Brtza
October 31, 2021, 11:42am
#1
Hi,
I installed new installation but with btrfs.
As I can see, I dont have swap file or swap partition.
I want swap file , but I also saw somewhere that I need swapfile on separate subvolume * which is not included in snapshots.
I am reading Arch wiki, but I am not sure how to do it.
I dont how which path is for subvolume etc…
Little help please xD
Thanks
pebcak
October 31, 2021, 12:08pm
#2
Try this:
1. sudo btrfs subvolume create @swap
2. sudo mkdir /swap
3. sudo mount -o subvol=@swap /dev/XXX /swap ## replace XXX with your actual partition for example sda2, nvme0n1p2
4. cd /swap
5. sudo truncate -s 0 swapfile
6. sudo chattr +C swapfile
7. sudo btrfs property set swapfile compression none
8. sudo dd if=/dev/zero of=swapfile bs=1M count=512 status=progress
9. sudo chmod 600 swapfile
10. sudo mkswap swapfile
11. sudo swapon swapfile
12. Now Edit the /etc/fstab and add the following two lines:
UUID=NNNN /swap btrfs subvol=@swap ## replace NNNN with the UUID of the partition where @swap resides
/swap/swapfile none swap defaults 0 0
Brtza
October 31, 2021, 12:11pm
#3
This is what I have for now
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot
└─nvme0n1p2 259:2 0 476.4G 0 part /
Brtza
October 31, 2021, 12:12pm
#4
I dont know what I did and where are others subvolumes , like home,var etc
pebcak
October 31, 2021, 12:14pm
#5
You can list them with:
sudo btrfs subvolume list /
Brtza
October 31, 2021, 12:15pm
#6
ID 259 gen 15 top level 5 path var/lib/portables
ID 260 gen 16 top level 5 path var/lib/machines
I screwed something right
Brtza
October 31, 2021, 12:17pm
#8
lsblk -fs
[marko@marko ~]$ lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1p1 vfat FAT32 1D05-8F9F 412.1M 19% /boot
└─nvme0n1
nvme0n1p2 btrfs 3148ec9f-34e6-421b-81ff-142263a3a76c 460.6G 3% /
└─nvme0n1
cat /etc/fstab
[marko@marko ~]$ cat /etc/fstab
# Static information about the filesystems.
# See fstab(5) for details.
# <file system> <dir> <type> <options> <dump> <pass>
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
# /dev/nvme0n1p2
UUID=3148ec9f-34e6-421b-81ff-142263a3a76c / btrfs rw,relatime,ssd,space_cache,subvolid=5,subvol=/ 0 0
# /dev/nvme0n1p1
UUID=1D05-8F9F /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 2
Brtza
October 31, 2021, 12:20pm
#9
Probably is best to reinstall again, maybe btrfs is not for me xD
pebcak
October 31, 2021, 12:26pm
#10
Doesn’t look quite right.
I would do an erase disk and install this time and choose swapfile already from the installer.
Brtza
#11
Sure, I will try… Thanks btw
Imho don’t bother with making swap work within btrfs. Just create a normal swap partition and keep the two separated. Makes life easier in the long run.
