After a recent update, the display manager doesn’t show any gui. entering password works as normal and still loads kde desktop environment. Switching DEs doesn’t have an effect on the condition. I assume it has something to do with the nvidia drivers.
Another effect i noticed is that the battery and energy widget doesn’t show the battery percentage after reboot.
If there’s any other information needed to help do let me know.
This means that your DM is working fine.
Try switching to another TTY and back. This often triggers the DM to appear.
Read this wiki and get and post some system info and logs.
Hey thanks for the help, switching between TTY doesn’t seem to have an effect. I have included hardware information alongside the bootlog respectively.
It’s not too late to learn .
Your Laptop has Hybrid Graphics (two GPU cards).
In Linux, users often use an assistant utility for such cases.
In the posted terminal output, activities from one of those utilities were logged.
I don’t know what LenovoLegionLinux offers.
You should read about the above in EnOS relevant wiki.
I have a very long time to use or support Optimus utilities, so I am not the best one to help you.
@prinMHW
I know there are a number of users with this laptop. (Legion 5 Pro 16ARH7H) As @petsam said it has hybrid graphics with onboard amd gpu Radeon 680M and dedicated Nvidia gpu RTX 3070. Does the UEFI Bios have settings for the gpu that are Hybrid, Integrated and Dedicated? Or what settings does it have? After checking this you may want to try uninstalling optimus-manager and try installing envycontrol
