I copied the .fonts from home /.fonts directory to the documents directory.
Now I want to delete the entire .fonts directory to the trash.
Runs sudo nautilus unfortunately I can’t see the .fonts directory in home /documents to delete it. picture # 1
i don’t use nautilus, but i did some research and it was recommended on a few pages. i use pcmanfm-qt and there it is also ctrl+h. then you can look in the settings of your file manager and make hidden files visible.
