HELP i'm losing my mind (thx sway)
I think I didn’t understand sorry, Like I install another desktop than gnome and edit files from this new desktop ?
Can you paste the config file?
Also where is the config file saved?
my config file is saved in ~/.config/sway/
and for some fricking reason I can’t copy paste the file of the config even though I activated the copy paste to be bidirectional virtualbox is pissing me off wait i’ll try to send it to me via mail or something to copy paste out of my virtual machine :sob:
# Default config for sway
# Copy this to ~/.config/sway/config and edit it to your liking.
# Read `man 5 sway` for a complete reference.
### Variables
# Logo key. Use Mod1 for Alt.
set $mod Mod4
# Home row direction keys, like vim
set $left h
set $down j
set $up k
set $right l
# Your preferred terminal emulator
set $term kitty
# Your preferred application launcher
set $menu wofi --shown drun
set $file_explorer nautilus
bindsym $mod+e exec $file_explorer
### Output configuration
# Default wallpaper (more resolutions are available in /usr/share/backgrounds/sway/)
output * bg /usr/share/backgrounds/sway/Sway_Wallpaper_Blue_1920x1080.png fill
# Example configuration:
# output HDMI-A-1 resolution 1920x1080 position 1920,0
# You can get the names of your outputs by running: swaymsg -t get_outputs
### Idle configuration
# exec swayidle -w \
# timeout 300 ‘swaylock -f -c 000000’ \
# timeout 600 ‘swaymsg “output * power off”’ resume ‘swaymsg “output * power on”’ \
# before-sleep ‘swaylock -f -c 000000’
# This will lock your screen after 300 seconds of inactivity, then turn off
# your displays after another 300 seconds, and turn your screens back on when
# resumed. It will also lock your screen before your computer goes to sleep.
### Input configuration
# input type:touchpad {
# dwt enabled
# tap enabled
# natural_scroll enabled
# middle_emulation enabled
# input type:keyboard {
# xkb_layout “eu”
# You can also configure each device individually.
# Read `man 5 sway-input` for more information about this section.
### Key bindings
# Basics:
# Start a terminal
bindsym $mod+Return exec $term
# Kill focused window
bindsym $mod+q kill
# Start your launcher
bindsym $mod+d exec $menu
# Drag floating windows by holding down $mod and left mouse button.
# Resize them with right mouse button + $mod.
# Despite the name, also works for non-floating windows.
# Change normal to inverse to use left mouse button for resizing and right
# mouse button for dragging.
floating_modifier $mod normal
# Reload the configuration file
bindsym $mod+Shift+c reload
# Exit sway (logs you out of your Wayland session)
bindsym $mod+Shift+e exec swaynag -t warning -m ‘You pressed the exit shortcut. Do you really want to exit sway? This will end your Wayland session.’ -B ‘Yes, exit sway’ ‘swaymsg exit’
# Moving around:
# Move your focus around
bindsym $mod+$left focus left
bindsym $mod+$down focus down
bindsym $mod+$up focus up
bindsym $mod+$right focus right
# Or use $mod+[up|down|left|right]
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# Move the focused window with the same, but add Shift
bindsym $mod+Shift+$left move left
bindsym $mod+Shift+$down move down
bindsym $mod+Shift+$up move up
bindsym $mod+Shift+$right move right
# Ditto, with arrow keys
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# Workspaces:
# Switch to workspace
bindsym $mod+1 workspace number 1
bindsym $mod+2 workspace number 2
bindsym $mod+3 workspace number 3
bindsym $mod+4 workspace number 4
bindsym $mod+5 workspace number 5
bindsym $mod+6 workspace number 6
bindsym $mod+7 workspace number 7
bindsym $mod+8 workspace number 8
bindsym $mod+9 workspace number 9
bindsym $mod+0 workspace number 10
# Move focused container to workspace
bindsym $mod+Shift+1 move container to workspace number 1
bindsym $mod+Shift+2 move container to workspace number 2
bindsym $mod+Shift+3 move container to workspace number 3
bindsym $mod+Shift+4 move container to workspace number 4
bindsym $mod+Shift+5 move container to workspace number 5
bindsym $mod+Shift+6 move container to workspace number 6
bindsym $mod+Shift+7 move container to workspace number 7
bindsym $mod+Shift+8 move container to workspace number 8
bindsym $mod+Shift+9 move container to workspace number 9
bindsym $mod+Shift+0 move container to workspace number 10
# Note: workspaces can have any name you want, not just numbers.
# We just use 1-10 as the default.
# Layout stuff:
# You can “split” the current object of your focus with
# $mod+b or $mod+v, for horizontal and vertical splits
# respectively.
bindsym $mod+b splith
bindsym $mod+v splitv
# Switch the current container between different layout styles
bindsym $mod+s layout stacking
bindsym $mod+w layout tabbed
# Make the current focus fullscreen
bindsym $mod+f fullscreen
# Toggle the current focus between tiling and floating mode
bindsym $mod+Shift+space floating toggle
# Swap focus between the tiling area and the floating area
bindsym $mod+space focus mode_toggle
# Move focus to the parent container
bindsym $mod+a focus parent
# Scratchpad:
# Sway has a “scratchpad”, which is a bag of holding for windows.
# You can send windows there and get them back later.
# Move the currently focused window to the scratchpad
bindsym $mod+Shift+minus move scratchpad
# Show the next scratchpad window or hide the focused scratchpad window.
# If there are multiple scratchpad windows, this command cycles through them.
bindsym $mod+minus scratchpad show
# Resizing containers:
mode “resize” {
# left will shrink the containers width
# right will grow the containers width
# up will shrink the containers height
# down will grow the containers height
bindsym $left resize shrink width 10px
bindsym $down resize grow height 10px
bindsym $up resize shrink height 10px
bindsym $right resize grow width 10px
bindsym Left resize shrink width 10px
bindsym Down resize grow height 10px
bindsym Up resize shrink height 10px
bindsym Right resize grow width 10px
# Return to default mode
bindsym Return mode “default”
bindsym Escape mode “default”
bindsym $mod+r mode “resize”
# Utilities:
# Special keys to adjust volume via PulseAudio
bindsym --locked XF86AudioMute exec pactl set-sink-mute \@DEFAULT_SINK@ toggle
bindsym --locked XF86AudioLowerVolume exec pactl set-sink-volume \@DEFAULT_SINK@ -5%
bindsym --locked XF86AudioRaiseVolume exec pactl set-sink-volume \@DEFAULT_SINK@ +5%
bindsym --locked XF86AudioMicMute exec pactl set-source-mute \@DEFAULT_SOURCE@ toggle
# Special keys to adjust brightness via brightnessctl
bindsym --locked XF86MonBrightnessDown exec brightnessctl set 5%-
bindsym --locked XF86MonBrightnessUp exec brightnessctl set 5%+
# Special key to take a screenshot with grim
bindsym Print exec grim
# Status Bar:
# Read `man 5 sway-bar` for more information about this section.
bar {
position top
# When the status_command prints a new line to stdout, swaybar updates.
# The default just shows the current date and time.
status_command while date +‘%Y-%m-%d %X’; do sleep 1; done
colors {
statusline #ffffff
background #323232
inactive_workspace #32323200 #32323200 #5c5c5c
include /etc/sway/config.d/*
Finally there it is
That doesn’t work with a virtual machine in Virtualbox. That will switch the host computer to TTY3.
In a Virtualbox VM, you use Right CTRL instead of CTRL+ALT.
That’s why, for example, kitty isn’t installed on the VM; it’s being installed via TTY on the host machine.
Use RIGHT CTRL + F3 on the VM.
The Actual default config:
Where you can see that foot is the default term and default launcher is wmenu-run
That I didn’t know.
Also if the suggestion of @Stagger_Lee does not work out, maybe just install foot and try using it as a terminal. Maybe kitty simply can’t open for some reason.
Yeah I changed it manually from the original config file store in /etc/sway/config I just wanted to changfe the terminal foot with kitty and the launcher with wofi
Well it worked for me for some reason to do ctrl+alt+f3 but yeah the problem is still not changing I’download the basic packages for sway for the launcher and terminal maybe that’s the problem
Remember, anything you’ve done in a TTY up to this point you’ve done on the host machine, not the VM. If you’ve installed anything through a TTY (using CTRL+ALT+F3) you’ve been installing to the host computer.
Oh, so to remove those I installed on my host computer do I just remove all packages through TTY ?
And finally the terminal opened I just downloaded the basic terminal and wmenu and it seems to work
Yes, you can switch to the host TTY and remove what you’ve installed.
Thank you all very very much ! Wish you all a great day !
