Looks like everything worked properly. All drives mounted and Timeshift is acting normally. Thanks again!
Noted the bit about sudo mount -a
Now to reroute my Steam library…
Yeah, we’re professionals.
Note that it is a bad practice to use mount -a for fstab checking. The recommended solution is
findmnt --verify
.(c)
man mount
Could you please elaborate?
I’ve quoted directly:
Read in -a
description
Didn’t find anything about “bad practice” ?
-a, --all
Mount all filesystems (of the given types) mentioned in fstab (except for those whose line contains the noauto keyword). The filesystems are
mounted following their order in fstab. The mount command compares filesystem source, target (and fs root for bind mount or btrfs) to detect
already mounted filesystems. The kernel table with already mounted filesystems is cached during mount --all. This means that all duplicated
fstab entries will be mounted.
The option --all is possible to use for remount operation too. In this case all filters (-t and -O) are applied to the table of already
Since version 2.35 is possible to use the command line option -o to alter mount options from fstab (see also --options-mode).
Note that it is a bad practice to use mount -a for fstab checking. The recommended solution is findmnt --verify.
Last one here
Today I learnt:
Right!
