Hibernation fails to resume with encrypted btrfs swap partition
Hey EndeavourOS,
I have a pretty recently installed system, installed with the Mercury Neo iso. As far as I can tell, the system is saving to swap properly, it just fails at resuming from hibernation. I did some searching through dmesg and I don’t think this is a configuration issue or has much to do with encryption or btrfs. From my, somewhat naive, searching my guess is that it’s a kernel issue related to multimedia cards.
dmesg output (Lines 850-866 at the 20s time jump seem to be where it all goes down):
[    0.000000] Linux version 6.16.8-arch3-1 (linux@archlinux) (gcc (GCC) 15.2.1 20250813, GNU ld (GNU Binutils) 2.45.0) #1 SMP PREEMPT_DYNAMIC Mon, 22 Sep 2025 22:08:35 +0000
[    0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=ad68e6c7-3abb-4416-9ab0-58584685c6bf rw rootflags=subvol=@ nowatchdog nvme_load=YES rd.luks.uuid=b9d16654-2455-4124-811a-8bfb86e271ab rd.luks.uuid=d9caec7b-56db-4947-9510-241a64e358a2 resume=/dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2 loglevel=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000c80aefff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c80af000-0x00000000c80affff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000c80b0000-0x00000000c80b0fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c80b1000-0x00000000d8f9afff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d8f9b000-0x00000000d9d7efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d9d7f000-0x00000000d9f7efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000d9f7f000-0x00000000d9ffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000d9fff000-0x00000000d9ffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da000000-0x00000000de7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041f7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] efi: EFI v2.5 by HP
[    0.000000] efi: ACPI=0xd9ffe000 ACPI 2.0=0xd9ffe014 TPMFinalLog=0xd9f76000 SMBIOS=0xd9765000 SMBIOS 3.0=0xd9763000 MEMATTR=0xd68d7018 ESRT=0xd6a25618 INITRD=0xc8194218 RNG=0xd9fb0018 TPMEventLog=0xd9fa5018
[    0.000000] random: crng init done
[    0.000000] efi: Remove mem54: MMIO range=[0xf8000000-0xfbffffff] (64MB) from e820 map
[    0.000000] e820: remove [mem 0xf8000000-0xfbffffff] reserved
[    0.000000] efi: Not removing mem55: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: HP HP EliteBook 840 G4/828C, BIOS P78 Ver. 01.16 03/29/2018
[    0.000000] DMI: Memory slots populated: 2/2
[    0.000000] tsc: Detected 2700.000 MHz processor
[    0.000000] tsc: Detected 2699.909 MHz TSC
[    0.001167] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001170] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001178] last_pfn = 0x41f800 max_arch_pfn = 0x400000000
[    0.001183] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
[    0.001186] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001660] last_pfn = 0xda000 max_arch_pfn = 0x400000000
[    0.011064] esrt: Reserving ESRT space from 0x00000000d6a25618 to 0x00000000d6a25650.
[    0.011070] e820: update [mem 0xd6a25000-0xd6a25fff] usable ==> reserved
[    0.011087] Using GB pages for direct mapping
[    0.011555] Secure boot disabled
[    0.011556] RAMDISK: [mem 0xbb546000-0xbd7f0fff]
[    0.011561] ACPI: Early table checksum verification disabled
[    0.011564] ACPI: RSDP 0x00000000D9FFE014 000024 (v02 HPQOEM)
[    0.011569] ACPI: XSDT 0x00000000D9FB8188 00010C (v01 HPQOEM SLIC-BPC 00000000      01000013)
[    0.011575] ACPI: FACP 0x00000000D9FE3000 00010C (v05 HPQOEM SLIC-BPC 00000000 HP   00000001)
[    0.011582] ACPI: DSDT 0x00000000D9FC0000 01F18E (v02 HPQOEM 828C     00000000 INTL 20160422)
[    0.011586] ACPI: FACS 0x00000000D9F61000 000040
[    0.011589] ACPI: SSDT 0x00000000D9FFC000 00012A (v02 HP     ShmTable 00000001 INTL 20160422)
[    0.011593] ACPI: SSDT 0x00000000D9FEF000 00C0A3 (v02 AcpiRe PLT_RTD3 00001000 INTL 20160422)
[    0.011597] ACPI: UEFI 0x00000000D9F71000 000042 (v01 HPQOEM EDK2     00000002      01000013)
[    0.011600] ACPI: SSDT 0x00000000D9FED000 0003B3 (v02 HPQOEM Tpm2Tabl 00001000 INTL 20160422)
[    0.011604] ACPI: TPM2 0x00000000D9FEC000 000034 (v03 HPQOEM EDK2     00000002      01000013)
[    0.011608] ACPI: SSDT 0x00000000D9FE8000 003051 (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.011611] ACPI: SSDT 0x00000000D9FE7000 0005C6 (v02 Intel  PerfTune 00001000 INTL 20160422)
[    0.011615] ACPI: MSDM 0x00000000D9FE6000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
[    0.011619] ACPI: SLIC 0x00000000D9FE5000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
[    0.011623] ACPI: WSMT 0x00000000D9FE4000 000028 (v01 HPQOEM 828C     00000001 HP   00000001)
[    0.011626] ACPI: HPET 0x00000000D9FE2000 000038 (v01 HPQOEM 828C     00000001 HP   00000001)
[    0.011630] ACPI: APIC 0x00000000D9FE1000 00012C (v03 HPQOEM 828C     00000001 HP   00000001)
[    0.011634] ACPI: MCFG 0x00000000D9FE0000 00003C (v01 HPQOEM 828C     00000001 HP   00000001)
[    0.011637] ACPI: SSDT 0x00000000D9FBF000 0001BC (v02 HPQOEM Sata0Ide 00001000 INTL 20160422)
[    0.011641] ACPI: SSDT 0x00000000D9FBE000 000734 (v01 HPQOEM PtidDevc 00001000 INTL 20160422)
[    0.011644] ACPI: SSDT 0x00000000D9FBC000 0017AE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.011648] ACPI: SSDT 0x00000000D9FBB000 0009CF (v02 CtdpB  CtdpB    00001000 INTL 20160422)
[    0.011652] ACPI: SSDT 0x00000000D9FBA000 000141 (v02 INTEL  HdaDsp   00000000 INTL 20160422)
[    0.011655] ACPI: SSDT 0x00000000D9FB9000 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.011659] ACPI: SSDT 0x00000000D9FFD000 000346 (v01 INTEL  EInkApp  00000000 INTL 20160422)
[    0.011663] ACPI: DBGP 0x00000000D9FB7000 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.011667] ACPI: DBG2 0x00000000D9FB6000 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.011670] ACPI: DMAR 0x00000000D9FB5000 0000F0 (v01 INTEL  KBL      00000001 INTL 00000001)
[    0.011674] ACPI: NHLT 0x00000000D9FB4000 00002D (v00 INTEL  EDK2     00000002      01000013)
[    0.011678] ACPI: ASF! 0x00000000D9FB3000 0000A0 (v32 HPQOEM  UYA     00000001 TFSM 000F4240)
[    0.011682] ACPI: FPDT 0x00000000D9FB2000 000044 (v01 HPQOEM EDK2     00000002      01000013)
[    0.011685] ACPI: BGRT 0x00000000D9FB1000 000038 (v01 HPQOEM EDK2     00000002      01000013)
[    0.011689] ACPI: SSDT 0x00000000D9FEE000 0002F9 (v02 HP     PwrCtlEv 00000001 INTL 20160422)
[    0.011692] ACPI: Reserving FACP table memory at [mem 0xd9fe3000-0xd9fe310b]
[    0.011694] ACPI: Reserving DSDT table memory at [mem 0xd9fc0000-0xd9fdf18d]
[    0.011695] ACPI: Reserving FACS table memory at [mem 0xd9f61000-0xd9f6103f]
[    0.011696] ACPI: Reserving SSDT table memory at [mem 0xd9ffc000-0xd9ffc129]
[    0.011697] ACPI: Reserving SSDT table memory at [mem 0xd9fef000-0xd9ffb0a2]
[    0.011698] ACPI: Reserving UEFI table memory at [mem 0xd9f71000-0xd9f71041]
[    0.011698] ACPI: Reserving SSDT table memory at [mem 0xd9fed000-0xd9fed3b2]
[    0.011699] ACPI: Reserving TPM2 table memory at [mem 0xd9fec000-0xd9fec033]
[    0.011700] ACPI: Reserving SSDT table memory at [mem 0xd9fe8000-0xd9feb050]
[    0.011701] ACPI: Reserving SSDT table memory at [mem 0xd9fe7000-0xd9fe75c5]
[    0.011702] ACPI: Reserving MSDM table memory at [mem 0xd9fe6000-0xd9fe6054]
[    0.011703] ACPI: Reserving SLIC table memory at [mem 0xd9fe5000-0xd9fe5175]
[    0.011704] ACPI: Reserving WSMT table memory at [mem 0xd9fe4000-0xd9fe4027]
[    0.011705] ACPI: Reserving HPET table memory at [mem 0xd9fe2000-0xd9fe2037]
[    0.011706] ACPI: Reserving APIC table memory at [mem 0xd9fe1000-0xd9fe112b]
[    0.011707] ACPI: Reserving MCFG table memory at [mem 0xd9fe0000-0xd9fe003b]
[    0.011708] ACPI: Reserving SSDT table memory at [mem 0xd9fbf000-0xd9fbf1bb]
[    0.011709] ACPI: Reserving SSDT table memory at [mem 0xd9fbe000-0xd9fbe733]
[    0.011709] ACPI: Reserving SSDT table memory at [mem 0xd9fbc000-0xd9fbd7ad]
[    0.011710] ACPI: Reserving SSDT table memory at [mem 0xd9fbb000-0xd9fbb9ce]
[    0.011711] ACPI: Reserving SSDT table memory at [mem 0xd9fba000-0xd9fba140]
[    0.011712] ACPI: Reserving SSDT table memory at [mem 0xd9fb9000-0xd9fb929e]
[    0.011713] ACPI: Reserving SSDT table memory at [mem 0xd9ffd000-0xd9ffd345]
[    0.011714] ACPI: Reserving DBGP table memory at [mem 0xd9fb7000-0xd9fb7033]
[    0.011715] ACPI: Reserving DBG2 table memory at [mem 0xd9fb6000-0xd9fb6053]
[    0.011716] ACPI: Reserving DMAR table memory at [mem 0xd9fb5000-0xd9fb50ef]
[    0.011717] ACPI: Reserving NHLT table memory at [mem 0xd9fb4000-0xd9fb402c]
[    0.011718] ACPI: Reserving ASF! table memory at [mem 0xd9fb3000-0xd9fb309f]
[    0.011719] ACPI: Reserving FPDT table memory at [mem 0xd9fb2000-0xd9fb2043]
[    0.011719] ACPI: Reserving BGRT table memory at [mem 0xd9fb1000-0xd9fb1037]
[    0.011720] ACPI: Reserving SSDT table memory at [mem 0xd9fee000-0xd9fee2f8]
[    0.011841] No NUMA configuration found
[    0.011842] Faking a node at [mem 0x0000000000000000-0x000000041f7fffff]
[    0.011853] NODE_DATA(0) allocated [mem 0x41f7d5280-0x41f7fffff]
[    0.012123] Zone ranges:
[    0.012124]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.012126]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.012128]   Normal   [mem 0x0000000100000000-0x000000041f7fffff]
[    0.012130]   Device   empty
[    0.012131] Movable zone start for each node
[    0.012133] Early memory node ranges
[    0.012133]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.012135]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.012136]   node   0: [mem 0x0000000000100000-0x00000000c80aefff]
[    0.012138]   node   0: [mem 0x00000000c80b1000-0x00000000d8f9afff]
[    0.012139]   node   0: [mem 0x00000000d9fff000-0x00000000d9ffffff]
[    0.012140]   node   0: [mem 0x0000000100000000-0x000000041f7fffff]
[    0.012143] Initmem setup node 0 [mem 0x0000000000001000-0x000000041f7fffff]
[    0.012149] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.012151] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.012176] On node 0, zone DMA: 98 pages in unavailable ranges
[    0.018738] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.018773] On node 0, zone DMA32: 4196 pages in unavailable ranges
[    0.043376] On node 0, zone Normal: 24576 pages in unavailable ranges
[    0.043395] On node 0, zone Normal: 2048 pages in unavailable ranges
[    0.043404] Reserving Intel graphics memory at [mem 0xdc800000-0xde7fffff]
[    0.043619] ACPI: PM-Timer IO Port: 0x1808
[    0.043629] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.043631] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.043632] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.043633] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.043633] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.043634] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.043635] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.043636] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.043637] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.043637] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.043638] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.043639] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.043640] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.043641] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.043641] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.043642] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.043670] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.043673] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.043675] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.043680] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.043682] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.043690] e820: update [mem 0xd5e99000-0xd5ee3fff] usable ==> reserved
[    0.043703] TSC deadline timer available
[    0.043708] CPU topo: Max. logical packages:   1
[    0.043709] CPU topo: Max. logical dies:       1
[    0.043709] CPU topo: Max. dies per package:   1
[    0.043714] CPU topo: Max. threads per core:   2
[    0.043715] CPU topo: Num. cores per package:     2
[    0.043716] CPU topo: Num. threads per package:   4
[    0.043716] CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
[    0.043738] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.043741] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.043743] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.043745] PM: hibernation: Registered nosave memory: [mem 0xc80af000-0xc80b0fff]
[    0.043748] PM: hibernation: Registered nosave memory: [mem 0xd5e99000-0xd5ee3fff]
[    0.043750] PM: hibernation: Registered nosave memory: [mem 0xd6a25000-0xd6a25fff]
[    0.043752] PM: hibernation: Registered nosave memory: [mem 0xd8f9b000-0xd9ffefff]
[    0.043754] PM: hibernation: Registered nosave memory: [mem 0xda000000-0xffffffff]
[    0.043755] [mem 0xde800000-0xfe00ffff] available for PCI devices
[    0.043757] Booting paravirtualized kernel on bare hardware
[    0.043759] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.052343] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.052654] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u524288
[    0.052663] pcpu-alloc: s217088 r8192 d28672 u524288 alloc=1*2097152
[    0.052666] pcpu-alloc: [0] 0 1 2 3
[    0.052710] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=ad68e6c7-3abb-4416-9ab0-58584685c6bf rw rootflags=subvol=@ nowatchdog nvme_load=YES rd.luks.uuid=b9d16654-2455-4124-811a-8bfb86e271ab rd.luks.uuid=d9caec7b-56db-4947-9510-241a64e358a2 resume=/dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2 loglevel=3
[    0.052860] Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-linux nvme_load=YES", will be passed to user space.
[    0.052896] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.054821] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.055806] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.055903] software IO TLB: area num 4.
[    0.071701] Fallback order for Node 0: 0
[    0.071705] Built 1 zonelists, mobility grouping on.  Total pages: 4163382
[    0.071706] Policy zone: Normal
[    0.072003] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.123970] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.123994] Kernel/User page tables isolation: enabled
[    0.135635] ftrace: allocating 56047 entries in 220 pages
[    0.135637] ftrace: allocated 220 pages with 5 groups
[    0.135726] Dynamic Preempt: full
[    0.135768] rcu: Preemptible hierarchical RCU implementation.
[    0.135769] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[    0.135770] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.135771] 	Trampoline variant of Tasks RCU enabled.
[    0.135772] 	Rude variant of Tasks RCU enabled.
[    0.135772] 	Tracing variant of Tasks RCU enabled.
[    0.135773] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.135774] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.135780] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.135782] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.135783] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.143353] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[    0.143585] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.143858] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.143898] Console: colour dummy device 80x25
[    0.143901] printk: legacy console [tty0] enabled
[    0.143958] ACPI: Core revision 20250404
[    0.144191] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.144220] APIC: Switch to symmetric I/O mode setup
[    0.144223] DMAR: Host address width 39
[    0.144224] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.144232] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.144235] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.144240] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.144242] DMAR: RMRR base: 0x000000d9c7a000 end: 0x000000d9c99fff
[    0.144244] DMAR: RMRR base: 0x000000dc000000 end: 0x000000de7fffff
[    0.144246] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.144247] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.144249] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.144251] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.144252] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.145991] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.145994] x2apic enabled
[    0.146068] APIC: Switched APIC routing to: cluster x2apic
[    0.149936] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26eae8729ef, max_idle_ns: 440795235156 ns
[    0.149942] Calibrating delay loop (skipped), value calculated using timer frequency.. 5399.81 BogoMIPS (lpj=2699909)
[    0.149978] x86/cpu: SGX disabled or unsupported by BIOS.
[    0.149985] CPU0: Thermal monitoring enabled (TM1)
[    0.150037] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.150039] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[    0.150044] process: using mwait in idle threads
[    0.150051] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.150056] SRBDS: Mitigation: Microcode
[    0.150062] Spectre V2 : Mitigation: IBRS
[    0.150068] RETBleed: Mitigation: IBRS
[    0.150069] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.150070] MDS: Mitigation: Clear CPU buffers
[    0.150071] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.150072] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.150073] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.150074] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.150077] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.150092] GDS: Mitigation: Microcode
[    0.150099] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.150102] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.150104] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.150105] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.150107] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.150110] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.150112] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.150114] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.150116] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.150940] Freeing SMP alternatives memory: 56K
[    0.150940] pid_max: default: 32768 minimum: 301
[    0.150940] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[    0.150940] landlock: Up and running.
[    0.150940] Yama: becoming mindful.
[    0.150940] LSM support for eBPF active
[    0.150940] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.150940] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.150940] smpboot: CPU0: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz (family: 0x6, model: 0x8e, stepping: 0x9)
[    0.150940] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.150940] ... version:                4
[    0.150940] ... bit width:              48
[    0.150940] ... generic registers:      4
[    0.150940] ... value mask:             0000ffffffffffff
[    0.150940] ... max period:             00007fffffffffff
[    0.150940] ... fixed-purpose events:   3
[    0.150940] ... event mask:             000000070000000f
[    0.150940] signal: max sigframe size: 2032
[    0.150940] Estimated ratio of average max frequency by base frequency (times 1024): 1175
[    0.150940] rcu: Hierarchical SRCU implementation.
[    0.150940] rcu: 	Max phase no-delay instances is 400.
[    0.150940] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.151079] smp: Bringing up secondary CPUs ...
[    0.151213] smpboot: x86: Booting SMP configuration:
[    0.151214] .... node  #0, CPUs:      #1 #2 #3
[    0.154966] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.154970] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.154972] VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
[    0.154987] smp: Brought up 1 node, 4 CPUs
[    0.154987] smpboot: Total of 4 processors activated (21599.27 BogoMIPS)
[    0.156009] Memory: 16191384K/16653528K available (19868K kernel code, 2942K rwdata, 16672K rodata, 4664K init, 4948K bss, 450400K reserved, 0K cma-reserved)
[    0.156461] devtmpfs: initialized
[    0.156461] x86/mm: Memory block size: 128MB
[    0.158589] ACPI: PM: Registering ACPI NVS region [mem 0xc80af000-0xc80affff] (4096 bytes)
[    0.158589] ACPI: PM: Registering ACPI NVS region [mem 0xd9d7f000-0xd9f7efff] (2097152 bytes)
[    0.158589] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.158589] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.158589] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[    0.158959] pinctrl core: initialized pinctrl subsystem
[    0.159177] PM: RTC time: 19:09:15, date: 2025-09-29
[    0.159770] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.160128] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.160290] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.160445] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.160463] audit: initializing netlink subsys (disabled)
[    0.160485] audit: type=2000 audit(1759172955.010:1): state=initialized audit_enabled=0 res=1
[    0.160485] thermal_sys: Registered thermal governor 'fair_share'
[    0.160485] thermal_sys: Registered thermal governor 'bang_bang'
[    0.160485] thermal_sys: Registered thermal governor 'step_wise'
[    0.160485] thermal_sys: Registered thermal governor 'user_space'
[    0.160485] thermal_sys: Registered thermal governor 'power_allocator'
[    0.160485] cpuidle: using governor ladder
[    0.160485] cpuidle: using governor menu
[    0.160485] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.160485] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.160485] PCI: ECAM [mem 0xf8000000-0xfbffffff] (base 0xf8000000) for domain 0000 [bus 00-3f]
[    0.160956] PCI: Using configuration type 1 for base access
[    0.161111] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.161111] HugeTLB: allocation took 0ms with hugepage_allocation_threads=1
[    0.161111] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.161111] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.161111] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.161111] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.161986] raid6: skipped pq benchmark and selected avx2x4
[    0.161986] raid6: using avx2x2 recovery algorithm
[    0.162217] ACPI: Added _OSI(Module Device)
[    0.162220] ACPI: Added _OSI(Processor Device)
[    0.162222] ACPI: Added _OSI(Processor Aggregator Device)
[    0.217875] ACPI: 14 ACPI AML tables successfully acquired and loaded
[    0.221043] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.229639] ACPI: Dynamic OEM Table Load:
[    0.229651] ACPI: SSDT 0xFFFF8DB881844C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.231460] ACPI: Dynamic OEM Table Load:
[    0.231470] ACPI: SSDT 0xFFFF8DB880F3B800 0006B4 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.234221] ACPI: Dynamic OEM Table Load:
[    0.234232] ACPI: SSDT 0xFFFF8DB880F44000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.237087] ACPI: Dynamic OEM Table Load:
[    0.237096] ACPI: SSDT 0xFFFF8DB881845400 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.239853] ACPI: Dynamic OEM Table Load:
[    0.239863] ACPI: SSDT 0xFFFF8DB881846400 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.242694] ACPI: EC: EC started
[    0.242696] ACPI: EC: interrupt blocked
[    3.125243] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    3.125247] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    3.125250] ACPI: Interpreter enabled
[    3.125314] ACPI: PM: (supports S0 S3 S4 S5)
[    3.125316] ACPI: Using IOAPIC for interrupt routing
[    3.127431] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    3.127433] PCI: Using E820 reservations for host bridge windows
[    3.128340] ACPI: Enabled 8 GPEs in block 00 to 7F
[    3.139528] ACPI: \_SB_.PCI0.RP02.PXP_: New power resource
[    3.273366] ACPI: \_SB_.PCI0.RP04.PXSX.WRST: New power resource
[    3.301975] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    3.301985] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    3.304544] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    3.304548] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    3.307666] PCI host bridge to bus 0000:00
[    3.307672] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    3.307676] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    3.307679] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
[    3.307682] pci_bus 0000:00: root bus resource [mem 0xde800000-0xf7ffffff window]
[    3.307684] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1fffffffff window]
[    3.307686] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    3.307688] pci_bus 0000:00: root bus resource [bus 00-3e]
[    3.307709] pci 0000:00:00.0: [8086:5904] type 00 class 0x060000 conventional PCI endpoint
[    3.307813] pci 0000:00:02.0: [8086:5916] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[    3.307835] pci 0000:00:02.0: BAR 0 [mem 0x1ff0000000-0x1ff0ffffff 64bit]
[    3.307839] pci 0000:00:02.0: BAR 2 [mem 0x1fe0000000-0x1fefffffff 64bit pref]
[    3.307842] pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
[    3.307859] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    3.308216] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330 conventional PCI endpoint
[    3.308259] pci 0000:00:14.0: BAR 0 [mem 0xdec20000-0xdec2ffff 64bit]
[    3.308300] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    3.309376] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000 conventional PCI endpoint
[    3.309414] pci 0000:00:14.2: BAR 0 [mem 0x1ff1018000-0x1ff1018fff 64bit]
[    3.309636] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000 conventional PCI endpoint
[    3.310023] pci 0000:00:15.0: BAR 0 [mem 0x1ff1017000-0x1ff1017fff 64bit]
[    3.310886] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000 conventional PCI endpoint
[    3.310940] pci 0000:00:15.1: BAR 0 [mem 0x1ff1016000-0x1ff1016fff 64bit]
[    3.311487] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000 conventional PCI endpoint
[    3.311530] pci 0000:00:16.0: BAR 0 [mem 0x1ff1015000-0x1ff1015fff 64bit]
[    3.311576] pci 0000:00:16.0: PME# supported from D3hot
[    3.312378] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601 conventional PCI endpoint
[    3.312415] pci 0000:00:17.0: BAR 0 [mem 0xdec34000-0xdec35fff]
[    3.312418] pci 0000:00:17.0: BAR 1 [mem 0xdec37000-0xdec370ff]
[    3.312421] pci 0000:00:17.0: BAR 2 [io  0x3080-0x3087]
[    3.312424] pci 0000:00:17.0: BAR 3 [io  0x3088-0x308b]
[    3.312427] pci 0000:00:17.0: BAR 4 [io  0x3060-0x307f]
[    3.312429] pci 0000:00:17.0: BAR 5 [mem 0xdec36000-0xdec367ff]
[    3.312468] pci 0000:00:17.0: PME# supported from D3hot
[    3.312956] pci 0000:00:1c.0: [8086:9d11] type 01 class 0x060400 PCIe Root Port
[    3.312979] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.312985] pci 0000:00:1c.0:   bridge window [mem 0xdeb00000-0xdebfffff]
[    3.313053] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    3.313965] pci 0000:00:1c.3: [8086:9d13] type 01 class 0x060400 PCIe Root Port
[    3.313988] pci 0000:00:1c.3: PCI bridge to [bus 02]
[    3.313994] pci 0000:00:1c.3:   bridge window [mem 0xdea00000-0xdeafffff]
[    3.314057] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    3.314953] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400 PCIe Root Port
[    3.314974] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    3.314980] pci 0000:00:1d.0:   bridge window [mem 0xde900000-0xde9fffff]
[    3.315042] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    3.315960] pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100 conventional PCI endpoint
[    3.316441] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000 conventional PCI endpoint
[    3.316482] pci 0000:00:1f.2: BAR 0 [mem 0xdec30000-0xdec33fff]
[    3.316885] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040380 conventional PCI endpoint
[    3.316935] pci 0000:00:1f.3: BAR 0 [mem 0x1ff1010000-0x1ff1013fff 64bit]
[    3.316944] pci 0000:00:1f.3: BAR 4 [mem 0x1ff1000000-0x1ff100ffff 64bit]
[    3.316991] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    3.318435] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500 conventional PCI endpoint
[    3.318559] pci 0000:00:1f.4: BAR 0 [mem 0x1ff1014000-0x1ff10140ff 64bit]
[    3.318571] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[    3.319014] pci 0000:00:1f.6: [8086:15d8] type 00 class 0x020000 conventional PCI endpoint
[    3.319062] pci 0000:00:1f.6: BAR 0 [mem 0xdec00000-0xdec1ffff]
[    3.319120] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    3.319608] pci 0000:01:00.0: [10ec:522a] type 00 class 0xff0000 PCIe Endpoint
[    3.319667] pci 0000:01:00.0: BAR 0 [mem 0xdeb00000-0xdeb00fff]
[    3.319779] pci 0000:01:00.0: supports D1 D2
[    3.319781] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[    3.320059] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.320173] pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000 PCIe Endpoint
[    3.320266] pci 0000:02:00.0: BAR 0 [mem 0xdea00000-0xdea01fff 64bit]
[    3.320436] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    3.321194] pci 0000:00:1c.3: PCI bridge to [bus 02]
[    3.321269] pci 0000:03:00.0: [144d:a804] type 00 class 0x010802 PCIe Endpoint
[    3.321315] pci 0000:03:00.0: BAR 0 [mem 0xde900000-0xde903fff 64bit]
[    3.321606] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    3.326367] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    3.326449] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    3.326529] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    3.326609] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    3.326688] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    3.326767] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[    3.326846] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    3.326925] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    3.327603] ACPI: EC: interrupt unblocked
[    3.327605] ACPI: EC: event unblocked
[    3.327611] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    3.327613] ACPI: EC: GPE=0x6e
[    3.327615] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    3.327618] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    3.327740] iommu: Default domain type: Translated
[    3.327740] iommu: DMA domain TLB invalidation policy: lazy mode
[    3.328043] SCSI subsystem initialized
[    3.328054] libata version 3.00 loaded.
[    3.328054] ACPI: bus type USB registered
[    3.328054] usbcore: registered new interface driver usbfs
[    3.328054] usbcore: registered new interface driver hub
[    3.328054] usbcore: registered new device driver usb
[    3.328054] EDAC MC: Ver: 3.0.0
[    3.328142] efivars: Registered efivars operations
[    3.328245] NetLabel: Initializing
[    3.328247] NetLabel:  domain hash size = 128
[    3.328248] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    3.328270] NetLabel:  unlabeled traffic allowed by default
[    3.328276] mctp: management component transport protocol core
[    3.328277] NET: Registered PF_MCTP protocol family
[    3.328287] PCI: Using ACPI for IRQ routing
[    3.335754] PCI: pci_cache_line_size set to 64 bytes
[    3.335847] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    3.335850] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    3.335852] e820: reserve RAM buffer [mem 0xc80af000-0xcbffffff]
[    3.335854] e820: reserve RAM buffer [mem 0xd5e99000-0xd7ffffff]
[    3.335855] e820: reserve RAM buffer [mem 0xd6a25000-0xd7ffffff]
[    3.335857] e820: reserve RAM buffer [mem 0xd8f9b000-0xdbffffff]
[    3.335858] e820: reserve RAM buffer [mem 0xda000000-0xdbffffff]
[    3.335860] e820: reserve RAM buffer [mem 0x41f800000-0x41fffffff]
[    3.335963] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    3.335963] pci 0000:00:02.0: vgaarb: bridge control possible
[    3.335963] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    3.335963] vgaarb: loaded
[    3.336105] clocksource: Switched to clocksource tsc-early
[    3.336872] VFS: Disk quotas dquot_6.6.0
[    3.336884] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.337029] pnp: PnP ACPI init
[    3.337299] system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
[    3.337305] system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
[    3.337308] system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
[    3.337310] system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    3.337313] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    3.337782] system 00:01: [io  0x2000-0x20fe] has been reserved
[    3.338009] system 00:02: [io  0x0680-0x069f] has been reserved
[    3.338013] system 00:02: [io  0xffff] has been reserved
[    3.338015] system 00:02: [io  0xffff] has been reserved
[    3.338017] system 00:02: [io  0xffff] has been reserved
[    3.338019] system 00:02: [io  0x1800-0x18fe] could not be reserved
[    3.338022] system 00:02: [io  0x164e-0x164f] has been reserved
[    3.338324] system 00:06: [io  0x0200-0x023f] has been reserved
[    3.338328] system 00:06: [mem 0xfedf0000-0xfedfffff] has been reserved
[    3.340145] system 00:07: [mem 0xfe031000-0xfe031fff] has been reserved
[    3.340149] system 00:07: [mem 0xfe030008-0xfe030fff] has been reserved
[    3.341016] system 00:08: [mem 0xfe030000-0xfe030007] has been reserved
[    3.341465] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[    3.341469] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[    3.341471] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[    3.341474] system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
[    3.341476] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[    3.341479] system 00:09: [mem 0xfed90000-0xfed93fff] could not be reserved
[    3.341481] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[    3.341484] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[    3.341486] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[    3.341489] system 00:09: [mem 0xde800000-0xde81ffff] has been reserved
[    3.342019] pnp: PnP ACPI: found 10 devices
[    3.348596] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    3.348674] NET: Registered PF_INET protocol family
[    3.348825] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    3.371405] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    3.371440] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    3.371529] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    3.371796] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    3.372075] TCP: Hash tables configured (established 131072 bind 65536)
[    3.372199] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    3.372303] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    3.372392] UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    3.372495] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    3.372507] NET: Registered PF_XDP protocol family
[    3.372517] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    3.372524] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    3.372537] pci 0000:00:1c.0: bridge window [mem 0x1c00000000-0x1c001fffff 64bit pref]: assigned
[    3.372541] pci 0000:00:1c.0: bridge window [io  0x4000-0x4fff]: assigned
[    3.372546] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    3.372549] pci 0000:00:1c.0:   bridge window [io  0x4000-0x4fff]
[    3.372554] pci 0000:00:1c.0:   bridge window [mem 0xdeb00000-0xdebfffff]
[    3.372558] pci 0000:00:1c.0:   bridge window [mem 0x1c00000000-0x1c001fffff 64bit pref]
[    3.372563] pci 0000:00:1c.3: PCI bridge to [bus 02]
[    3.372567] pci 0000:00:1c.3:   bridge window [mem 0xdea00000-0xdeafffff]
[    3.372574] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    3.372578] pci 0000:00:1d.0:   bridge window [mem 0xde900000-0xde9fffff]
[    3.372585] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    3.372588] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    3.372590] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000effff window]
[    3.372592] pci_bus 0000:00: resource 7 [mem 0xde800000-0xf7ffffff window]
[    3.372594] pci_bus 0000:00: resource 8 [mem 0x1c00000000-0x1fffffffff window]
[    3.372596] pci_bus 0000:00: resource 9 [mem 0xfd000000-0xfe7fffff window]
[    3.372599] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    3.372601] pci_bus 0000:01: resource 1 [mem 0xdeb00000-0xdebfffff]
[    3.372602] pci_bus 0000:01: resource 2 [mem 0x1c00000000-0x1c001fffff 64bit pref]
[    3.372605] pci_bus 0000:02: resource 1 [mem 0xdea00000-0xdeafffff]
[    3.372607] pci_bus 0000:03: resource 1 [mem 0xde900000-0xde9fffff]
[    3.373197] PCI: CLS 0 bytes, default 64
[    3.373260] pci 0000:00:1f.1: [8086:9d20] type 00 class 0x058000 conventional PCI endpoint
[    3.373400] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    3.373576] DMAR: ACPI device "device:6f" under DMAR at fed91000 as 00:15.0
[    3.373581] DMAR: ACPI device "device:70" under DMAR at fed91000 as 00:15.1
[    3.373594] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    3.373595] software IO TLB: mapped [mem 0x00000000d123d000-0x00000000d523d000] (64MB)
[    3.373664] Trying to unpack rootfs image as initramfs...
[    3.417349] Initialise system trusted keyrings
[    3.417359] Key type blacklist registered
[    3.417435] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    3.417946] fuse: init (API version 7.44)
[    3.418071] integrity: Platform Keyring initialized
[    3.418075] integrity: Machine keyring initialized
[    3.438323] xor: automatically using best checksumming function   avx
[    3.438329] Key type asymmetric registered
[    3.438331] Asymmetric key parser 'x509' registered
[    3.438369] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    3.438462] io scheduler mq-deadline registered
[    3.438467] io scheduler kyber registered
[    3.438493] io scheduler bfq registered
[    3.441251] ledtrig-cpu: registered to indicate activity on CPUs
[    3.441575] pcieport 0000:00:1c.0: PME: Signaling with IRQ 120
[    3.441684] pcieport 0000:00:1c.0: AER: enabled with IRQ 120
[    3.441728] pcieport 0000:00:1c.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    3.442222] pcieport 0000:00:1c.3: PME: Signaling with IRQ 121
[    3.442328] pcieport 0000:00:1c.3: AER: enabled with IRQ 121
[    3.442649] pcieport 0000:00:1d.0: PME: Signaling with IRQ 122
[    3.442739] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
[    3.443213] ACPI: AC: AC Adapter [AC] (on-line)
[    3.443320] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    3.443347] ACPI: button: Sleep Button [SLPB]
[    3.443383] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[    3.443408] ACPI: button: Lid Switch [LID]
[    3.443449] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    3.443510] ACPI: button: Power Button [PWRF]
[    3.449844] thermal LNXTHERM:00: registered as thermal_zone0
[    3.449850] ACPI: thermal: Thermal Zone [CPUZ] (40 C)
[    3.454930] thermal LNXTHERM:01: registered as thermal_zone1
[    3.454937] ACPI: thermal: Thermal Zone [GFXZ] (0 C)
[    3.457814] thermal LNXTHERM:02: registered as thermal_zone2
[    3.457818] ACPI: thermal: Thermal Zone [EXTZ] (34 C)
[    3.460689] thermal LNXTHERM:03: registered as thermal_zone3
[    3.460694] ACPI: thermal: Thermal Zone [LOCZ] (27 C)
[    3.465604] thermal LNXTHERM:04: registered as thermal_zone4
[    3.465610] ACPI: thermal: Thermal Zone [BATZ] (26 C)
[    3.465672] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20250404/exoparg2-393)
[    3.465689] ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
[    3.465701] ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
[    3.466644] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20250404/exoparg2-393)
[    3.466661] ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
[    3.466673] ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20250404/psparse-529)
[    3.467575] ACPI: thermal: [Firmware Bug]: No valid trip points!
[    3.468504] thermal LNXTHERM:05: registered as thermal_zone5
[    3.468508] ACPI: thermal: Thermal Zone [CHGZ] (32 C)
[    3.471428] thermal LNXTHERM:06: registered as thermal_zone6
[    3.471432] ACPI: thermal: Thermal Zone [PCHZ] (0 C)
[    3.471834] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.475571] hpet_acpi_add: no address or irqs in _CRS
[    3.475646] Non-volatile memory driver v1.3
[    3.475649] Linux agpgart interface v0.103
[    3.479943] tpm_tis MSFT0101:00: 2.0 TPM (device-id 0x1B, rev-id 16)
[    3.483521] ACPI: battery: Slot [BAT0] (battery present)
[    3.608373] Freeing initrd memory: 35500K
[    3.713003] ACPI: bus type drm_connector registered
[    3.724265] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    3.724271] ahci 0000:00:17.0: 1/1 ports implemented (port mask 0x1)
[    3.724273] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    3.724754] scsi host0: ahci
[    3.724815] ata1: SATA max UDMA/133 abar m2048@0xdec36000 port 0xdec36100 irq 123 lpm-pol 3
[    3.725080] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.725088] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    3.726171] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    3.726671] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.726675] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    3.726679] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    3.726725] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    3.726729] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.726731] usb usb1: Product: xHCI Host Controller
[    3.726733] usb usb1: Manufacturer: Linux 6.16.8-arch3-1 xhci-hcd
[    3.726735] usb usb1: SerialNumber: 0000:00:14.0
[    3.726992] hub 1-0:1.0: USB hub found
[    3.727011] hub 1-0:1.0: 12 ports detected
[    3.728203] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.16
[    3.728207] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.728210] usb usb2: Product: xHCI Host Controller
[    3.728212] usb usb2: Manufacturer: Linux 6.16.8-arch3-1 xhci-hcd
[    3.728214] usb usb2: SerialNumber: 0000:00:14.0
[    3.728405] hub 2-0:1.0: USB hub found
[    3.728418] hub 2-0:1.0: 6 ports detected
[    3.728906] usb: port power management may be unreliable
[    3.729336] usbcore: registered new interface driver usbserial_generic
[    3.729343] usbserial: USB Serial support registered for generic
[    3.729385] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    3.730648] i8042: Detected active multiplexing controller, rev 1.1
[    3.730934] serio: i8042 KBD port at 0x60,0x64 irq 1
[    3.730972] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[    3.730997] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[    3.731021] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[    3.731043] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[    3.731233] rtc_cmos 00:03: RTC can wake from S4
[    3.731994] rtc_cmos 00:03: registered as rtc0
[    3.732148] rtc_cmos 00:03: setting system clock to 2025-09-29T19:09:19 UTC (1759172959)
[    3.732180] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    3.732380] intel_pstate: Intel P-state driver initializing
[    3.732620] intel_pstate: HWP enabled
[    3.732900] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    3.732902] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    3.734003] fbcon: Deferring console take-over
[    3.734008] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    3.734087] hid: raw HID events driver (C) Jiri Kosina
[    3.734116] usbcore: registered new interface driver usbhid
[    3.734118] usbhid: USB HID core driver
[    3.734184] drop_monitor: Initializing network drop monitor service
[    3.734297] NET: Registered PF_INET6 protocol family
[    3.741046] Segment Routing with IPv6
[    3.741049] RPL Segment Routing with IPv6
[    3.741063] In-situ OAM (IOAM) with IPv6
[    3.741107] NET: Registered PF_PACKET protocol family
[    3.741393] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    3.741433] microcode: Current revision: 0x000000f6
[    3.741436] microcode: Updated early from: 0x00000084
[    3.741512] IPI shorthand broadcast: enabled
[    3.743932] sched_clock: Marking stable (3737001278, 6227404)->(3823375826, -80147144)
[    3.744076] registered taskstats version 1
[    3.744364] Loading compiled-in X.509 certificates
[    3.747226] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    3.750834] Loaded X.509 cert 'Build time autogenerated kernel key: 7d8148e314c8603e91d6c5edfc705ff0faf765b3'
[    3.753772] zswap: loaded using pool zstd/zsmalloc
[    3.753831] Demotion targets for Node 0: null
[    3.754060] Key type .fscrypt registered
[    3.754062] Key type fscrypt-provisioning registered
[    3.754748] Btrfs loaded, zoned=yes, fsverity=yes
[    3.754793] Key type big_key registered
[    3.755357] integrity: Loading X.509 certificate: UEFI:db
[    3.755392] integrity: Loaded X.509 cert 'Hewlett-Packard Company: HP UEFI Secure Boot 2013 DB key: 1d7cf2c2b92673f69c8ee1ec7063967ab9b62bec'
[    3.755393] integrity: Loading X.509 certificate: UEFI:db
[    3.755409] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    3.755411] integrity: Loading X.509 certificate: UEFI:db
[    3.755424] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    3.757046] PM:   Magic number: 9:830:193
[    3.757106] acpi device:1f: hash matches
[    3.758371] RAS: Correctable Errors collector initialized.
[    3.965344] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[    4.035486] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.036264] ata1.00: ACPI cmd f5/00:00:00:00:00:e0(SECURITY FREEZE LOCK) filtered out
[    4.036297] ata1.00: ATA-10: WDC WD10SPZX-22Z10T1, 04.01A04, max UDMA/133
[    4.037573] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.037589] ata1.00: Features: NCQ-prio
[    4.038580] ata1.00: ACPI cmd f5/00:00:00:00:00:e0(SECURITY FREEZE LOCK) filtered out
[    4.040079] ata1.00: configured for UDMA/133
[    4.040768] scsi 0:0:0:0: Direct-Access     ATA      WDC WD10SPZX-22Z 1A04 PQ: 0 ANSI: 5
[    4.041665] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    4.041678] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    4.041704] sd 0:0:0:0: [sda] Write Protect is off
[    4.041712] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.041745] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.041806] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    4.091112] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[    4.091129] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.091137] usb 1-1: Product: USB Receiver
[    4.091143] usb 1-1: Manufacturer: Logitech
[    4.094739] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C52B.0001/input/input8
[    4.146799] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
[    4.150098] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input9
[    4.150478] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input10
[    4.165364]  sda: sda1
[    4.165694] sd 0:0:0:0: [sda] Attached SCSI disk
[    4.165869] clk: Disabling unused clocks
[    4.165881] PM: genpd: Disabling unused power domains
[    4.170019] Freeing unused decrypted memory: 2028K
[    4.172626] Freeing unused kernel image (initmem) memory: 4664K
[    4.172882] Write protecting the kernel read-only data: 38912k
[    4.174188] Freeing unused kernel image (text/rodata gap) memory: 608K
[    4.175832] Freeing unused kernel image (rodata/data gap) memory: 1760K
[    4.201510] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input11
[    4.201778] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
[    4.203684] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-1/input2
[    4.250299] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.250304] rodata_test: all tests were successful
[    4.250305] x86/mm: Checking user space page tables
[    4.296995] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.297009] Run /init as init process
[    4.297011]   with arguments:
[    4.297012]     /init
[    4.297013]   with environment:
[    4.297014]     HOME=/
[    4.297015]     TERM=linux
[    4.297016]     BOOT_IMAGE=/@/boot/vmlinuz-linux
[    4.297017]     nvme_load=YES
[    4.316287] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[    4.379944] systemd[1]: Successfully made /usr/ read-only.
[    4.380244] systemd[1]: systemd 258-4-arch running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    4.380252] systemd[1]: Detected architecture x86-64.
[    4.380254] systemd[1]: Running in initrd.
[    4.380475] fbcon: Taking over console
[    4.381109] Console: switching to colour frame buffer device 170x48
[    4.382416] systemd[1]: Hostname set to <damien-hpelitebook840g4>.
[    4.405244] tsc: Refined TSC clocksource calibration: 2711.999 MHz
[    4.405254] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x271785701be, max_idle_ns: 440795203568 ns
[    4.405273] clocksource: Switched to clocksource tsc
[    4.441272] usb 1-7: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.10
[    4.441278] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.554407] usb 1-9: new high-speed USB device number 4 using xhci_hcd
[    4.625849] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    4.638574] systemd-hibernate-resume-generator[108]: Reported hibernation image: ID=endeavouros kernel=6.16.8-arch3-1 UUID=5eb74a6a-4a06-4958-85e7-9e928022b067 offset=0
[    4.685845] systemd[1]: Queued start job for default target Initrd Default Target.
[    4.699528] systemd[1]: Created slice Slice /system/systemd-cryptsetup.
[    4.699637] usb 1-9: New USB device found, idVendor=05c8, idProduct=0397, bcdDevice= 1.05
[    4.699641] usb 1-9: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    4.699642] usb 1-9: Product: HP HD Camera
[    4.699643] usb 1-9: Manufacturer: Generic
[    4.699645] usb 1-9: SerialNumber: 200901010001
[    4.699946] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.700057] systemd[1]: Expecting device /dev/disk/by-uuid/ad68e6c7-3abb-4416-9ab0-58584685c6bf...
[    4.700113] systemd[1]: Expecting device /dev/disk/by-uuid/b9d16654-2455-4124-811a-8bfb86e271ab...
[    4.700163] systemd[1]: Expecting device /dev/disk/by-uuid/d9caec7b-56db-4947-9510-241a64e358a2...
[    4.700207] systemd[1]: Expecting device /dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2...
[    4.700276] systemd[1]: Reached target Initrd /usr File System.
[    4.700323] systemd[1]: Reached target Path Units.
[    4.700371] systemd[1]: Reached target Slice Units.
[    4.700419] systemd[1]: Reached target Swaps.
[    4.700461] systemd[1]: Reached target Timer Units.
[    4.700594] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.700727] systemd[1]: Listening on Journal Sockets.
[    4.700835] systemd[1]: Listening on udev Control Socket.
[    4.700917] systemd[1]: Listening on udev Kernel Socket.
[    4.700966] systemd[1]: Reached target Socket Units.
[    4.702119] systemd[1]: Starting Create List of Static Device Nodes...
[    4.703382] systemd[1]: Starting Check battery level during early boot...
[    4.705943] systemd[1]: Starting Journal Service...
[    4.707411] systemd[1]: Starting Load Kernel Modules...
[    4.710198] systemd[1]: TPM PCR Barrier (initrd) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    4.711271] systemd[1]: Starting Virtual Console Setup...
[    4.713419] systemd[1]: Finished Create List of Static Device Nodes.
[    4.716393] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    4.725308] systemd[1]: Finished Check battery level during early boot.
[    4.732625] Asymmetric key parser 'pkcs8' registered
[    4.735544] systemd[1]: Finished Virtual Console Setup.
[    4.738010] systemd-journald[140]: Collecting audit messages is disabled.
[    4.738498] systemd[1]: Starting dracut ask for additional cmdline parameters...
[    4.740441] systemd[1]: Finished Load Kernel Modules.
[    4.742503] systemd[1]: Starting Apply Kernel Variables...
[    4.758555] systemd[1]: Finished Apply Kernel Variables.
[    4.761450] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    4.762980] systemd[1]: Starting Create Static Device Nodes in /dev...
[    4.777444] systemd[1]: Finished dracut ask for additional cmdline parameters.
[    4.778928] systemd[1]: Starting dracut cmdline hook...
[    4.798686] systemd[1]: Finished Create Static Device Nodes in /dev.
[    4.808526] systemd[1]: Started Journal Service.
[    4.949732] device-mapper: uevent: version 1.0.3
[    4.949805] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    5.453316] systemd-hibernate-resume-generator[417]: Reported hibernation image: ID=endeavouros kernel=6.16.8-arch3-1 UUID=5eb74a6a-4a06-4958-85e7-9e928022b067 offset=0
[    5.561876] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: DF4E63B6-3BBC-4858-9737-C74F82F821F3 has zero instances
[    5.561919] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 8F1F6436-9F42-42C8-BADC-0E9424F20C9A has zero instances
[    5.588394] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    5.589907] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    5.609281] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    5.609735] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    5.736540] rtsx_pci 0000:01:00.0: enabling device (0000 -> 0002)
[    5.745083] Key type psk registered
[    5.766867] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-1/input2
[    5.813821] nvme nvme0: pci function 0000:03:00.0
[    5.827156] nvme nvme0: 4/0/0 default/read/poll queues
[    5.884219]  nvme0n1: p1 p2 p3
[    5.890663] input: Logitech Wireless Device PID:4051 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4051.0004/input/input15
[    5.894504] hid-generic 0003:046D:4051.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Device PID:4051] on usb-0000:00:14.0-1/input2:1
[    5.908149] pcieport 0000:00:1c.0: pciehp: Slot(1): Card not present
[    5.997563] input: Logitech M510 as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4051.0004/input/input19
[    5.999025] logitech-hidpp-device 0003:046D:4051.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M510] on usb-0000:00:14.0-1/input2:1
[    6.504769] input: PS/2 Generic Mouse as /devices/platform/i8042/serio2/input/input14
[    7.142555] irq 16: nobody cared (try booting with the "irqpoll" option)
[    7.142561] CPU: 1 UID: 0 PID: 0 Comm: swapper/1 Not tainted 6.16.8-arch3-1 #1 PREEMPT(full)  c3805c1210d56bc7a68d560dd9e968bb1cc9c38e
[    7.142565] Hardware name: HP HP EliteBook 840 G4/828C, BIOS P78 Ver. 01.16 03/29/2018
[    7.142567] Call Trace:
[    7.142569]  <IRQ>
[    7.142571]  dump_stack_lvl+0x5d/0x80
[    7.142578]  __report_bad_irq+0x35/0xb5
[    7.142582]  note_interrupt.cold+0x28/0x66
[    7.142585]  handle_irq_event+0x72/0x80
[    7.142590]  handle_fasteoi_irq+0x7b/0x220
[    7.142593]  __common_interrupt+0x3e/0xa0
[    7.142597]  common_interrupt+0x80/0xa0
[    7.142602]  </IRQ>
[    7.142603]  <TASK>
[    7.142604]  asm_common_interrupt+0x26/0x40
[    7.142607] RIP: 0010:cpuidle_enter_state+0xbb/0x410
[    7.142611] Code: 00 00 e8 a8 46 09 ff e8 b3 f2 ff ff 48 89 c5 0f 1f 44 00 00 31 ff e8 94 bf 07 ff 45 84 ff 0f 85 33 02 00 00 fb 0f 1f 44 00 00 <45> 85 f6 0f 88 7c 01 00 00 49 63 ce 48 2b 2c 24 48 6b d1 68 48 89
[    7.142613] RSP: 0000:ffffcf12c0127e78 EFLAGS: 00000246
[    7.142616] RAX: ffff8dbbff59a000 RBX: 0000000000000001 RCX: 0000000000000000
[    7.142618] RDX: 00000001a9ba9773 RSI: fffffff8890c6bc2 RDI: 0000000000000000
[    7.142619] RBP: 00000001a9ba9773 R08: 0000000000000002 R09: 0000000000000000
[    7.142621] R10: 00000000ffffffff R11: ffffffffffffffff R12: ffff8dbb8f4b9c80
[    7.142622] R13: ffffffff8f3ef740 R14: 0000000000000001 R15: 0000000000000000
[    7.142627]  ? cpuidle_enter_state+0xac/0x410
[    7.142631]  cpuidle_enter+0x31/0x50
[    7.142635]  do_idle+0x1b1/0x210
[    7.142641]  cpu_startup_entry+0x29/0x30
[    7.142644]  start_secondary+0x119/0x140
[    7.142648]  common_startup_64+0x13e/0x141
[    7.142654]  </TASK>
[    7.142655] handlers:
[    7.142662] [<00000000eaa498b8>] idma64_irq [idma64]
[    7.142669] [<00000000236431f9>] i2c_dw_isr
[    7.142673] Disabling IRQ #16
[    7.231585] psmouse serio3: synaptics: queried max coordinates: x [..5670], y [..4758]
[    7.260788] psmouse serio3: synaptics: queried min coordinates: x [1360..], y [1198..]
[    7.260810] psmouse serio3: synaptics: Trying to set up SMBus access
[    7.263212] psmouse serio3: synaptics: SMbus companion is not ready yet
[    7.314813] psmouse serio3: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2b1, caps: 0xf00123/0x840300/0x2e800/0x0, board id: 3139, fw id: 2000742
[    7.348174] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio3/input/input20
[    9.818568] Key type trusted registered
[    9.822673] Key type encrypted registered
[    9.865567] PM: Image signature found, resuming
[    9.865579] PM: hibernation: resume from hibernation
[    9.865593] random: crng reseeded on system resumption
[    9.865758] Freezing user space processes
[    9.866894] Freezing user space processes completed (elapsed 0.001 seconds)
[    9.866897] OOM killer disabled.
[    9.866898] Freezing remaining freezable tasks
[   29.869364] Freezing remaining freezable tasks failed after 20.002 seconds (0 tasks refusing to freeze, wq_busy=1):
[   29.869388] Showing freezable workqueues that are still busy:
[   29.869394] workqueue events_freezable: flags=0x4
[   29.869402]   pwq 10: cpus=2 node=0 flags=0x0 nice=0 active=1 refcnt=3
[   29.869423]     in-flight: 57:mmc_rescan [mmc_core] BAR(70)
[   29.869590] Restarting kernel threads ...
[   29.869682] Done restarting kernel threads.
[   29.870014] OOM killer enabled.
[   29.870029] Restarting tasks: Starting
[   29.872846] Restarting tasks: Done
[   29.872897] PM: hibernation: resume failed (-16)
[   30.580718] BTRFS: device label Root devid 1 transid 5156 /dev/mapper/luks-b9d16654-2455-4124-811a-8bfb86e271ab (253:1) scanned by mount (615)
[   30.581173] BTRFS info (device dm-1): first mount of filesystem ad68e6c7-3abb-4416-9ab0-58584685c6bf
[   30.581190] BTRFS info (device dm-1): using crc32c (crc32c-x86) checksum algorithm
[   30.588129] BTRFS info (device dm-1): enabling ssd optimizations
[   30.588136] BTRFS info (device dm-1): enabling free space tree
[   30.887601] systemd-journald[140]: Received SIGTERM from PID 1 (systemd).
[   30.998460] systemd[1]: systemd 258-4-arch running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[   30.998468] systemd[1]: Detected architecture x86-64.
[   31.274611] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[   31.502395] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[   31.502554] systemd[1]: Stopped Switch Root.
[   31.504902] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[   31.505474] systemd[1]: Created slice Slice /system/dirmngr.
[   31.507276] systemd[1]: Created slice Slice /system/getty.
[   31.508578] systemd[1]: Created slice Slice /system/gpg-agent.
[   31.509179] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[   31.510409] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[   31.511179] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[   31.511938] systemd[1]: Created slice Slice /system/keyboxd.
[   31.513224] systemd[1]: Created slice Slice /system/systemd-fsck.
[   31.514871] systemd[1]: Created slice User and Session Slice.
[   31.515598] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   31.515879] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   31.516324] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   31.516582] systemd[1]: Expecting device /dev/disk/by-uuid/223C-C2E7...
[   31.516798] systemd[1]: Expecting device /dev/disk/by-uuid/28bda2a6-454a-463e-9ff4-1bf750f2c495...
[   31.517015] systemd[1]: Expecting device /dev/mapper/luks-28bda2a6-454a-463e-9ff4-1bf750f2c495...
[   31.517255] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-b9d16654-2455-4124-811a-8bfb86e271ab.
[   31.517495] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2.
[   31.517754] systemd[1]: Reached target Login Prompts.
[   31.517978] systemd[1]: Reached target Image Downloads.
[   31.518202] systemd[1]: Stopped target Switch Root.
[   31.518621] systemd[1]: Stopped target Initrd File Systems.
[   31.518989] systemd[1]: Stopped target Initrd Root File System.
[   31.519390] systemd[1]: Reached target Local Integrity Protected Volumes.
[   31.519804] systemd[1]: Reached target Path Units.
[   31.520196] systemd[1]: Reached target Remote File Systems.
[   31.520568] systemd[1]: Reached target Slice Units.
[   31.520997] systemd[1]: Reached target Local Verity Protected Volumes.
[   31.521581] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   31.522152] systemd[1]: Listening on LVM2 poll daemon socket.
[   31.523960] systemd[1]: Listening on Query the User Interactively for a Password.
[   31.525974] systemd[1]: Listening on Process Core Dump Socket.
[   31.527560] systemd[1]: Listening on Credential Encryption/Decryption.
[   31.528690] systemd[1]: Listening on Factory Reset Management.
[   31.529705] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   31.529739] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   31.529885] systemd[1]: Listening on udev Control Socket.
[   31.530371] systemd[1]: Listening on udev Varlink Socket.
[   31.530812] systemd[1]: Listening on User Database Manager Socket.
[   31.532904] systemd[1]: Activating swap /dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2...
[   31.534218] systemd[1]: Mounting Huge Pages File System...
[   31.536110] systemd[1]: Mounting POSIX Message Queue File System...
[   31.539473] systemd[1]: Mounting Kernel Debug File System...
[   31.546410] systemd[1]: Mounting Kernel Trace File System...
[   31.551041] systemd[1]: Starting Create List of Static Device Nodes...
[   31.551937] Adding 20969468k swap on /dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2.  Priority:-2 extents:1 across:20969468k SS
[   31.553983] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   31.554513] systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!configfs).
[   31.554598] systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
[   31.554673] systemd[1]: Load Kernel Module drm was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!drm).
[   31.554726] systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!fuse).
[   31.556769] systemd[1]: Mounting FUSE Control File System...
[   31.560893] systemd[1]: Starting Load Kernel Module loop...
[   31.563287] systemd[1]: systemd-fsck-root.service: Deactivated successfully.
[   31.563367] systemd[1]: Stopped File System Check on Root Device.
[   31.565177] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[   31.568066] systemd[1]: Starting Journal Service...
[   31.574167] systemd[1]: Starting Load Kernel Modules...
[   31.576301] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   31.577874] systemd[1]: Starting Remount Root and Kernel File Systems...
[   31.580328] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   31.581776] systemd[1]: Starting Load udev Rules from Credentials...
[   31.588831] systemd[1]: Starting Coldplug All udev Devices...
[   31.589276] loop: module loaded
[   31.601312] BTRFS info (device dm-1 state M): use zstd compression, level 3
[   31.604246] systemd[1]: Activated swap /dev/mapper/luks-d9caec7b-56db-4947-9510-241a64e358a2.
[   31.607934] systemd-journald[690]: Collecting audit messages is disabled.
[   31.610370] systemd[1]: Mounted Huge Pages File System.
[   31.611656] systemd[1]: Started Journal Service.
[   32.268513] mousedev: PS/2 mouse device common for all mice
[   32.411757] input: Wireless hotkeys as /devices/virtual/input/input22
[   32.418654] hp_accel: hardware type HPB64xx found
[   32.527095] lis3lv02d: 8 bits 3DC sensor found
[   32.584807] systemd-journald[690]: Received client request to flush runtime journal.
[   32.586349] nfc: nfc_init: NFC Core ver 0.1
[   32.586391] NET: Registered PF_NFC protocol family
[   32.587918] systemd-journald[690]: File /var/log/journal/540b16d69e1d40a9bb7c073dcf48365d/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   32.677537] mc: Linux media interface: v0.10
[   32.679358] input: ST LIS3LV02DL Accelerometer as /devices/faux/lis3lv02d/input/input23
[   32.693904] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   32.783711] Bluetooth: Core ver 2.22
[   32.783737] NET: Registered PF_BLUETOOTH protocol family
[   32.783740] Bluetooth: HCI device and connection manager initialized
[   32.783745] Bluetooth: HCI socket layer initialized
[   32.783748] Bluetooth: L2CAP socket layer initialized
[   32.783752] Bluetooth: SCO socket layer initialized
[   32.786329] videodev: Linux video capture interface: v2.00
[   32.798143] pps_core: LinuxPPS API ver. 1 registered
[   32.798148] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   32.860404] input: PC Speaker as /devices/platform/pcspkr/input/input24
[   32.876635] PTP clock support registered
[   32.886502] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   32.904549] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   32.904792] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   32.905559] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   32.905569] cfg80211: failed to load regulatory.db
[   32.921604] e1000e: Intel(R) PRO/1000 Network Driver
[   32.921608] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   32.921645] e1000e 0000:00:1f.6: enabling device (0000 -> 0002)
[   32.922954] i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
[   32.924859] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[   32.924869] i801_smbus 0000:00:1f.4: An interrupt is pending!
[   32.924876] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[   32.926077] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000024be98f9 (20250404/exresop-557)
[   32.926086] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20250404/dswexec-433)
[   32.926173] ACPI Error: Aborting method \_SB.WMIV.WVPO due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.927856] ACPI Error: Aborting method \_SB.WMIV.WMPV due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.928419] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[   32.933365] ACPI Error: Needed [Buffer/String/Package], found [Integer] 000000000033310f (20250404/exresop-557)
[   32.933375] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20250404/dswexec-433)
[   32.933384] ACPI Error: Aborting method \_SB.WMIV.WVPO due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.933394] ACPI Error: Aborting method \_SB.WMIV.WMPV due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.938206] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000051ded97a (20250404/exresop-557)
[   32.938216] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20250404/dswexec-433)
[   32.938225] ACPI Error: Aborting method \_SB.WMIV.WVPO
[   32.938295] i2c i2c-2: Successfully instantiated SPD at 0x50
[   32.940383]  due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.940396] ACPI Error: Aborting method \_SB.WMIV.WMPV due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.940484] input: HP WMI hotkeys as /devices/virtual/input/input25
[   32.963812] ACPI Error: Needed [Buffer/String/Package], found [Integer] 00000000ffc58f0f (20250404/exresop-557)
[   32.963822] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20250404/dswexec-433)
[   32.963832] ACPI Error: Aborting method \_SB.WMIV.WVPO due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   32.963842] ACPI Error: Aborting method \_SB.WMIV.WMPV due to previous error (AE_AML_OPERAND_TYPE) (20250404/psparse-529)
[   33.014860] Intel(R) Wireless WiFi driver for Linux
[   33.014955] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[   33.016886] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[   33.016889] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   33.016891] RAPL PMU: hw unit of domain package 2^-14 Joules
[   33.016893] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   33.018347] iwlwifi 0000:02:00.0: Detected crf-id 0xbadcafe, cnv-id 0x10 wfpm id 0x80000000
[   33.018367] iwlwifi 0000:02:00.0: PCI dev 24fd/1010, rev=0x230, rfid=0xd55555d5
[   33.018372] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless-AC 8265
[   33.048927] iwlwifi 0000:02:00.0: loaded firmware version 36.c8e8e144.0 8265-36.ucode op_mode iwlmvm
[   33.140578] usb 1-9: Found UVC 1.00 device HP HD Camera (05c8:0397)
[   33.163899] usbcore: registered new interface driver uvcvideo
[   33.186666] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[   33.288560] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 10:62:e5:55:07:1f
[   33.289069] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[   33.289124] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[   33.707944] psmouse serio3: synaptics: queried max coordinates: x [..5670], y [..4758]
[   33.737242] psmouse serio3: synaptics: queried min coordinates: x [1360..], y [1198..]
[   33.737251] psmouse serio3: synaptics: Trying to set up SMBus access
[   33.902775] usbcore: registered new interface driver btusb
[   33.904492] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[   33.905500] Bluetooth: hci0: Device revision is 16
[   33.905510] Bluetooth: hci0: Secure boot is enabled
[   33.905513] Bluetooth: hci0: OTP lock is enabled
[   33.905514] Bluetooth: hci0: API lock is enabled
[   33.905516] Bluetooth: hci0: Debug lock is disabled
[   33.905517] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   33.910190] iTCO_vendor_support: vendor-support=0
[   33.915502] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[   33.919280] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[   33.942082] i915 0000:00:02.0: [drm] Found kabylake/ult (device ID 5916) integrated display version 9.00 stepping B0
[   33.955068] ee1004 2-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[   34.031330] Console: switching to colour dummy device 80x25
[   34.041367] i915 0000:00:02.0: vgaarb: deactivate vga console
[   34.050290] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   34.052211] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[   34.055751] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[   34.058254] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   34.077382] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   34.097880] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[   34.098427] iwlwifi 0000:02:00.0: base HW address: 94:b8:6d:69:bc:fc, OTP minor version: 0x4
[   34.118672] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
[   34.123831] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   34.124199] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input28
[   34.126281] intel_tcc_cooling: Programmable TCC Offset detected
[   34.134715] rmi4_smbus 2-002c: registering SMbus-connected sensor
[   34.165426] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
[   34.180315] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   34.193422] intel_pmc_core intel_pmc_core.0:  initialized
[   34.211528] fbcon: i915drmfb (fb0) is primary device
[   34.211617] Console: switching to colour frame buffer device 170x48
[   34.211663] snd_hda_codec_conexant hdaudioC0D0: CX8200: BIOS auto-probing.
[   34.212102] snd_hda_codec_conexant hdaudioC0D0: CX8200: picked fixup  for PCI SSID 103c:828c
[   34.212782] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[   34.214078] snd_hda_codec_conexant hdaudioC0D0: vmaster hook already present before cdev!
[   34.214468] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX8200: line_outs=1 (0x16/0x0/0x0/0x0/0x0) type:line
[   34.214475] snd_hda_codec_conexant hdaudioC0D0:    speaker_outs=1 (0x17/0x0/0x0/0x0/0x0)
[   34.214479] snd_hda_codec_conexant hdaudioC0D0:    hp_outs=1 (0x1d/0x0/0x0/0x0/0x0)
[   34.214482] snd_hda_codec_conexant hdaudioC0D0:    mono: mono_out=0x0
[   34.214485] snd_hda_codec_conexant hdaudioC0D0:    inputs:
[   34.214487] snd_hda_codec_conexant hdaudioC0D0:      Mic=0x19
[   34.214490] snd_hda_codec_conexant hdaudioC0D0:      Internal Mic=0x1a
[   34.214492] snd_hda_codec_conexant hdaudioC0D0:      Line=0x18
[   34.234980] rmi4_f01 rmi4-00.fn01: found RMI device, manufacturer: Synaptics, product: TM3139-001, fw id: 2000742
[   34.271357] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[   34.271437] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[   34.271502] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[   34.271562] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[   34.271621] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input34
[   34.271681] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input35
[   34.271739] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input36
[   34.283157] intel_rapl_common: Found RAPL domain package
[   34.283161] intel_rapl_common: Found RAPL domain core
[   34.283163] intel_rapl_common: Found RAPL domain uncore
[   34.308950] input: Synaptics TM3139-001 as /devices/pci0000:00/0000:00:1f.4/i2c-2/2-002c/rmi4-00/input/input29
[   35.350599] Bluetooth: hci0: Waiting for firmware download to complete
[   35.351469] Bluetooth: hci0: Firmware loaded in 1398616 usecs
[   35.351500] Bluetooth: hci0: Waiting for device to boot
[   35.363478] Bluetooth: hci0: Device booted in 11709 usecs
[   35.363559] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[   35.366559] Bluetooth: hci0: Applying Intel DDC parameters completed
[   35.367510] Bluetooth: hci0: Firmware revision 0.1 build 19 week 44 2021
[   35.369475] Bluetooth: hci0: Reading supported features failed (-16)
[   35.369478] Bluetooth: hci0: Error reading debug features
[   35.369483] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[   37.125417] BTRFS: device label Home devid 1 transid 9092 /dev/mapper/luks-28bda2a6-454a-463e-9ff4-1bf750f2c495 (253:2) scanned by mount (881)
[   37.126032] BTRFS info (device dm-2): first mount of filesystem b5ff56dc-ec56-47da-b2b2-867895d92020
[   37.126047] BTRFS info (device dm-2): using crc32c (crc32c-x86) checksum algorithm
[   38.112073] BTRFS info (device dm-2): checking UUID tree
[   38.112149] BTRFS info (device dm-2): enabling free space tree
[   38.112151] BTRFS info (device dm-2): use zstd compression, level 3
[   38.457610] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   38.457614] Bluetooth: BNEP filters: protocol multicast
[   38.457619] Bluetooth: BNEP socket layer initialized
[   38.459537] Bluetooth: MGMT ver 1.23
[   38.479457] NET: Registered PF_ALG protocol family
[   39.247579] input: evremap Virtual input for /dev/input/event3 as /devices/virtual/input/input37
[   39.803462] iwlwifi 0000:02:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[   43.168661] wlan0: authenticate with b0:0a:d5:64:8a:c0 (local address=94:b8:6d:69:bc:fc)
[   43.169951] wlan0: send auth to b0:0a:d5:64:8a:c0 (try 1/3)
[   43.179304] wlan0: authenticated
[   43.181249] wlan0: associate with b0:0a:d5:64:8a:c0 (try 1/3)
[   43.199878] wlan0: RX AssocResp from b0:0a:d5:64:8a:c0 (capab=0x1431 status=0 aid=23)
[   43.203760] wlan0: associated
[   43.256451] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by b0:0a:d5:64:8a:c0
[   54.492151] systemd-journald[690]: File /var/log/journal/540b16d69e1d40a9bb7c073dcf48365d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   56.703899] Bluetooth: RFCOMM TTY layer initialized
[   56.703910] Bluetooth: RFCOMM socket layer initialized
[   56.703915] Bluetooth: RFCOMM ver 1.11
[   56.905316] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   59.288941] input: Huion Tablet as /devices/virtual/misc/uhid/0003:256C:FFFF.0005/input/input38
[   59.289068] hid-generic 0003:256C:FFFF.0005: input,hidraw2: USB HID v0.00 Device [Huion Tablet] on
[   59.289607] input: Huion Tablet as /devices/virtual/misc/uhid/0003:256C:FFFF.0006/input/input39
[   59.289715] hid-generic 0003:256C:FFFF.0006: input,hidraw3: USB HID v0.00 Device [Huion Tablet] on
[   59.290463] input: HUION 256C PEN STYLUS as /devices/virtual/input/input40
[   59.294156] input: Huion keyboard as /devices/virtual/input/input41
[   59.300410] input: Huion Mouse as /devices/virtual/input/input42
[   59.333511] input: HUION 256C PEN STYLUS as /devices/virtual/input/input43
[   62.168686] input: HUION 256C PEN STYLUS as /devices/virtual/input/input44
[   79.259893] pcieport 0000:00:1c.0: pciehp: Slot(1): Card present
[   79.259905] pcieport 0000:00:1c.0: pciehp: Slot(1): Link Up
[   79.382256] pci 0000:01:00.0: [10ec:522a] type 00 class 0xff0000 PCIe Endpoint
[   79.382318] pci 0000:01:00.0: BAR 0 [mem 0xdeb00000-0xdeb00fff]
[   79.382437] pci 0000:01:00.0: supports D1 D2
[   79.382439] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[   79.382803] pci 0000:01:00.0: BAR 0 [mem 0xdeb00000-0xdeb00fff]: assigned
[   79.382816] pcieport 0000:00:1c.0: PCI bridge to [bus 01]
[   79.382822] pcieport 0000:00:1c.0:   bridge window [io  0x4000-0x4fff]
[   79.382830] pcieport 0000:00:1c.0:   bridge window [mem 0xdeb00000-0xdebfffff]
[   79.382836] pcieport 0000:00:1c.0:   bridge window [mem 0x1c00000000-0x1c001fffff 64bit pref]
[  769.729957] logitech-hidpp-device 0003:046D:4051.0004: HID++ 4.5 device connected.
[  796.093713] nvme nvme0: using unchecked data buffer
[ 4038.412471] iwlwifi 0000:02:00.0: missed beacons exceeds threshold, but receiving data. Stay connected, Expect bugs.
[ 4038.412485] iwlwifi 0000:02:00.0: missed_beacons:19, missed_beacons_since_rx:2
[ 4038.514627] iwlwifi 0000:02:00.0: missed beacons exceeds threshold, but receiving data. Stay connected, Expect bugs.
[ 4038.514645] iwlwifi 0000:02:00.0: missed_beacons:20, missed_beacons_since_rx:3
[ 4038.617017] wlan0: Connection to AP b0:0a:d5:64:8a:c0 lost
[ 4047.142336] wlan0: authenticate with b0:0a:d5:64:8a:c0 (local address=94:b8:6d:69:bc:fc)
[ 4047.143618] wlan0: send auth to b0:0a:d5:64:8a:c0 (try 1/3)
[ 4047.147438] wlan0: authenticated
[ 4047.149178] wlan0: associate with b0:0a:d5:64:8a:c0 (try 1/3)
[ 4047.178605] wlan0: RX AssocResp from b0:0a:d5:64:8a:c0 (capab=0x1431 status=0 aid=24)
[ 4047.180847] wlan0: associated
[ 4047.206963] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by b0:0a:d5:64:8a:c0
In a previous attempt to fix this I followed this post and ran echo 'install_items+=" /usr/lib/systemd/system/systemd-hibernate-resume.service ' | tee -a /etc/dracut.conf.d/resume.conf; sudo dracut-rebuild
This is my first post to this forum and my first Arch-based install so lmk if I’m missing anything.
Thanks All!
