I have the Cinnamon desktop installed and for some reason my headphones wont work. In Pulse Audio Volume Control I see them connected and the little meter moves when there is sound but no sound is present anywhere. Any help would be appericated
Try with alsamixer
- run it, press F6 to switch between outputs, and make sure the headphone output isn’t muted.
No is was not muted
Have you tested other headphones / speakers through same connector?
Just to exclude headphones / cord malfunction out of equation
Assuming you checked the volume level, it’s also possible your system needs a specific option passing to the audio driver for the correct port setup.
I was able to fix it. I disabled quick boot in the bios and then did a complete shutdown. Now it works. Thanks for your help
Damn this quick boot!
What’s so quick in just skipping devices initialization…
Exactly. It’s even quicker if you leave your computer off.
