Headphones not being auto-detected and other audio playback issues
TL;DR - Laptop not automatically switching to plugged-in headphones, certain apps not making sound when using Analog Stereo, at least 2 GUI flaws regarding switching playback devices, and systemctl not bothering to detect & configure listed units.
1.) When first plugging my headphones into my laptop’s audio jack, it does not automatically become the used playback device, and I can’t access the headphones through the system tray’s audio widget. I’m forced to open System Settings to change the port to Headphones. However, it is labelled as “unplugged” no matter what.
2.) Testing the audio works for both sides when using either the Analog Stereo or Pro Audio profiles. The second problem happens with the former, where audio does not play for the headphones in some applications. For example, playing media in LibreWolf does not give sound, whereas other apps like LMMS does. Whatever causes this to happen, at least Pro Audio works for both of these apps, though for some reason I’m unable to choose a playback device when using Pro Audio, forcing me to switch to Analog Stereo for that.
I have tried to troubleshoot problem 1 through 5.1.2 in the PipeWire page in the ArchWiki, already created the listed .conf file which switches to newly connected devices automatically, but attempting to restart the pipewire-pulse.service unit says it is not found nor loaded, even though systemctl --user says it is loaded, active and running.
Other things I did was running sudo alsactl restore multiple times, setting Pro Audio as the default output device in pavucontrol, and running systemctl --user restart pipewire for a few times. They helped a bit, but problems stil persist.
Perhaps there is a package I should install that will auto-switch to headphones for me, as I’ll stick to Pro Audio from now on. Or was I supposed to do something with the sinks? Let me know if my issue also involved bugs and what I should do to report those as well soon. thanks
$ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 3837
Tile Size: 65472
User Name: kian
Host Name: lenovoideapad330-81de
Server Name: PulseAudio (on PipeWire 1.4.9)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.pro-output-0
Default Source: alsa_input.pci-0000_00_1f.3.pro-input-0
Cookie: 5823:1a7d
$ inxi -FAZ
Host: lenovoideapad330-81de Kernel: 6.17.9-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.5.3 Distro: EndeavourOS
Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
serial:
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial:
Firmware: UEFI vendor: LENOVO v: 8TCN46WW date: 07/26/2018
Battery:
ID-1: BAT0 charge: 23.4 Wh (100%) condition: 23.4/30.6 Wh (76.4%)
Info: dual core model: Intel Core i3-8130U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 800 min/max: 400/3400 cores: 1: 800 2: 800 3: 800 4: 800
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: NVIDIA GP108M [GeForce MX150] driver: nouveau v: kernel
Device-3: Syntek EasyCamera driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris,nouveau
gpu: i915 resolution: 1366x768~60Hz
API: EGL v: 1.5 drivers: iris,nouveau,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.3.1-arch1.2
renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
API: ALSA v: k6.17.9-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp2s0 state: down mac: 8c:16:45:b9:e5:da
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
driver: ath10k_pci
IF: wlan0 state: up mac: 30:d1:6b:ea:70:d1
Bluetooth:
Device-1: Qualcomm Atheros driver: btusb type: USB
Report: btmgmt ID: hci0 rfk-id: 9 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 2.05 TiB used: 22.63 GiB (1.1%)
ID-1: /dev/sda vendor: Samsung model: SSD 870 EVO 250GB size: 232.89 GiB
ID-2: /dev/sdb vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
ID-1: / size: 226.2 GiB used: 11.22 GiB (5.0%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 43.0 C pch: 40.5 C mobo: N/A gpu: nouveau
temp: 36.0 C
Fan Speeds (rpm): N/A
Memory: total: 12 GiB available: 11.59 GiB used: 4.01 GiB (34.6%)
Processes: 199 Uptime: 8h 9m Shell: Bash inxi: 3.3.40
