I bought a new laptop with a key that does some special weird thing in windows. It’s between right alt and the arrow keys, so I’d like to map it to right control.
I analyzed it in keyd and wev, and the key identifies as RSuper + RShift + F23. How can I make this emit RControl?
@j4s0n ,
Google suggests the following: yay -S keyd sudo systemctl enable keyd --now
Put the following in /etc/keyd/default.conf:
A post festam Edit (tested variant/version):
I figured out the issue. ChatGPT told me that I could omit the [ids] block if I wanted it to apply to all keyboards. That is not correct. To apply to everything, the block needs to be there with a *.
When asked who was the leader of Denmark, an AI bot told me that Queen Margrethe had died and that her son Frederik became King as a result. In fact, she’s doing just fine, thank you very much.
