I have already created a 16gb swap partition and I want to actually enable it.
Also please note that I need it for hibernation as well.
Please post the output of
lsblk -fs
and
cat /etc/fstab
`lsblk -fs`:
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /var/lib/snapd/snap/snapd/14295
loop1
squash 4.0 0 100% /var/lib/snapd/snap/bare/5
loop2
squash 4.0 0 100% /var/lib/snapd/snap/snapd/14549
loop3
squash 4.0 0 100% /var/lib/snapd/snap/core18/2284
loop4
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
loop5
squash 4.0 0 100% /var/lib/snapd/snap/spotify/57
loop6
squash 4.0 0 100% /var/lib/snapd/snap/spotify/56
loop7
squash 4.0 0 100% /var/lib/snapd/snap/vlc/2344
loop8
squash 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1519
loop9
squash 4.0 0 100% /var/lib/snapd/snap/teams/6
sda1 vfat FAT32 NO_LABEL
│ 4A81-3497 510.7M 0% /boot/efi
└─sda
sda2 ext4 1.0 7d39844e-d23b-432f-b32c-2be1eca5b9d3 393.8G 6% /
└─sda
sda3 swap 1 4edff8a1-0bc8-4974-80b6-3d990cdba082 [SWAP]
└─sda
nvme0n1p1
│ ntfs Recovery
│ 56F0D3BBF0D39F93
└─nvme0n1
nvme0n1p2
│ vfat FAT32 BAD4-7990
└─nvme0n1
nvme0n1p3
└─nvme0n1
nvme0n1p4
│ ntfs Sun Valley
│ E8BCD85DBCD82838
└─nvme0n1
nvme0n1p5
│ ntfs 22CAF23FCAF20EB3
└─nvme0n1
`cat /etc/fstab`:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=4A81-3497 /boot/efi vfat umask=0077 0 2
UUID=7d39844e-d23b-432f-b32c-2be1eca5b9d3 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
already there
but should be added in fstab
I have now added the swap partition to fstab but it still doesn’t work:
UUID=4edff8a1-0bc8-4974-80b6-3d990cdba082 none swap sw 0 0
What should I do?
What doesn’t work?
what does sudo swapon -s
show?
Please use code tags around what output you posted in all posts.
Edit: This makes it more readable.
- swap entry is malformatted should be like so:
UUID=4edff8a1-0bc8-4974-80b6-3d990cdba082 swap swap defaults,noatime 0 0
- for resume/hibernation to work you need to setup resume:
sudo nano /etc/default/grub
and addresume=UUID=4edff8a1-0bc8-4974-80b6-3d990cdba082
to theGRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=4edff8a1-0bc8-4974-80b6-3d990cdba082 loglevel=3 nowatchdog nvme_load=YES"
line.
After saved the filr rebuild grub.cfg:sudo grub-mkconfig -o /boot/grub/grub.cfg
Fstab
GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="EndeavourOS"
GRUB_CMDLINE_LINUX=""
I’ve configured both of them but when I hibernate, it still doesn’t work.
For the record, I’ve rebuilt grub.cfg
Two things to check:
/etc/default/grub
Can you check again if "
exists after YES
? From your post it seems you missed "
It should look like ... nvme_load=YES"
If yes, the regenerate grub config again sudo grub-mkconfig -o /boot/grub/grub.cfg
/etc/mkinitcpio.conf
Verify resume
exists as in below ex:
HOOKS=(base udev autodetect keyboard modconf block filesystems resume fsck)
If resume
already exists, then its all good.
If its not there, then regnerate initramfs sudo mkinitcpio -P
@joekamprad @ricklinux, hibernation page of Arch Wiki talk about this kernel parameter. Is it not required anymore?
resume_offset=swap_file_offset
Ok so resume
wasn’t there in /etc/mkinitcpio.conf
so I regenerated initramfs with the command you mentioned but it still seems to say:HOOKS="base udev autodetect modconf block keyboard keymap filesystems fsck"
And yes, there was a "
after nvme_load=YES
You need to add resume
in the HOOKS. Sorry for not being clear about it.
sudo nano /etc/mkinitcpio.conf
and add it.
Then regenrate initramfs sudo mkinitcpio -P
Thank you very much.
That worked.
I missed this one
But:
this is only needed if you are using swap file to define the exact location of the swapfile and notz needed for a swap partition because the exact location is defined with the UUID already
Ahh, ok - It clearing says swap file . Thanks for clearing that up. I am a big dum dum.
same counts for me on forgetting the mkinitcpio one
