sudo pacman -Rc gnome-session
local/adwaita-icon-theme 42.0+r1+gc144c3d75-1
GNOME standard icons
local/arc-gtk-theme-eos 20220405-1
A flat theme with transparent elements for GTK 2,3,4 and Gnome-Shell
local/gjs 2:1.72.2-1
Javascript Bindings for GNOME
local/gnome-autoar 0.4.3-2
Automatic archives creating and extracting library
local/gnome-bluetooth-3.0 42.4-1
GNOME Bluetooth Subsystem
local/gnome-browser-connector 42.0-1
Native browser connector for integration with extensions.gnome.org
local/gnome-desktop 1:42.4-1
Library with common API for various GNOME modules (GTK3)
local/gnome-desktop-common 1:42.4-1
Library with common API for various GNOME modules (common files)
local/gnome-disk-utility 42.0-1 (gnome)
Disk Management Utility for GNOME
local/gnome-nettool 42.0-1 (gnome-extra)
Graphical interface for various networking tools
local/gnome-power-manager 3.32.0-2
System power information and statistics
local/gnome-screenshot 41.0+r25+g45f08f0-1
Take pictures of your screen
local/gnome-session 42.0-1 (gnome)
The GNOME Session Handler
local/gnome-settings-daemon 42.2-1 (gnome)
GNOME Settings Daemon
local/gnome-shell 1:42.5-1 (gnome)
Next generation desktop shell
local/gnome-themes-extra 3.28+r6+g45b1d457-1
Extra Themes for GNOME Applications
local/gnome-tweaks 42beta+r14+g2d9d76c-2 (gnome-extra)
Graphical interface for advanced GNOME 3 settings (Tweak Tool)
local/gnome-usage 3.38.1-1 (gnome-extra)
GNOME application to view information about use of system resources
local/gtksourceview3 1:3.24.11+r28+g73e57b57-1
A text widget adding syntax highlighting and more to GNOME
local/gtksourceview4 4.8.3-1
local/libadwaita 1:1.2.0-1
Building blocks for modern adaptive GNOME applications
local/libopenraw 0.3.2-1
Library for decoding RAW files
local/libsoup 2.74.2-2
HTTP client/server library for GNOME
local/libsoup3 3.2.0-1
local/mutter 42.5-1 (gnome)
A window manager for GNOME
Thank you guys! You’re all huge life-savers for normies like me
some of those are in gnome-extra group so you can probably remove that as well
pacman -Runs gnome-extra
and again verify what it’s removing for anything you might need
