Guys, i have a problem with i3wm. My xterm if white and as far as i understood it tries to render russian lang but doesnt have it.
How can i fix this? What is the easiest way to add eng and ru languages? Can u recommend me some sources to get involved into i3wm, endeavor as a total newbie?
As i3WM is not a full Desktop (Window Manager) most things will get handled systemwide over default tools.
Also default Terminal on EndeavourOS i3WM is xfce4-terminal and it should follow what you set on the installer for keymap and language. But indeed in cases it can be wrong to as of installer not always 100% correctly detects it automatically, and you may not correct that on the installer slide for keyboard and language settings.
