as it affecting all qtile users.
PR #19 & #20 submitted.
