I have these default apps set up in my system (xfce)
I would like to change all fo ones that have “Atom” as default to the default Text Editor
How can I do that without going after each one of them?
You can use your favourite text editor (Atom, really? okay, I guess…) to edit this file:
~/.config/mimeapps.list
That’s where all your user’s custom associations are normally stored.
If an entry is missing, you can copy it from:
/usr/local/share/applications/mimeapps.list
That’s where distribution defaults are stored, your user’s file overrides this.
For more info, read:
https://wiki.archlinux.org/title/XDG_MIME_Applications
