After rebooting, the temperature disappeared from the list, the widget can’t read either.
p.s. i’m not auto runing sudo modprobe k10temp
problem resolv! THX!
You don’t need to autorun that command -.-
you failed to do that:
remove that, it will only cause problems as it is severly outdated. It was only needed BEFORE the necessary patches were upstreamed into the kernel.
Uh-huh, so these are the old packets.
I’m gonna go read how to rebuild with initframs dracut
ty
