Hi Plasma users!
I am just getting my feet wet using KDE, but perhaps many of you will be excited over the news (that is if it is news to you):
Looks like 5.19.5-1 is already hitting the repos.
I see the updates, but will wait until after work to install just in case.
Edit: So far, so good!
Yeah, I just got it. Everything seems to work, but I haven’t had time to explore.
Yup, mine is downloading the updates as I type…
The updates went well on my end. So far everything seems to be working.
Half a day in, no problems so far…
I haven’t noticed anything odd. The only issue I am seeing (and this existed prior to this update) is themes not applying correctly to apps like timeshift and gparted.
updated, everything went fine.
