I know I posted this topic before but this is a different laptop. My wired headphones worked on my previous linux distro. They worked on the EndeavourOS live image. They worked if I install offline before update if I update they stop working. They do not work on online install at all. I have tried alsamixer to make sure they were not muted. They were not muted. I have disabled quick boot. In pulseaudio volume control it shows the headphones are connected and the meter shows sound is being played. Yet there is no sound comming out the headphones
I have also tried bluetooth headphones and had the exact same experience.
I really want to use EndeavourOS on all my machines.
I really really hate to reply with this, but I had a similar issue about a week or so ago. I honestly can’t for the life of me remember the specific action I used to solve it. I know I discovered the solution at https://wiki.archlinux.org/index.php/PulseAudio/Troubleshooting
Like I said it pains me greatly to link to the ArchWiki and I truly apologize. I figured since you have not had a reply yet at the very least me posting may bump your topic so someone else sees it. I’m sorry I cannot be more helpful.
I beleive I have tried all the different settings in the pulse-audio panel the little meter shows there is sound being played but there is none. Sound does play out my speakers tho
Yes it was install by default. My speakers work just no headphones and I know the jack works becuase if I install a different distro it works. and it works on the live media. I think it has something to do with a pulse audio update
Hi!
I’ve read this thread for a while, but since all things seems to be excluded and headphones themselves…
Maybe you can try JACK (not headphones jack, but program) and bypass pulseaudio completely to see if it works and if it will play - then it’s some problem with pulseaudio and we can report it…
I can walk you through JACK installation and basic use, if you want to try
Launch Cadence and do it’s most basic settings (to route all audio through JACK):
JACK Settings
[x] Auto-start JACK or LADISH at login
ALSA Audio
Alsa -> PulseAudio -> JACK (plugin)
PulseAudio
[ ] Auto-start at login
Engine
[x] Realtime
Driver
[x] ALSA
[x] Duplex Mode !
Device/Interface - your audio card
Sample rate - 44100 kHz
Buffer size - 512
Period/Buffer - 2
System settings - Audio
[x] JACK sink (PulseAudio JACK Sink)
Smaller buffer size - obviously smaller will be latency, but if you just listen and don’t create music - it should be safe starting value (although outcome heavily depends on Audio hardware, usually you should aim for as small value as possible, which doesn’t introduce crackles / xruns)
Inside Cadence there is Tools - Catia - here you can route anything to any connection like an octopus
Now, you start for example VLC, go to Tools - Preferences - Audio - Output module and choose JACK audio output, this means that you will completely bypass pulseaudio and ALSA and use jack directly.
Now, close VLC and open any audio file with it see if there is a sound!
If there still won’t be sound you can just remove those packages, this should bring you back to usual pulseaudio setup…
Hopefully it will help!
P.S. If you’re interested, JACK is for proaudio mainly, you can read more here https://jackaudio.org/
Thank you for the help. I must have done something wrong. I had no audio at all even through my speakers after a reboot. I uninstalled the files and my speaker volume came back just not my headphones thank you anyways
Now, you start for example VLC, go to Tools - Preferences - Audio - Output module and choose JACK audio output , this means that you will completely bypass pulseaudio and ALSA and use jack directly.
You must have missed something along those lines, or:
Driver - Device/Interface - Choose your audio card output
Well…Anyway, other than trying JACK i’m completely out of ideas
I know I posted this some time ago but I just found a solution and thought I wouild share it. It seems that a small change a change in patch_realtek.c in the kernel and updated lts kernel is the problem. This affects ASUS GL703GM, GL703GE, GU502GW, GL503VM and GL503VD Laptops. The fix I used is to add “options snd-hda-intel model=headset-mode” to /etc/modprobe.d/alsa.conf then completely shut down my system turned it back on and now my headphones are working
