I am unable to use the docker daemon I have running with systemd.
This is what I see when I run journalctl -xeu docker.service
Jul 19 23:50:24 Framework systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ Automatic restarting of the unit docker.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Jul 19 23:50:24 Framework systemd[1]: docker.service: Start request repeated too quickly.
Jul 19 23:50:24 Framework systemd[1]: docker.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit docker.service has entered the 'failed' state with result 'exit-code'.
Jul 19 23:50:24 Framework systemd[1]: Failed to start Docker Application Container Engine.
░░ Subject: A start job for unit docker.service has failed
░░ A start job for unit docker.service has finished with a failure.
░░ The job identifier is 1735 and the job result is failed.
This is what I see when I run journalctl -xeu docker.socket
Jul 19 23:49:47 Framework systemd[1]: Starting Docker Socket for the API...
░░ Subject: A start job for unit docker.socket has begun execution
░░ A start job for unit docker.socket has begun execution.
░░ The job identifier is 268.
Jul 19 23:49:47 Framework systemd[1]: Listening on Docker Socket for the API.
░░ Subject: A start job for unit docker.socket has finished successfully
░░ A start job for unit docker.socket has finished successfully.
Jul 19 23:50:24 Framework systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'.
░░ The unit docker.socket has entered the 'failed' state with result 'service-start-limit-hit'.
I thought I had messed something up on my existing install, so I reinstalled Endeavour using the latest install ISO from endeavouros.com and am still running into this problem after installing docker.
Here is some information about my system:
./o. insomnia@Framework
./sssso- ------------------
`:osssssss+- OS: EndeavourOS x86_64
`:+sssssssssso/. Host: Laptop 16 (AMD Ryzen 7040 Series) (A7)
`-/ossssssssssssso/. Kernel: Linux 6.9.10-arch1-1
`-/+sssssssssssssssso+:` Uptime: 10 hours, 37 mins
`-:/+sssssssssssssssssso+/. Packages: 1098 (pacman)
`.://osssssssssssssssssssso++- Shell: fish 3.7.1
.://+ssssssssssssssssssssssso++: Display (BOE0BC9): 2560x1600 @ 165Hz (as 1706x1066) [Buil]
.:///ossssssssssssssssssssssssso++: DE: KDE Plasma 6.1.3
`:////ssssssssssssssssssssssssssso+++. WM: KWin (Wayland)
`-////+ssssssssssssssssssssssssssso++++- WM Theme: Breeze
`..-+oosssssssssssssssssssssssso+++++/` Theme: Breeze (Dark) [Qt], Breeze-Dark [GTK2], Breeze [GT]
./++++++++++++++++++++++++++++++/:. Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4]
`:::::::::::::::::::::::::------`` Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: breeze (24px)
Terminal: konsole 24.5.2
CPU: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics (16) @ 5.z
GPU: AMD Radeon 780M [Integrated]
Memory: 4.89 GiB / 14.82 GiB (33%)
Swap: 0 B / 16.30 GiB (0%)
Disk (/): 43.55 GiB / 898.79 GiB (5%) - ext4
Local IP (wlan0): 192.168.1.251/24
Battery: 100% [AC Connected]
Locale: en_US.UTF-8
I can provide more information if necessary.
