How is the monitor connected?
one monitor via dvi and another via hdmi
Which was disconnected when the issue came back?
the one connected via hdmi
Switch back to the hdmi and reboot and see if the issue goes away again.
So you edited the default grub file.
sudo nano /etc/default/grub
You added nvidia-drm.modeset=1 to the line here
GRUB_CMDLINE_LINUX_DEFAULT="nvidia-drm.modeset=1 resume=UUID=*****
Then ran
Then edited the mkinitcpio.conf
sudo nano /etc/mkinitcpio.conf
Added the following to modules=""
MODULES="nvidia"
Then ran
sudo mkinitcpio -P
Reboot
Then add the FullCompositingPipeline to
/etc/X11/xorg.conf.d/20-nvidia.conf
Section "Device"
Identifier "Nvidia Card"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "true"
EndSection
Section "Screen"
Identifier "nvidia"
Option "metamodes" "nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Option "TripleBuffer" "on"
Option "AllowIndirectGLXProtocol" "off"
EndSection
If this doesnât work you may have to start over as you did in the beginning to get there. But maybe @joekamprad has a quicker solution to correct it. Iâm not the expert on some of this.
Edit: I had to do this on one of my systems i built for someone that has Cinnamon desktop. My own system with Xfce which also has an Nvidia didnât have this issue. At least not yet.
after reproducing the steps a second time it seems to work now, tho it still feels like its booting slower than before.
i very small inconvenience was added but its not really a bother may i message you directly about it?
Sure no problem.
wellâŚi wanted to ask them a day later, than saw the problem magically vanished, i have not done anything different, my hardware is cursed sometime.
Well thatâs good news and in the mean time you did learn something regarding your
(nvidia) hardware and how to know it is installed and working correctly.
