How can I set a charging threshold
Hello, I have a problem setting a threshold for charging. I lower the number in charge_control_end_threshold but it doesn’t work and after reboot it resets itself back to 100. My model is Asus ZenBook14 UM433I and I use cinnamon as my DE
There are multiple methods to automatically set the threshold values at boot. For instance, you can do it with either a systemd service or a udev rule.
A more flexible approach would be to use an aur package called bat-asus-battery-bin, which provides a systemd service that sets the threshold values at boot and a command-line interface for you to change the threshold at runtime. E.g:
$ bat-asus-battery threshold some_value
https://aur.archlinux.org/packages/bat-asus-battery-bin
