Help with grub
My problem is the following: i have 2 hds, one with eos and the other one with windows 7 (at least i had) my problem is that since i formated the hd with windows 7 to install windows 10 grub is still showing windows 7 and if i try to boot that hd it will fail, do i need to regenerate grub or maybe update it ? thanks
You probably need to delete/modify the config for Windows in /etc/grub.d
If you delete it, enable os-prober in /etc/default/grub and run sudo grub-mkconfig -o /boot/grub/grub.cfg
┬─[ramon@ramon-m61pmes2p:/e/grub.d]─[12:06:54]
╰─>$ ls        0 < 12:06:54
00_header*  10_linux*  10_linux.bak  20_linux_xen*  30_os-prober*  30_os-prober.bak  30_uefi-firmware*  35_fwupd*  40_custom*  41_custom*  README
i dont see any windows file inside grub.d
In that case, you can skip that step and do the other steps.
GRUB_DISABLE_OS_PROBER=false, do i need to set this to true ?
No, that is correct. You probably just need to run the last command.
Thanks, is there any risk to run that command ?
Yes.
i ran that command maybe a few weeks ago. so it should be pretty much okay to run it again i guess ?
Yes, in most cases it will be fine.
i ran the command and it cleared windows 7 on grub, but now it only shows both options to boot eos, how can i make grub show the hd with windows 10 ?
Can you share the full output from the command sudo grub-mkconfig
┬─[ramon@ramon-m61pmes2p:~]─[13:19:17]
╰─>$ sudo grub-mkconfig                                                             0 < 13:19:17
[sudo] senha para ramon:
A gerar ficheiro de configuração grub...
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_msdos
insmod ext2
set root='hd1,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos1 --hint-efi=hd1,msdos1 --hint-baremetal=ahci1,msdos1  d1a3e63f-1931-4b17-a860-b6cbef37c814
else
  search --no-floppy --fs-uuid --set=root d1a3e63f-1931-4b17-a860-b6cbef37c814
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=pt_BR
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
Tema encontrado: /boot/grub/themes/EndeavourOS/theme.txt
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/boot/grub/themes/EndeavourOS/unifont-regular-16.pf2
insmod png
set theme=($root)/boot/grub/themes/EndeavourOS/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
Imagem Linux encontrada: /boot/vmlinuz-linux
Imagem initrd encontrada: /boot/amd-ucode.img /boot/initramfs-linux.img
menuentry 'EndeavourOS, on linux' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-d1a3e63f-1931-4b17-a860-b6cbef37c814' {
        load_video
        set gfxpayload=keep
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Loading kernel linux ...'
        linux   /boot/vmlinuz-linux root=UUID=d1a3e63f-1931-4b17-a860-b6cbef37c814 rw  quiet loglevel=3 nowatchdog nvme_load=YES
        echo    'Carregando o ramdisk inicial...'
        initrd  /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-fallback.img
menuentry 'EndeavourOS, on linux (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-d1a3e63f-1931-4b17-a860-b6cbef37c814' {
        load_video
        set gfxpayload=keep
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        initrd  /boot/amd-ucode.img /boot/initramfs-linux-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
Aviso: os-prober será executado para detectar outras partições de arranque.
A sua saída será usada para detectar binários de arranque nessas partições e criar novas entradas.
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
A adicionar entrada de menu para UEFI Firmware Settings ...
if [ "$grub_platform" = "efi" ]; then
        fwsetup --is-supported
        if [ "$?" = 0 ]; then
                menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
                        fwsetup
        fi
fi
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/35_fwupd ###
### END /etc/grub.d/35_fwupd ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
concluído
It looks like os-prober is running but not detecting your Windows partition.
maybe if i set the hd windows 10 as primary boot order this could help ?
The most common reason is that your Linux is EFI and your windows BIOS or the opposite.
They either need to both be installed in BIOS mode or both in UEFI.
i think i’ll just use quick boot menu instead, thanks for the help
think you could add windows to grub.d/40_custom
so i just add ‘windows’ at the end of the 40_custom file ?
I don’t think that will work if one is UEFI and the other BIOS/MBR.
