Help needed, gedit stopped working
i’ve been using gedit as my main text editor, and it suddenly stopped working (without updating my system), maybe it could be something related to zram but i am not sure, here’s the output
┬─[ramon@ramon-m61pmes2p:~]─[11:38:58]
╰─>$ inxi -j                                                        0 < 11:38:58
  ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) dev: /dev/zram0
┬─[ramon@ramon-m61pmes2p:~]─[11:34:52]
╰─>$ gedit                                                          0 <
fish: Tarefa 1, 'gedit' encerrada pelo sinal SIGSEGV (Address boundary error)
i tried LANG=C gedit to get the output in english but it did not work
I installed gedit to test and it works over here.
Try taking the update and see if makes a difference.
my system is up to date, gedit now on plasma only seems to open with sudo (i did a test) one thing i noticed is that gedit opened fine on a xfce session, the problem seems to be on plasma which is my main DE, and i am using x11 instead of wayland
If you have done this before, it may have messed up ownership of its config files, I guess.
Check if everything under your home directory belong to your user:
find $HOME ! -user $USER
┬─[ramon@ramon-m61pmes2p:~]─[17:03:12]
╰─>$ find $HOME ! -user $USER                                       0 < 17:03:12
/home/ramon/dfilemanager/build/install_manifest.txt
/home/ramon/dfilemanager/build/dfm/cmake_install.cmake
/home/ramon/dfilemanager/build/dfm/Makefile
/home/ramon/dfilemanager/build/dfm/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/build.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/cmake_clean.cmake
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/progress.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/compiler_depend.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen_timestamp_deps.dir/compiler_depend.ts
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/build.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/depend.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/progress.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/link.txt
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/flags.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm.dir/compiler_depend.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen.dir/build.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen.dir/AutogenInfo.json
/home/ramon/dfilemanager/build/dfm/CMakeFiles/dfm_autogen.dir/progress.make
/home/ramon/dfilemanager/build/dfm/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsText/cmake_install.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/Makefile
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen.dir/AutogenInfo.json
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/cmake_clean.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin_autogen_timestamp_deps.dir/compiler_depend.ts
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/link.txt
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/flags.make
/home/ramon/dfilemanager/build/plugins/ThumbsText/CMakeFiles/thumbstextplugin.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/cmake_install.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/Makefile
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/link.txt
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/flags.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/cmake_clean.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen_timestamp_deps.dir/compiler_depend.ts
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen.dir/AutogenInfo.json
/home/ramon/dfilemanager/build/plugins/ThumbsImages/CMakeFiles/thumbsimageplugin_autogen.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/cmake_install.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/Makefile
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen.dir/AutogenInfo.json
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/cmake_clean.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin_autogen_timestamp_deps.dir/compiler_depend.ts
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/link.txt
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/flags.make
/home/ramon/dfilemanager/build/plugins/ThumbsVideos/CMakeFiles/thumbsvideosplugin.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsMovies/Makefile
/home/ramon/dfilemanager/build/plugins/ThumbsMovies/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsMovies/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/cmake_install.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/Makefile
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/link.txt
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/flags.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen.dir/AutogenInfo.json
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/build.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/cmake_clean.cmake
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/progress.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/compiler_depend.make
/home/ramon/dfilemanager/build/plugins/ThumbsPDF/CMakeFiles/thumbspdfplugin_autogen_timestamp_deps.dir/compiler_depend.ts
/home/ramon/dfilemanager/build/plugins/Makefile
/home/ramon/dfilemanager/build/plugins/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/plugins/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/Makefile
/home/ramon/dfilemanager/build/CMakeCache.txt
/home/ramon/dfilemanager/build/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/dfilemanager/build/CMakeFiles/pkgRedirects
/home/ramon/dfilemanager/build/CMakeFiles/CMakeConfigureLog.yaml
/home/ramon/dfilemanager/build/CMakeFiles/Makefile2
/home/ramon/dfilemanager/build/CMakeFiles/progress.marks
/home/ramon/dfilemanager/build/CMakeFiles/CMakeScratch
/home/ramon/dfilemanager/build/CMakeFiles/TargetDirectories.txt
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdC
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdC/tmp
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdC/CMakeCCompilerId.c
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdC/a.out
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CMakeCXXCompiler.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CMakeDetermineCompilerABI_C.bin
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CMakeSystem.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CMakeDetermineCompilerABI_CXX.bin
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CMakeCCompiler.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdCXX
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdCXX/tmp
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdCXX/a.out
/home/ramon/dfilemanager/build/CMakeFiles/3.23.1/CompilerIdCXX/CMakeCXXCompilerId.cpp
/home/ramon/dfilemanager/build/CMakeFiles/Makefile.cmake
/home/ramon/dfilemanager/build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/dfilemanager/build/CMakeFiles/uninstall.dir/DependInfo.cmake
/home/ramon/dfilemanager/build/CMakeFiles/uninstall.dir/build.make
/home/ramon/dfilemanager/build/CMakeFiles/uninstall.dir/progress.make
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdC
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdC/tmp
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdC/CMakeCCompilerId.c
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdC/a.out
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CMakeCXXCompiler.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CMakeDetermineCompilerABI_C.bin
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CMakeSystem.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CMakeDetermineCompilerABI_CXX.bin
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CMakeCCompiler.cmake
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdCXX
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdCXX/tmp
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdCXX/a.out
/home/ramon/dfilemanager/build/CMakeFiles/3.28.3/CompilerIdCXX/CMakeCXXCompilerId.cpp
/home/ramon/styleproject-code/build/kwin/Makefile
/home/ramon/styleproject-code/build/kwin/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5ConfigWidgets_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5ConfigWidgets_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Auth_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Auth_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5WidgetsAddons_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5WidgetsAddons_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen.dir/AutogenInfo.json
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen.dir/compiler_depend.internal
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen.dir/compiler_depend.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/progress.marks
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5GuiAddons_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5GuiAddons_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5CoreAddons_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5CoreAddons_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen_timestamp_deps.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration_autogen_timestamp_deps.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Config_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Config_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/depend.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/link.txt
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/flags.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/dspdecoration.dir/compiler_depend.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Codecs_QCH.dir/build.make
/home/ramon/styleproject-code/build/kwin/CMakeFiles/KF5Codecs_QCH.dir/progress.make
/home/ramon/styleproject-code/build/kwin/CTestTestfile.cmake
/home/ramon/styleproject-code/build/install_manifest.txt
/home/ramon/styleproject-code/build/config/Makefile
/home/ramon/styleproject-code/build/config/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/styleproject-code/build/config/CMakeFiles/progress.marks
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/build.make
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/depend.make
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/progress.make
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/link.txt
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/flags.make
/home/ramon/styleproject-code/build/config/CMakeFiles/dspsettings_qt5.dir/compiler_depend.make
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/build.make
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/depend.make
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/progress.make
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/link.txt
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/flags.make
/home/ramon/styleproject-code/build/config/CMakeFiles/styleproject_config_qt5.dir/compiler_depend.make
/home/ramon/styleproject-code/build/.qt
/home/ramon/styleproject-code/build/.qt/QtDeploySupport.cmake
/home/ramon/styleproject-code/build/Makefile
/home/ramon/styleproject-code/build/CMakeCache.txt
/home/ramon/styleproject-code/build/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/styleproject-code/build/CMakeFiles/pkgRedirects
/home/ramon/styleproject-code/build/CMakeFiles/Makefile2
/home/ramon/styleproject-code/build/CMakeFiles/KF5WindowSystem_QCH.dir/build.make
/home/ramon/styleproject-code/build/CMakeFiles/KF5WindowSystem_QCH.dir/progress.make
/home/ramon/styleproject-code/build/CMakeFiles/progress.marks
/home/ramon/styleproject-code/build/CMakeFiles/CMakeScratch
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/build.make
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/depend.make
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/progress.make
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/link.txt
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/flags.make
/home/ramon/styleproject-code/build/CMakeFiles/styleproject_qt5.dir/compiler_depend.make
/home/ramon/styleproject-code/build/CMakeFiles/TargetDirectories.txt
/home/ramon/styleproject-code/build/CMakeFiles/Makefile.cmake
/home/ramon/styleproject-code/build/CMakeFiles/fetch-translations.dir/build.make
/home/ramon/styleproject-code/build/CMakeFiles/fetch-translations.dir/progress.make
/home/ramon/styleproject-code/build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdC
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdC/tmp
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdC/CMakeCCompilerId.c
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdC/a.out
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CMakeCXXCompiler.cmake
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CMakeDetermineCompilerABI_C.bin
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CMakeSystem.cmake
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CMakeDetermineCompilerABI_CXX.bin
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CMakeCCompiler.cmake
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdCXX
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdCXX/tmp
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdCXX/a.out
/home/ramon/styleproject-code/build/CMakeFiles/3.29.0/CompilerIdCXX/CMakeCXXCompilerId.cpp
/home/ramon/styleproject-code/build/CMakeFiles/uninstall.dir/build.make
/home/ramon/styleproject-code/build/CMakeFiles/uninstall.dir/progress.make
/home/ramon/styleproject-code/build/stylelib/Makefile
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/CMakeDirectoryInformation.cmake
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/build.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/depend.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/progress.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/link.txt
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/flags.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5.dir/compiler_depend.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/progress.marks
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen.dir/build.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen.dir/AutogenInfo.json
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen.dir/progress.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen.dir/compiler_depend.internal
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen.dir/compiler_depend.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen_timestamp_deps.dir/build.make
/home/ramon/styleproject-code/build/stylelib/CMakeFiles/dspstylelib_qt5_autogen_timestamp_deps.dir/progress.make
/home/ramon/styleproject-code/build/CTestTestfile.cmake
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdC
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdC/tmp
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdC/CMakeCCompilerId.c
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdC/a.out
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CMakeCXXCompiler.cmake
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CMakeDetermineCompilerABI_C.bin
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CMakeSystem.cmake
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CMakeDetermineCompilerABI_CXX.bin
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CMakeCCompiler.cmake
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdCXX
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdCXX/tmp
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdCXX/a.out
/home/ramon/.shapecorners-code/build/CMakeFiles/3.23.1/CompilerIdCXX/CMakeCXXCompilerId.cpp
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Notifications_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Notifications_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/Makefile.cmake
/home/ramon/.shapecorners-code/build/CMakeFiles/fetch-translations.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/fetch-translations.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5GlobalAccel_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5GlobalAccel_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5GuiAddons_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5GuiAddons_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners_autogen.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners_autogen.dir/AutogenInfo.json
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners_autogen.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5CoreAddons_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5CoreAddons_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Completion_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Completion_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Service_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Service_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Config_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Config_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Solid_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Solid_QCH.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/uninstall.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/uninstall.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_shapecorners_config_autogen.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_shapecorners_config_autogen.dir/AutogenInfo.json
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_shapecorners_config_autogen.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/depend.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/progress.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/link.txt
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/flags.make
/home/ramon/.shapecorners-code/build/CMakeFiles/kwin4_effect_shapecorners.dir/compiler_depend.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Codecs_QCH.dir/build.make
/home/ramon/.shapecorners-code/build/CMakeFiles/KF5Codecs_QCH.dir/progress.make
/home/ramon/kdfm-code/build/install_manifest.txt
/home/ramon/kdfm-code/build/src/CMakeFiles/kdfm_autogen.dir/compiler_depend.internal
/home/ramon/kdfm-code/build/src/CMakeFiles/kdfm_autogen.dir/compiler_depend.make
/home/ramon/kdfm-code/build/src/CMakeFiles/kdfm.dir/compiler_depend.internal
/home/ramon/kdfm-code/build/src/CMakeFiles/kdfm.dir/compiler_depend.make
/home/ramon/kdfm-code/build/CMakeFiles/pkgRedirects
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdC
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdC/tmp
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdC/CMakeCCompilerId.c
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdC/a.out
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CMakeCXXCompiler.cmake
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CMakeDetermineCompilerABI_C.bin
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CMakeSystem.cmake
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CMakeDetermineCompilerABI_CXX.bin
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CMakeCCompiler.cmake
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdCXX
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdCXX/tmp
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdCXX/a.out
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/3.24.0/CompilerIdCXX/CMakeCXXCompilerId.cpp
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5GlobalAccel_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5GuiAddons_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5CoreAddons_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5Completion_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5Service_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5Config_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5Solid_QCH.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/uninstall.dir/build.make
/home/ramon/.Builds/LightlyShaders-160b37089b8be93261cb400dac34b2ef9bbd3e47/qt5build/CMakeFiles/KF5Codecs_QCH.dir/build.make
/home/ramon/LightlyShaders/qt6build/install_manifest.txt
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/kcm/CMakeFiles/kwin_lightlyshaders_config_autogen.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/kcm/CMakeFiles/kwin_lightlyshaders_config_autogen.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/kcm/CMakeFiles/kwin_lightlyshaders_config.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/CMakeFiles/kwin_effect_lightlyshaders_autogen.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/CMakeFiles/kwin_effect_lightlyshaders_autogen.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt6build/src/lightlyshaders/CMakeFiles/kwin_effect_lightlyshaders.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/blur/kcm/CMakeFiles/kwin_lightlyshaders_blur_config.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/blur/kcm/CMakeFiles/kwin_lightlyshaders_blur_config_autogen.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/blur/kcm/CMakeFiles/kwin_lightlyshaders_blur_config_autogen.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt6build/src/blur/CMakeFiles/lightlyshaders_blur_autogen.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/blur/CMakeFiles/lightlyshaders_blur_autogen.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt6build/src/blur/CMakeFiles/lightlyshaders_blur.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/liblshelper/CMakeFiles/lshelper_autogen.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt6build/src/liblshelper/CMakeFiles/lshelper_autogen.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt6build/src/liblshelper/CMakeFiles/lshelper.dir/compiler_depend.internal
/home/ramon/LightlyShaders/qt5build/kwin4_effect_lightlyshaders.so
/home/ramon/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/EWIEGA46WW/moc_lightlyshaders_config.cpp
/home/ramon/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/include/lightlyshaders_config.moc
/home/ramon/LightlyShaders/qt5build/install_manifest.txt
/home/ramon/LightlyShaders/qt5build/kwin4_lightlyshaders_config.so
/home/ramon/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/moc_lightlyshaders.cpp
/home/ramon/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/include/lightlyshaders.moc
/home/ramon/LightlyShaders/qt5build/Makefile
/home/ramon/LightlyShaders/qt5build/CMakeCache.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5ItemViews_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5KIO_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Bookmarks_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders_autogen.dir/AutogenInfo.json
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders_autogen.dir/ParseCache.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders_autogen.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5JobWidgets_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5I18n_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/pkgRedirects
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5ConfigWidgets_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5XmlGui_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Auth_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5WidgetsAddons_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/lightlyshaders_config.cpp.o
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/kwin4_lightlyshaders_config_autogen/mocs_compilation.cpp.o
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/kwineffects_interface.cpp.o
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/depend.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/link.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/Makefile2
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5WindowSystem_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/progress.marks
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/depend.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/lightlyshaders.cpp.o
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/link.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/kwin4_effect_lightlyshaders_autogen/mocs_compilation.cpp.o
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_effect_lightlyshaders.dir/compiler_depend.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Crash_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/TargetDirectories.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Notifications_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config_autogen.dir/AutogenInfo.json
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config_autogen.dir/ParseCache.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/kwin4_lightlyshaders_config_autogen.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/Makefile.cmake
/home/ramon/LightlyShaders/qt5build/CMakeFiles/fetch-translations.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5GlobalAccel_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5GuiAddons_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5CoreAddons_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Completion_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Service_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Config_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Solid_QCH.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/uninstall.dir/progress.make
/home/ramon/LightlyShaders/qt5build/CMakeFiles/KF5Codecs_QCH.dir/progress.make
/home/ramon/Filer/build/install_manifest.txt
/home/ramon/Filer/build/src/Filer
/home/ramon/Filer/build/src/CMakeFiles/Filer_autogen.dir/progress.make
/home/ramon/Filer/build/src/CMakeFiles/progress.marks
/home/ramon/Filer/build/src/CMakeFiles/translations.dir/DependInfo.cmake
/home/ramon/Filer/build/src/CMakeFiles/translations.dir/build.make
/home/ramon/Filer/build/src/CMakeFiles/translations.dir/progress.make
/home/ramon/Filer/build/src/CMakeFiles/translations_update.dir/DependInfo.cmake
/home/ramon/Filer/build/src/CMakeFiles/translations_update.dir/build.make
/home/ramon/Filer/build/src/CMakeFiles/translations_update.dir/progress.make
/home/ramon/Filer/build/src/CMakeFiles/Filer.dir/build.make
/home/ramon/Filer/build/src/CMakeFiles/Filer.dir/depend.make
/home/ramon/Filer/build/src/CMakeFiles/Filer.dir/progress.make
/home/ramon/Filer/build/src/CMakeFiles/Filer.dir/compiler_depend.internal
/home/ramon/Filer/build/src/CMakeFiles/Filer.dir/compiler_depend.make
/home/ramon/Filer/build/Makefile
/home/ramon/Filer/build/CMakeFiles/pkgRedirects
/home/ramon/Filer/build/CMakeFiles/Makefile2
/home/ramon/Filer/build/CMakeFiles/progress.marks
/home/ramon/Filer/build/CMakeFiles/TargetDirectories.txt
/home/ramon/Filer/build/CMakeFiles/Makefile.cmake
/home/ramon/Filer/build/CMakeFiles/VerifyGlobs.cmake
/home/ramon/Filer/build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/install_manifest.txt
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config.dir/depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config.dir/compiler_depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config_autogen.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config_autogen.dir/compiler_depend.internal
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config_autogen.dir/compiler_depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/progress.marks
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config_autogen_timestamp_deps.dir/build.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/kcm/CMakeFiles/kwin_yetanothermagiclamp_config_autogen_timestamp_deps.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp_autogen.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp_autogen.dir/compiler_depend.internal
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp_autogen.dir/compiler_depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/progress.marks
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp_autogen_timestamp_deps.dir/build.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp_autogen_timestamp_deps.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp.dir/depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/src/CMakeFiles/kwin4_effect_yetanothermagiclamp.dir/compiler_depend.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/Makefile
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/pkgRedirects
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5ConfigWidgets_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5Auth_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5WidgetsAddons_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/Makefile2
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5WindowSystem_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/progress.marks
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/TargetDirectories.txt
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/Makefile.cmake
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/fetch-translations.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5CoreAddons_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/CMakeRuleHashes.txt
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5Config_QCH.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/uninstall.dir/progress.make
/home/ramon/kwin-effects-yet-another-magic-lamp/qt5build/CMakeFiles/KF5Codecs_QCH.dir/progress.make
these builds looks ok, these are all from my home directory
on xfce gedit can launch just fine, no root needed, it was working fine on plasma too since yesterday, not sure what’s wrong but maybe something related to x11 ?
wonder if you added an unusual funky plugin to it?
as long as I’ve been on Linux gedit to me has been the most stable app in existence.
//–there may be something to it re: ‘a plasma thing’ also but that’s just a hunch, not actual knowledge.//
no plugins installed, i just have the gedit package installed, i tried gnome-text-editor and it works fine but i dont like it cos it’s gtk4 and the gtk theme i use doesnt support gtk4, must be a specific problem with gedit on plasma but not very sure, i can just switch to another text editor for now, anyways i really should create another plasma user for a fresh plasma6 experience, there are some things on the system tray that doesnt work for me, but i created a test user and it worked fine on there, so my desktop might be a bit messed up on configs, just need to create courage for all the work and i’ve been still lazy for setting up a new user for plasma 6, so there’s that to account too
i tried launching gedit this morning and still nothing, but right now i just noticed some updates available for gkt3 and after installing the updates gedit launch again just fine
