Having Trouble recompiling sdl for unreal engine
From the UE source code, path: Engine/Source/ThirdParty/SDL2
is this build.sh
#!/bin/bash
## Unreal Engine 4 Build script for SDL2
## Copyright Epic Games, Inc. All Rights Reserved.
pushd "`dirname "$0"`/"
if [ -z "$TARGET_ARCH" ]; then
	TARGET_ARCH=x86_64-unknown-linux-gnu
fi
export VULKAN_SDK=`pwd`/../Vulkan
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:/usr/local/share/pkgconfig:$PKG_CONFIG_PATH
BuildWithOptions()
	local StaticLibName=$1
	local BuildDir=$2
	local SdlDir=$3
	local SdlLibName=$4
	shift
	shift
	shift
	shift
	local Options=$@
	rm -rf $BuildDir
	mkdir -p $BuildDir
	pushd $BuildDir
	cmake $Options $SdlDir
	make -j 4
	mkdir -p $SdlDir/lib/Linux/$TARGET_ARCH/
	cp --remove-destination $StaticLibName $SdlDir/lib/Linux/$TARGET_ARCH/$SdlLibName
	popd
set -e
SDL_DIR=SDL-gui-backend
BUILD_DIR=build-$SDL_DIR
# build Debug with -fPIC so it's usable in any type of build
BuildWithOptions libSDL2d.a $BUILD_DIR-Debug ../$SDL_DIR libSDL2_fPIC_Debug.a -DCMAKE_BUILD_TYPE=Debug -DSDL_STATIC_PIC=ON -DVIDEO_MIR=OFF -DVIDEO_KMSDRM=OFF -DCMAKE_C_FLAGS=-gdwarf-4
#exit 0
BuildWithOptions libSDL2.a $BUILD_DIR-Release ../$SDL_DIR libSDL2.a -DCMAKE_BUILD_TYPE=Release -DVIDEO_MIR=OFF -DVIDEO_KMSDRM=OFF -DCMAKE_C_FLAGS=-gdwarf-4
BuildWithOptions libSDL2.a $BUILD_DIR-ReleasePIC ../$SDL_DIR libSDL2_fPIC.a -DCMAKE_BUILD_TYPE=Release -DSDL_STATIC_PIC=ON -DVIDEO_MIR=OFF -DVIDEO_KMSDRM=OFF -DCMAKE_C_FLAGS=-gdwarf-4
set +e
This thing just refuses to compile giving seemingly nonsensical errors (errors that looking up online didn’t yield any results)
Such as:
CMake Error: File /home/rabcor/Downloads/SDL2Unreal/UnrealEngine-5.4.2-release/Engine/Source/ThirdParty/SDL2/SDL-gui-backend/sdl2.pc.in does not exist.
CMake Error at CMakeLists.txt:2906 (configure_file):
  configure_file Problem configuring file
CMake Error: File /home/rabcor/Downloads/SDL2Unreal/UnrealEngine-5.4.2-release/Engine/Source/ThirdParty/SDL2/SDL-gui-backend/sdl2-config.in does not exist.
CMake Error at CMakeLists.txt:2908 (configure_file):
CMake Error at CMakeLists.txt:2910 (configure_file):
CMake Error: File /home/rabcor/Downloads/SDL2Unreal/UnrealEngine-5.4.2-release/Engine/Source/ThirdParty/SDL2/SDL-gui-backend/SDL2.spec.in does not exist.
CMake Error at CMakeLists.txt:2912 (configure_file):
it seems like there are files that cmake is supposed to create that it does not actually create thus cannot find and fails to compile, any idea how i could fix this?
