Hi, I switched from Gnome to XFCE4 and I find that I’m missing hot corners, which I find indispensable for my way of working. I found that there is an application that allows me to have this as in Gnome, but it gives me an installation error and I can’t find how to fix it.
Could someone please help me?
what I want to install is xcfe4-hotcorner-plugin
and what it tells is:
CMake Deprecation Warning at CMakeLists.txt:1 (CMAKE_MINIMUM_REQUIRED):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- Checking for modules 'libxfce4panel-1.0;libxfce4ui-1;libwnck-3.0'
-- Package 'libxfce4panel-1.0', required by 'virtual:world', not found
-- Package 'libxfce4ui-1', required by 'virtual:world', not found
CMake Error at /usr/share/cmake-3.22/Modules/FindPkgConfig.cmake:603 (message):
A required package was not found
Call Stack (most recent call first):
/usr/share/cmake-3.22/Modules/FindPkgConfig.cmake:825 (_pkg_check_modules_internal)
CMakeLists.txt:11 (PKG_CHECK_MODULES)
-- Configuring incomplete, errors occurred!
See also "/home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeOutput.log".
[alejandro@aldo xfce4-hotcorner-plugin]$ xed /home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeOutput.log
The log:
The system is: Linux - 5.15.7-arch1-1 - x86_64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: /usr/bin/cc
Build flags:
Id flags:
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
The C compiler identification is GNU, found in "/home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/3.22.1/CompilerIdC/a.out"
Detecting C compiler ABI info compiled with the following output:
Change Dir: /home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make -f Makefile cmTC_49e4c/fast && /usr/bin/make -f CMakeFiles/cmTC_49e4c.dir/build.make CMakeFiles/cmTC_49e4c.dir/build
make[1]: Entering directory '/home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o
/usr/bin/cc -v -o CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-3.22/Modules/CMakeCCompilerABI.c
Using built-in specs.
COLLECT_GCC=/usr/bin/cc
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++,d --with-isl --with-linker-hash-style=gnu --with-system-zlib --enable-__cxa_atexit --enable-cet=auto --enable-checking=release --enable-clocale=gnu --enable-default-pie --enable-default-ssp --enable-gnu-indirect-function --enable-gnu-unique-object --enable-install-libiberty --enable-linker-build-id --enable-lto --enable-multilib --enable-plugin --enable-shared --enable-threads=posix --disable-libssp --disable-libstdcxx-pch --disable-libunwind-exceptions --disable-werror gdc_include_dir=/usr/include/dlang/gdc
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.1.0 (GCC)
COLLECT_GCC_OPTIONS='-v' '-o' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'CMakeFiles/cmTC_49e4c.dir/'
/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/cc1 -quiet -v /usr/share/cmake-3.22/Modules/CMakeCCompilerABI.c -quiet -dumpdir CMakeFiles/cmTC_49e4c.dir/ -dumpbase CMakeCCompilerABI.c.c -dumpbase-ext .c -mtune=generic -march=x86-64 -version -o /tmp/ccjtHgwV.s
GNU C17 (GCC) version 11.1.0 (x86_64-pc-linux-gnu)
compiled by GNU C version 11.1.0, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP
warning: MPFR header version 4.1.0 differs from library version 4.1.0-p13.
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../x86_64-pc-linux-gnu/include"
#include "..." search starts here:
#include <...> search starts here:
/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include
/usr/local/include
/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed
/usr/include
End of search list.
Compiler executable checksum: 3d0ac5c030c008e73f10e8b66957dbfa
as -v --64 -o CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o /tmp/ccjtHgwV.s
GNU assembler version 2.36.1 (x86_64-pc-linux-gnu) using BFD version (GNU Binutils) 2.36.1
COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-v' '-o' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.'
Linking C executable cmTC_49e4c
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_49e4c.dir/link.txt --verbose=1
/usr/bin/cc -v -rdynamic CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -o cmTC_49e4c
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper
Thread model: posix
COLLECT_GCC_OPTIONS='-v' '-rdynamic' '-o' 'cmTC_49e4c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'cmTC_49e4c.'
/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/collect2 -plugin /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper -plugin-opt=-fresolution=/tmp/ccaOtyVQ.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie -o cmTC_49e4c /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/Scrt1.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crti.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtbeginS.o -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0 -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../.. CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtendS.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crtn.o
make[1]: Leaving directory '/home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeTmp'
Parsed C implicit include dir info from above output: rv=done
found start of include info
found start of implicit include info
add: [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include]
add: [/usr/local/include]
add: [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed]
add: [/usr/include]
end of search list found
collapse include dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include] ==> [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include]
collapse include dir [/usr/local/include] ==> [/usr/local/include]
collapse include dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed] ==> [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed]
collapse include dir [/usr/include] ==> [/usr/include]
implicit include dirs: [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include;/usr/local/include;/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed;/usr/include]
Parsed C implicit link information from above output:
link line regex: [^( *|.*[/\])(ld|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
ignore line: [Change Dir: /home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command(s):/usr/bin/make -f Makefile cmTC_49e4c/fast && /usr/bin/make -f CMakeFiles/cmTC_49e4c.dir/build.make CMakeFiles/cmTC_49e4c.dir/build]
ignore line: [make[1]: Entering directory '/home/alejandro/xfce4-hotcorner-plugin/CMakeFiles/CMakeTmp']
ignore line: [Building C object CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o]
ignore line: [/usr/bin/cc -v -o CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-3.22/Modules/CMakeCCompilerABI.c]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=/usr/bin/cc]
ignore line: [Target: x86_64-pc-linux-gnu]
ignore line: [Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c c++ ada fortran go lto objc obj-c++ d --with-isl --with-linker-hash-style=gnu --with-system-zlib --enable-__cxa_atexit --enable-cet=auto --enable-checking=release --enable-clocale=gnu --enable-default-pie --enable-default-ssp --enable-gnu-indirect-function --enable-gnu-unique-object --enable-install-libiberty --enable-linker-build-id --enable-lto --enable-multilib --enable-plugin --enable-shared --enable-threads=posix --disable-libssp --disable-libstdcxx-pch --disable-libunwind-exceptions --disable-werror gdc_include_dir=/usr/include/dlang/gdc]
ignore line: [Thread model: posix]
ignore line: [Supported LTO compression algorithms: zlib zstd]
ignore line: [gcc version 11.1.0 (GCC) ]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'CMakeFiles/cmTC_49e4c.dir/']
ignore line: [ /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/cc1 -quiet -v /usr/share/cmake-3.22/Modules/CMakeCCompilerABI.c -quiet -dumpdir CMakeFiles/cmTC_49e4c.dir/ -dumpbase CMakeCCompilerABI.c.c -dumpbase-ext .c -mtune=generic -march=x86-64 -version -o /tmp/ccjtHgwV.s]
ignore line: [GNU C17 (GCC) version 11.1.0 (x86_64-pc-linux-gnu)]
ignore line: [ compiled by GNU C version 11.1.0 GMP version 6.2.1 MPFR version 4.1.0 MPC version 1.2.1 isl version isl-0.24-GMP]
ignore line: []
ignore line: [warning: MPFR header version 4.1.0 differs from library version 4.1.0-p13.]
ignore line: [GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072]
ignore line: [ignoring nonexistent directory "/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../x86_64-pc-linux-gnu/include"]
ignore line: [#include "..." search starts here:]
ignore line: [#include <...> search starts here:]
ignore line: [ /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include]
ignore line: [ /usr/local/include]
ignore line: [ /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/include-fixed]
ignore line: [ /usr/include]
ignore line: [End of search list.]
ignore line: []
ignore line: [Compiler executable checksum: 3d0ac5c030c008e73f10e8b66957dbfa]
ignore line: [ as -v --64 -o CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o /tmp/ccjtHgwV.s]
ignore line: [GNU assembler version 2.36.1 (x86_64-pc-linux-gnu) using BFD version (GNU Binutils) 2.36.1]
ignore line: [COMPILER_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/]
ignore line: [LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../:/lib/:/usr/lib/]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.']
ignore line: [Linking C executable cmTC_49e4c]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_49e4c.dir/link.txt --verbose=1]
ignore line: [/usr/bin/cc -v -rdynamic CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -o cmTC_49e4c ]
ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-rdynamic' '-o' 'cmTC_49e4c' '-mtune=generic' '-march=x86-64' '-dumpdir' 'cmTC_49e4c.']
link line: [ /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/collect2 -plugin /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper -plugin-opt=-fresolution=/tmp/ccaOtyVQ.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie -o cmTC_49e4c /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/Scrt1.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crti.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtbeginS.o -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0 -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../.. CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtendS.o /usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crtn.o]
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/collect2] ==> ignore
arg [-plugin] ==> ignore
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/liblto_plugin.so] ==> ignore
arg [-plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/lto-wrapper] ==> ignore
arg [-plugin-opt=-fresolution=/tmp/ccaOtyVQ.res] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
arg [-plugin-opt=-pass-through=-lc] ==> ignore
arg [--build-id] ==> ignore
arg [--eh-frame-hdr] ==> ignore
arg [--hash-style=gnu] ==> ignore
arg [-m] ==> ignore
arg [elf_x86_64] ==> ignore
arg [-export-dynamic] ==> ignore
arg [-dynamic-linker] ==> ignore
arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
arg [-pie] ==> ignore
arg [-o] ==> ignore
arg [cmTC_49e4c] ==> ignore
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/Scrt1.o] ==> obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/Scrt1.o]
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crti.o] ==> obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crti.o]
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtbeginS.o] ==> obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtbeginS.o]
arg [-L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0] ==> dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0]
arg [-L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib] ==> dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib]
arg [-L/lib/../lib] ==> dir [/lib/../lib]
arg [-L/usr/lib/../lib] ==> dir [/usr/lib/../lib]
arg [-L/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../..] ==> dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../..]
arg [CMakeFiles/cmTC_49e4c.dir/CMakeCCompilerABI.c.o] ==> ignore
arg [-lgcc] ==> lib [gcc]
arg [--push-state] ==> ignore
arg [--as-needed] ==> ignore
arg [-lgcc_s] ==> lib [gcc_s]
arg [--pop-state] ==> ignore
arg [-lc] ==> lib [c]
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtendS.o] ==> obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtendS.o]
arg [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crtn.o] ==> obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crtn.o]
collapse obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/Scrt1.o] ==> [/usr/lib/Scrt1.o]
collapse obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crti.o] ==> [/usr/lib/crti.o]
collapse obj [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib/crtn.o] ==> [/usr/lib/crtn.o]
collapse library dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0] ==> [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0]
collapse library dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../../../lib] ==> [/usr/lib]
collapse library dir [/lib/../lib] ==> [/lib]
collapse library dir [/usr/lib/../lib] ==> [/usr/lib]
collapse library dir [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/../../..] ==> [/usr/lib]
implicit libs: [gcc;gcc_s;c;gcc;gcc_s]
implicit objs: [/usr/lib/Scrt1.o;/usr/lib/crti.o;/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtbeginS.o;/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0/crtendS.o;/usr/lib/crtn.o]
implicit dirs: [/usr/lib/gcc/x86_64-pc-linux-gnu/11.1.0;/usr/lib;/lib]
implicit fwks: []
By the way, it all started here
If that tells you anything, I appreciate your help!
