Help with gtk inspector needed
I would like some help with the gtk inspector and some css for customization, basically i’ve been trying to change the background color on the left side panel of evolution mail, i installed dconf editor and launched evolution with this comand:
GTK_DEBUG=interactive evolution
It says the class is “EMailSidebar” or id, but whenever i try to target that id on gtk.css config it seems to do nothing at all, i have the gtk.css file located on this path:
/home/ramon/.config/gtk-3.0/gtk.css
Hi, you need to use the styling class for the “EMailSidebar” control. Looking at the inspector we have EMFolderTree class there, so the only CSS you need is something like:
.EMFolderTree {
  background-color: teal;
and that produces
Sidebar style classes
thanks, i just ended using treeview instead, i liked it better since i was looking for a way to change the background left panel color on gthumb image viewer as well, here’s the code i used:
treeview { background-color: #d7dce1 };
treeview*:focused { background:#3770a6 linear-gradient(0deg,rgba(33, 56, 90, 1) 4%, rgba(55, 92, 143, 1) 3%, rgba(119, 153, 202, 1) 92%, rgba(163, 195, 239, 1) 94%, rgba(54, 69, 89, 0.85) 97%);  color:white; }
treeview*:selected { background:#3770a6 linear-gradient(0deg,rgba(33, 56, 90, 1) 4%, rgba(55, 92, 143, 1) 3%, rgba(119, 153, 202, 1) 92%, rgba(163, 195, 239, 1) 94%, rgba(54, 69, 89, 0.85) 97%);  color:white; }
