Could you paste the output of
cat /var/log/Xorg.0.log
[ 4.763]
X.Org X Server 1.20.10
X Protocol Version 11, Revision 0
[ 4.764] Build Operating System: Linux Arch Linux
[ 4.764] Current Operating System: Linux honnoji 5.9.14-arch1-1 #1 SMP PREEMPT Sat, 12 Dec 2020 14:37:12 +0000 x86_64
[ 4.764] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=69a5b5f2-e9c7-46d1-8dcb-c94c2c4a6c3e rw quiet loglevel=3 nowatchdog
[ 4.764] Build Date: 14 December 2020 12:10:29PM
[ 4.764]
[ 4.764] Current version of pixman: 0.40.0
[ 4.764] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 4.764] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4.764] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 30 11:45:00 2020
[ 4.767] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4.767] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4.769] (==) No Layout section. Using the first Screen section.
[ 4.769] (==) No screen section available. Using defaults.
[ 4.769] (**) |-->Screen "Default Screen Section" (0)
[ 4.769] (**) | |-->Monitor "<default monitor>"
[ 4.769] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 4.769] (**) | |-->Device "Nvidia Card"
[ 4.769] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 4.769] (==) Automatically adding devices
[ 4.769] (==) Automatically enabling devices
[ 4.769] (==) Automatically adding GPU devices
[ 4.769] (==) Automatically binding GPU devices
[ 4.769] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.770] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 4.770] Entry deleted from font path.
[ 4.771] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 4.771] Entry deleted from font path.
[ 4.771] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 4.771] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 4.772] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.772] Entry deleted from font path.
[ 4.772] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 4.772] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 4.772] (==) FontPath set to:
[ 4.772] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4.772] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 4.772] (II) Module ABI versions:
[ 4.772] X.Org ANSI C Emulation: 0.4
[ 4.772] X.Org Video Driver: 24.1
[ 4.772] X.Org XInput driver : 24.1
[ 4.772] X.Org Server Extension : 10.0
[ 4.773] (++) using VT number 7
[ 4.773] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 4.774] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.780] (--) PCI: (0@0:2:0) 8086:3e92:17aa:36eb rev 0, Mem @ 0xa2000000/16777216, 0x80000000/268435456, I/O @ 0x00004000/64
[ 4.781] (--) PCI:*(1@0:0:0) 10de:1c82:1462:3510 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[ 4.781] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.781] (II) LoadModule: "glx"
[ 4.782] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.795] (II) Module glx: vendor="X.Org Foundation"
[ 4.795] compiled for 1.20.10, module version = 1.0.0
[ 4.795] ABI class: X.Org Server Extension, version 10.0
[ 4.795] (II) LoadModule: "nvidia"
[ 4.795] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 4.802] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 4.802] compiled for 1.6.99.901, module version = 1.0.0
[ 4.802] Module class: X.Org Video Driver
[ 4.803] (II) NVIDIA dlloader X Driver 455.45.01 Thu Nov 5 23:01:05 UTC 2020
[ 4.803] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 4.808] (II) Loading sub module "fb"
[ 4.808] (II) LoadModule: "fb"
[ 4.808] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.809] (II) Module fb: vendor="X.Org Foundation"
[ 4.809] compiled for 1.20.10, module version = 1.0.0
[ 4.809] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.809] (II) Loading sub module "wfb"
[ 4.809] (II) LoadModule: "wfb"
[ 4.810] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 4.811] (II) Module wfb: vendor="X.Org Foundation"
[ 4.811] compiled for 1.20.10, module version = 1.0.0
[ 4.811] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.811] (II) Loading sub module "ramdac"
[ 4.811] (II) LoadModule: "ramdac"
[ 4.811] (II) Module "ramdac" already built-in
[ 5.697] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 5.697] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 5.697] (==) NVIDIA(0): RGB weight 888
[ 5.697] (==) NVIDIA(0): Default visual is TrueColor
[ 5.697] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.703] (**) NVIDIA(0): Enabling 2D acceleration
[ 5.703] (II) Loading sub module "glxserver_nvidia"
[ 5.703] (II) LoadModule: "glxserver_nvidia"
[ 5.703] (WW) Warning, couldn't open module glxserver_nvidia
[ 5.703] (EE) NVIDIA: Failed to load module "glxserver_nvidia" (module does not exist, 0)
[ 5.703] (EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
[ 5.703] (EE) NVIDIA(0): log file that the GLX module has been loaded in your X
[ 5.703] (EE) NVIDIA(0): server, and that the module is the NVIDIA GLX module. If
[ 5.703] (EE) NVIDIA(0): you continue to encounter problems, Please try
[ 5.703] (EE) NVIDIA(0): reinstalling the NVIDIA driver.
[ 5.703] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 6.611] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 6.611] (--) NVIDIA(0): DFP-0 (boot)
[ 6.611] (--) NVIDIA(0): DFP-1
[ 6.611] (--) NVIDIA(0): DFP-2
[ 6.611] (--) NVIDIA(0): DFP-3
[ 6.611] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 Ti (GP107-A) at PCI:1:0:0 (GPU-0)
[ 6.611] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 6.611] (--) NVIDIA(0): VideoBIOS: 86.07.39.80.0e
[ 6.611] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 6.641] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 6.641] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 6.641] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 6.670] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 6.670] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 6.670] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 6.670] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 6.671] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 6.671] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 6.671] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 6.671] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 6.671] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 6.681] (==) NVIDIA(0):
[ 6.681] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 6.681] (==) NVIDIA(0): will be used as the requested mode.
[ 6.681] (II) NVIDIA(0): Validated MetaModes:
[ 6.681] (II) NVIDIA(0): "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 6.681] (II) NVIDIA(0): Virtual screen size determined to be 4480 x 1440
[ 6.688] (--) NVIDIA(0): DPI set to (92, 93); computed from "UseEdidDpi" X config
[ 6.688] (--) NVIDIA(0): option
[ 6.688] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 6.688] (II) NVIDIA: access.
[ 6.690] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 6.690] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 6.690] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 6.690] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 6.690] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 6.690] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 6.690] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 6.690] (II) NVIDIA(0): Config Options in the README.
[ 6.704] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
[ 6.756] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 6.756] (==) NVIDIA(0): Backing store enabled
[ 6.756] (==) NVIDIA(0): Silken mouse disabled
[ 6.756] (==) NVIDIA(0): DPMS enabled
[ 6.757] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 6.757] (II) Loading sub module "dri2"
[ 6.757] (II) LoadModule: "dri2"
[ 6.757] (II) Module "dri2" already built-in
[ 6.757] (II) NVIDIA(0): [DRI2] Setup complete
[ 6.757] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 6.758] (II) Initializing extension Generic Event Extension
[ 6.758] (II) Initializing extension SHAPE
[ 6.758] (II) Initializing extension MIT-SHM
[ 6.758] (II) Initializing extension XInputExtension
[ 6.758] (II) Initializing extension XTEST
[ 6.758] (II) Initializing extension BIG-REQUESTS
[ 6.758] (II) Initializing extension SYNC
[ 6.758] (II) Initializing extension XKEYBOARD
[ 6.758] (II) Initializing extension XC-MISC
[ 6.758] (II) Initializing extension SECURITY
[ 6.758] (II) Initializing extension XFIXES
[ 6.758] (II) Initializing extension RENDER
[ 6.758] (II) Initializing extension RANDR
[ 6.759] (II) Initializing extension COMPOSITE
[ 6.759] (II) Initializing extension DAMAGE
[ 6.759] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.759] (II) Initializing extension DOUBLE-BUFFER
[ 6.759] (II) Initializing extension RECORD
[ 6.759] (II) Initializing extension DPMS
[ 6.759] (II) Initializing extension Present
[ 6.759] (II) Initializing extension DRI3
[ 6.759] (II) Initializing extension X-Resource
[ 6.759] (II) Initializing extension XVideo
[ 6.759] (II) Initializing extension XVideo-MotionCompensation
[ 6.759] (II) Initializing extension GLX
[ 6.759] (II) AIGLX: Screen 0 is not DRI2 capable
[ 7.016] (II) IGLX: Loaded and initialized swrast
[ 7.017] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 7.017] (II) Initializing extension XFree86-VidModeExtension
[ 7.017] (II) Initializing extension XFree86-DGA
[ 7.017] (II) Initializing extension XFree86-DRI
[ 7.017] (II) Initializing extension DRI2
[ 7.017] (II) Initializing extension NV-GLX
[ 7.018] (II) Initializing extension NV-CONTROL
[ 7.018] (II) Initializing extension XINERAMA
[ 7.072] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.072] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.072] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.072] (II) LoadModule: "libinput"
[ 7.072] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.077] (II) Module libinput: vendor="X.Org Foundation"
[ 7.077] compiled for 1.20.8, module version = 0.30.0
[ 7.077] Module class: X.Org XInput Driver
[ 7.077] ABI class: X.Org XInput driver, version 24.1
[ 7.077] (II) Using input driver 'libinput' for 'Power Button'
[ 7.077] (**) Power Button: always reports core events
[ 7.077] (**) Option "Device" "/dev/input/event2"
[ 7.077] (**) Option "_source" "server/udev"
[ 7.086] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.086] (II) event2 - Power Button: device is a keyboard
[ 7.086] (II) event2 - Power Button: device removed
[ 7.110] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 7.110] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.110] (**) Option "xkb_model" "pc105"
[ 7.110] (**) Option "xkb_layout" "at"
[ 7.135] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.135] (II) event2 - Power Button: device is a keyboard
[ 7.136] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 7.136] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.136] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.136] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.136] (**) Video Bus: always reports core events
[ 7.136] (**) Option "Device" "/dev/input/event3"
[ 7.136] (**) Option "_source" "server/udev"
[ 7.137] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 7.137] (II) event3 - Video Bus: device is a keyboard
[ 7.138] (II) event3 - Video Bus: device removed
[ 7.230] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3/event3"
[ 7.230] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 7.230] (**) Option "xkb_model" "pc105"
[ 7.230] (**) Option "xkb_layout" "at"
[ 7.234] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 7.234] (II) event3 - Video Bus: device is a keyboard
[ 7.235] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.235] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.235] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.235] (II) Using input driver 'libinput' for 'Power Button'
[ 7.235] (**) Power Button: always reports core events
[ 7.235] (**) Option "Device" "/dev/input/event1"
[ 7.235] (**) Option "_source" "server/udev"
[ 7.238] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.238] (II) event1 - Power Button: device is a keyboard
[ 7.239] (II) event1 - Power Button: device removed
[ 7.270] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 7.270] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 7.270] (**) Option "xkb_model" "pc105"
[ 7.270] (**) Option "xkb_layout" "at"
[ 7.273] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.274] (II) event1 - Power Button: device is a keyboard
[ 7.275] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 7.275] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 7.275] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 7.275] (II) Using input driver 'libinput' for 'Sleep Button'
[ 7.275] (**) Sleep Button: always reports core events
[ 7.275] (**) Option "Device" "/dev/input/event0"
[ 7.275] (**) Option "_source" "server/udev"
[ 7.278] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.278] (II) event0 - Sleep Button: device is a keyboard
[ 7.279] (II) event0 - Sleep Button: device removed
[ 7.310] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 7.310] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 7.310] (**) Option "xkb_model" "pc105"
[ 7.310] (**) Option "xkb_layout" "at"
[ 7.313] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.314] (II) event0 - Sleep Button: device is a keyboard
[ 7.315] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event10)
[ 7.315] (II) No input driver specified, ignoring this device.
[ 7.315] (II) This device may have been added with another device file.
[ 7.316] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event5)
[ 7.316] (II) No input driver specified, ignoring this device.
[ 7.316] (II) This device may have been added with another device file.
[ 7.317] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event6)
[ 7.317] (II) No input driver specified, ignoring this device.
[ 7.317] (II) This device may have been added with another device file.
[ 7.318] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event7)
[ 7.318] (II) No input driver specified, ignoring this device.
[ 7.318] (II) This device may have been added with another device file.
[ 7.319] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event8)
[ 7.319] (II) No input driver specified, ignoring this device.
[ 7.320] (II) This device may have been added with another device file.
[ 7.321] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event9)
[ 7.321] (II) No input driver specified, ignoring this device.
[ 7.321] (II) This device may have been added with another device file.
[ 7.324] (II) config/udev: Adding input device SHANWAN PS3 GamePad (/dev/input/event30)
[ 7.324] (II) No input driver specified, ignoring this device.
[ 7.324] (II) This device may have been added with another device file.
[ 7.326] (II) config/udev: Adding input device SHANWAN PS3 GamePad (/dev/input/js0)
[ 7.326] (II) No input driver specified, ignoring this device.
[ 7.326] (II) This device may have been added with another device file.
[ 7.328] (II) config/udev: Adding input device SHANWAN PS3 GamePad Motion Sensors (/dev/input/event29)
[ 7.328] (II) No input driver specified, ignoring this device.
[ 7.328] (II) This device may have been added with another device file.
[ 7.330] (II) config/udev: Adding input device HOLTEK USB Gaming Keyboard (/dev/input/event20)
[ 7.330] (**) HOLTEK USB Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.330] (**) HOLTEK USB Gaming Keyboard: Applying InputClass "system-keyboard"
[ 7.330] (II) Using input driver 'libinput' for 'HOLTEK USB Gaming Keyboard'
[ 7.330] (**) HOLTEK USB Gaming Keyboard: always reports core events
[ 7.330] (**) Option "Device" "/dev/input/event20"
[ 7.330] (**) Option "_source" "server/udev"
[ 7.334] (II) event20 - HOLTEK USB Gaming Keyboard: is tagged by udev as: Keyboard
[ 7.335] (II) event20 - HOLTEK USB Gaming Keyboard: device is a keyboard
[ 7.335] (II) event20 - HOLTEK USB Gaming Keyboard: device removed
[ 7.363] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:04D9:A1FA.0001/input/input20/event20"
[ 7.364] (II) XINPUT: Adding extended input device "HOLTEK USB Gaming Keyboard" (type: KEYBOARD, id 10)
[ 7.364] (**) Option "xkb_model" "pc105"
[ 7.364] (**) Option "xkb_layout" "at"
[ 7.368] (II) event20 - HOLTEK USB Gaming Keyboard: is tagged by udev as: Keyboard
[ 7.369] (II) event20 - HOLTEK USB Gaming Keyboard: device is a keyboard
[ 7.371] (II) config/udev: Adding input device Logitech G502 HERO SE (/dev/input/event21)
[ 7.372] (**) Logitech G502 HERO SE: Applying InputClass "libinput pointer catchall"
[ 7.372] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE'
[ 7.372] (**) Logitech G502 HERO SE: always reports core events
[ 7.372] (**) Option "Device" "/dev/input/event21"
[ 7.372] (**) Option "_source" "server/udev"
[ 7.430] (II) event21 - Logitech G502 HERO SE: is tagged by udev as: Mouse
[ 7.431] (II) event21 - Logitech G502 HERO SE: device set to 2400 DPI
[ 7.431] (II) event21 - Logitech G502 HERO SE: device is a pointer
[ 7.431] (II) event21 - Logitech G502 HERO SE: device removed
[ 7.483] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:046D:C08B.0002/input/input21/event21"
[ 7.483] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE" (type: MOUSE, id 11)
[ 7.484] (**) Option "AccelerationScheme" "none"
[ 7.484] (**) Logitech G502 HERO SE: (accel) selected scheme none/0
[ 7.484] (**) Logitech G502 HERO SE: (accel) acceleration factor: 2.000
[ 7.484] (**) Logitech G502 HERO SE: (accel) acceleration threshold: 4
[ 7.544] (II) event21 - Logitech G502 HERO SE: is tagged by udev as: Mouse
[ 7.544] (II) event21 - Logitech G502 HERO SE: device set to 2400 DPI
[ 7.544] (II) event21 - Logitech G502 HERO SE: device is a pointer
[ 7.546] (II) config/udev: Adding input device Logitech G502 HERO SE (/dev/input/mouse0)
[ 7.546] (II) No input driver specified, ignoring this device.
[ 7.546] (II) This device may have been added with another device file.
[ 7.548] (II) config/udev: Adding input device Logitech G502 HERO SE Keyboard (/dev/input/event22)
[ 7.548] (**) Logitech G502 HERO SE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.548] (**) Logitech G502 HERO SE Keyboard: Applying InputClass "system-keyboard"
[ 7.548] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Keyboard'
[ 7.548] (**) Logitech G502 HERO SE Keyboard: always reports core events
[ 7.548] (**) Option "Device" "/dev/input/event22"
[ 7.549] (**) Option "_source" "server/udev"
[ 7.553] (II) event22 - Logitech G502 HERO SE Keyboard: is tagged by udev as: Keyboard
[ 7.553] (II) event22 - Logitech G502 HERO SE Keyboard: device is a keyboard
[ 7.553] (II) event22 - Logitech G502 HERO SE Keyboard: device removed
[ 7.577] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input22/event22"
[ 7.577] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Keyboard" (type: KEYBOARD, id 12)
[ 7.577] (**) Option "xkb_model" "pc105"
[ 7.577] (**) Option "xkb_layout" "at"
[ 7.582] (II) event22 - Logitech G502 HERO SE Keyboard: is tagged by udev as: Keyboard
[ 7.582] (II) event22 - Logitech G502 HERO SE Keyboard: device is a keyboard
[ 7.585] (II) config/udev: Adding input device Logitech G502 HERO SE Consumer Control (/dev/input/event23)
[ 7.585] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.585] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "system-keyboard"
[ 7.585] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Consumer Control'
[ 7.585] (**) Logitech G502 HERO SE Consumer Control: always reports core events
[ 7.585] (**) Option "Device" "/dev/input/event23"
[ 7.585] (**) Option "_source" "server/udev"
[ 7.589] (II) event23 - Logitech G502 HERO SE Consumer Control: is tagged by udev as: Keyboard
[ 7.589] (II) event23 - Logitech G502 HERO SE Consumer Control: device is a keyboard
[ 7.589] (II) event23 - Logitech G502 HERO SE Consumer Control: device removed
[ 7.630] (II) libinput: Logitech G502 HERO SE Consumer Control: needs a virtual subdevice
[ 7.630] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input23/event23"
[ 7.630] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Consumer Control" (type: MOUSE, id 13)
[ 7.630] (**) Option "AccelerationScheme" "none"
[ 7.630] (**) Logitech G502 HERO SE Consumer Control: (accel) selected scheme none/0
[ 7.631] (**) Logitech G502 HERO SE Consumer Control: (accel) acceleration factor: 2.000
[ 7.631] (**) Logitech G502 HERO SE Consumer Control: (accel) acceleration threshold: 4
[ 7.635] (II) event23 - Logitech G502 HERO SE Consumer Control: is tagged by udev as: Keyboard
[ 7.635] (II) event23 - Logitech G502 HERO SE Consumer Control: device is a keyboard
[ 7.636] (II) config/udev: Adding input device Logitech G502 HERO SE System Control (/dev/input/event24)
[ 7.636] (**) Logitech G502 HERO SE System Control: Applying InputClass "libinput keyboard catchall"
[ 7.636] (**) Logitech G502 HERO SE System Control: Applying InputClass "system-keyboard"
[ 7.636] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE System Control'
[ 7.636] (**) Logitech G502 HERO SE System Control: always reports core events
[ 7.636] (**) Option "Device" "/dev/input/event24"
[ 7.636] (**) Option "_source" "server/udev"
[ 7.637] (II) event24 - Logitech G502 HERO SE System Control: is tagged by udev as: Keyboard
[ 7.637] (II) event24 - Logitech G502 HERO SE System Control: device is a keyboard
[ 7.637] (II) event24 - Logitech G502 HERO SE System Control: device removed
[ 7.650] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input24/event24"
[ 7.650] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE System Control" (type: KEYBOARD, id 14)
[ 7.650] (**) Option "xkb_model" "pc105"
[ 7.650] (**) Option "xkb_layout" "at"
[ 7.652] (II) event24 - Logitech G502 HERO SE System Control: is tagged by udev as: Keyboard
[ 7.652] (II) event24 - Logitech G502 HERO SE System Control: device is a keyboard
[ 7.652] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event25)
[ 7.652] (**) HTLTEK Gaming keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.652] (**) HTLTEK Gaming keyboard: Applying InputClass "system-keyboard"
[ 7.652] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard'
[ 7.652] (**) HTLTEK Gaming keyboard: always reports core events
[ 7.652] (**) Option "Device" "/dev/input/event25"
[ 7.652] (**) Option "_source" "server/udev"
[ 7.654] (II) event25 - HTLTEK Gaming keyboard: is tagged by udev as: Keyboard
[ 7.654] (II) event25 - HTLTEK Gaming keyboard: device is a keyboard
[ 7.654] (II) event25 - HTLTEK Gaming keyboard: device removed
[ 7.670] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:04D9:A1CD.0004/input/input27/event25"
[ 7.670] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard" (type: KEYBOARD, id 15)
[ 7.670] (**) Option "xkb_model" "pc105"
[ 7.670] (**) Option "xkb_layout" "at"
[ 7.672] (II) event25 - HTLTEK Gaming keyboard: is tagged by udev as: Keyboard
[ 7.672] (II) event25 - HTLTEK Gaming keyboard: device is a keyboard
[ 7.673] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event26)
[ 7.674] (II) No input driver specified, ignoring this device.
[ 7.674] (II) This device may have been added with another device file.
[ 7.674] (II) config/udev: Adding input device HTLTEK Gaming keyboard Consumer Control (/dev/input/event27)
[ 7.675] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.675] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 7.675] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard Consumer Control'
[ 7.675] (**) HTLTEK Gaming keyboard Consumer Control: always reports core events
[ 7.675] (**) Option "Device" "/dev/input/event27"
[ 7.675] (**) Option "_source" "server/udev"
[ 7.677] (II) event27 - HTLTEK Gaming keyboard Consumer Control: is tagged by udev as: Keyboard
[ 7.677] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device is a keyboard
[ 7.677] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device removed
[ 7.690] (II) libinput: HTLTEK Gaming keyboard Consumer Control: needs a virtual subdevice
[ 7.690] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:04D9:A1CD.0005/input/input29/event27"
[ 7.690] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard Consumer Control" (type: MOUSE, id 16)
[ 7.691] (**) Option "AccelerationScheme" "none"
[ 7.691] (**) HTLTEK Gaming keyboard Consumer Control: (accel) selected scheme none/0
[ 7.691] (**) HTLTEK Gaming keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 7.691] (**) HTLTEK Gaming keyboard Consumer Control: (accel) acceleration threshold: 4
[ 7.694] (II) event27 - HTLTEK Gaming keyboard Consumer Control: is tagged by udev as: Keyboard
[ 7.695] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device is a keyboard
[ 7.697] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event28)
[ 7.697] (**) HTLTEK Gaming keyboard: Applying InputClass "libinput pointer catchall"
[ 7.697] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard'
[ 7.697] (**) HTLTEK Gaming keyboard: always reports core events
[ 7.697] (**) Option "Device" "/dev/input/event28"
[ 7.697] (**) Option "_source" "server/udev"
[ 7.757] (II) event28 - HTLTEK Gaming keyboard: is tagged by udev as: Mouse
[ 7.758] (II) event28 - HTLTEK Gaming keyboard: device is a pointer
[ 7.758] (II) event28 - HTLTEK Gaming keyboard: device removed
[ 7.797] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.3/0003:04D9:A1CD.0007/input/input30/event28"
[ 7.797] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard" (type: MOUSE, id 17)
[ 7.797] (**) Option "AccelerationScheme" "none"
[ 7.797] (**) HTLTEK Gaming keyboard: (accel) selected scheme none/0
[ 7.797] (**) HTLTEK Gaming keyboard: (accel) acceleration factor: 2.000
[ 7.797] (**) HTLTEK Gaming keyboard: (accel) acceleration threshold: 4
[ 7.857] (II) event28 - HTLTEK Gaming keyboard: is tagged by udev as: Mouse
[ 7.858] (II) event28 - HTLTEK Gaming keyboard: device is a pointer
[ 7.860] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/mouse1)
[ 7.860] (II) No input driver specified, ignoring this device.
[ 7.860] (II) This device may have been added with another device file.
[ 7.861] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 7.861] (II) No input driver specified, ignoring this device.
[ 7.861] (II) This device may have been added with another device file.
[ 7.862] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 7.862] (II) No input driver specified, ignoring this device.
[ 7.862] (II) This device may have been added with another device file.
[ 7.863] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event13)
[ 7.863] (II) No input driver specified, ignoring this device.
[ 7.863] (II) This device may have been added with another device file.
[ 7.864] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event14)
[ 7.865] (II) No input driver specified, ignoring this device.
[ 7.865] (II) This device may have been added with another device file.
[ 7.866] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[ 7.866] (II) No input driver specified, ignoring this device.
[ 7.866] (II) This device may have been added with another device file.
[ 7.867] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[ 7.867] (II) No input driver specified, ignoring this device.
[ 7.867] (II) This device may have been added with another device file.
[ 7.868] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[ 7.868] (II) No input driver specified, ignoring this device.
[ 7.868] (II) This device may have been added with another device file.
[ 7.869] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[ 7.869] (II) No input driver specified, ignoring this device.
[ 7.869] (II) This device may have been added with another device file.
[ 7.870] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[ 7.870] (II) No input driver specified, ignoring this device.
[ 7.870] (II) This device may have been added with another device file.
[ 7.871] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 7.871] (II) No input driver specified, ignoring this device.
[ 7.871] (II) This device may have been added with another device file.
[ 7.884] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.884] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "system-keyboard"
[ 7.884] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Consumer Control'
[ 7.884] (**) Logitech G502 HERO SE Consumer Control: always reports core events
[ 7.884] (**) Option "Device" "/dev/input/event23"
[ 7.885] (**) Option "_source" "_driver/libinput"
[ 7.885] (II) libinput: Logitech G502 HERO SE Consumer Control: is a virtual subdevice
[ 7.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input23/event23"
[ 7.885] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Consumer Control" (type: KEYBOARD, id 18)
[ 7.885] (**) Option "xkb_model" "pc105"
[ 7.885] (**) Option "xkb_layout" "at"
[ 7.885] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.885] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 7.885] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard Consumer Control'
[ 7.885] (**) HTLTEK Gaming keyboard Consumer Control: always reports core events
[ 7.885] (**) Option "Device" "/dev/input/event27"
[ 7.885] (II) libinput: HTLTEK Gaming keyboard Consumer Control: is a virtual subdevice
[ 7.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:04D9:A1CD.0005/input/input29/event27"
[ 7.885] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard Consumer Control" (type: KEYBOARD, id 19)
[ 7.889] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event26)
[ 7.889] (II) No input driver specified, ignoring this device.
[ 7.889] (II) This device may have been added with another device file.
[ 7.889] (II) config/udev: removing device Logitech G502 HERO SE System Control
[ 7.889] (II) event24 - Logitech G502 HERO SE System Control: device removed
[ 7.917] (II) UnloadModule: "libinput"
[ 7.918] (II) config/udev: Adding input device Logitech G502 HERO SE System Control (/dev/input/event24)
[ 7.918] (**) Logitech G502 HERO SE System Control: Applying InputClass "libinput keyboard catchall"
[ 7.918] (**) Logitech G502 HERO SE System Control: Applying InputClass "system-keyboard"
[ 7.918] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE System Control'
[ 7.918] (**) Logitech G502 HERO SE System Control: always reports core events
[ 7.918] (**) Option "Device" "/dev/input/event24"
[ 7.918] (**) Option "_source" "server/udev"
[ 7.921] (II) event24 - Logitech G502 HERO SE System Control: is tagged by udev as: Keyboard
[ 7.921] (II) event24 - Logitech G502 HERO SE System Control: device is a keyboard
[ 7.921] (II) event24 - Logitech G502 HERO SE System Control: device removed
[ 7.937] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input24/event24"
[ 7.937] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE System Control" (type: KEYBOARD, id 14)
[ 7.937] (**) Option "xkb_model" "pc105"
[ 7.937] (**) Option "xkb_layout" "at"
[ 7.941] (II) event24 - Logitech G502 HERO SE System Control: is tagged by udev as: Keyboard
[ 7.941] (II) event24 - Logitech G502 HERO SE System Control: device is a keyboard
[ 7.942] (II) config/udev: removing device Logitech G502 HERO SE Keyboard
[ 7.942] (II) event22 - Logitech G502 HERO SE Keyboard: device removed
[ 7.953] (II) UnloadModule: "libinput"
[ 7.955] (II) config/udev: Adding input device Logitech G502 HERO SE Keyboard (/dev/input/event22)
[ 7.955] (**) Logitech G502 HERO SE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.955] (**) Logitech G502 HERO SE Keyboard: Applying InputClass "system-keyboard"
[ 7.955] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Keyboard'
[ 7.955] (**) Logitech G502 HERO SE Keyboard: always reports core events
[ 7.955] (**) Option "Device" "/dev/input/event22"
[ 7.955] (**) Option "_source" "server/udev"
[ 7.959] (II) event22 - Logitech G502 HERO SE Keyboard: is tagged by udev as: Keyboard
[ 7.960] (II) event22 - Logitech G502 HERO SE Keyboard: device is a keyboard
[ 7.960] (II) event22 - Logitech G502 HERO SE Keyboard: device removed
[ 7.980] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input22/event22"
[ 7.980] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Keyboard" (type: KEYBOARD, id 12)
[ 7.980] (**) Option "xkb_model" "pc105"
[ 7.980] (**) Option "xkb_layout" "at"
[ 7.981] (II) event22 - Logitech G502 HERO SE Keyboard: is tagged by udev as: Keyboard
[ 7.981] (II) event22 - Logitech G502 HERO SE Keyboard: device is a keyboard
[ 7.981] (II) config/udev: removing device HOLTEK USB Gaming Keyboard
[ 7.981] (II) event20 - HOLTEK USB Gaming Keyboard: device removed
[ 8.003] (II) UnloadModule: "libinput"
[ 8.004] (II) config/udev: Adding input device HOLTEK USB Gaming Keyboard (/dev/input/event20)
[ 8.004] (**) HOLTEK USB Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.004] (**) HOLTEK USB Gaming Keyboard: Applying InputClass "system-keyboard"
[ 8.004] (II) Using input driver 'libinput' for 'HOLTEK USB Gaming Keyboard'
[ 8.004] (**) HOLTEK USB Gaming Keyboard: always reports core events
[ 8.004] (**) Option "Device" "/dev/input/event20"
[ 8.004] (**) Option "_source" "server/udev"
[ 8.005] (II) event20 - HOLTEK USB Gaming Keyboard: is tagged by udev as: Keyboard
[ 8.005] (II) event20 - HOLTEK USB Gaming Keyboard: device is a keyboard
[ 8.005] (II) event20 - HOLTEK USB Gaming Keyboard: device removed
[ 8.023] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:04D9:A1FA.0001/input/input20/event20"
[ 8.023] (II) XINPUT: Adding extended input device "HOLTEK USB Gaming Keyboard" (type: KEYBOARD, id 10)
[ 8.023] (**) Option "xkb_model" "pc105"
[ 8.023] (**) Option "xkb_layout" "at"
[ 8.025] (II) event20 - HOLTEK USB Gaming Keyboard: is tagged by udev as: Keyboard
[ 8.025] (II) event20 - HOLTEK USB Gaming Keyboard: device is a keyboard
[ 8.025] (II) config/udev: removing device Logitech G502 HERO SE Consumer Control
[ 8.025] (II) UnloadModule: "libinput"
[ 8.025] (II) event23 - Logitech G502 HERO SE Consumer Control: device removed
[ 8.043] (II) UnloadModule: "libinput"
[ 8.044] (II) config/udev: Adding input device Logitech G502 HERO SE Consumer Control (/dev/input/event23)
[ 8.044] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.044] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "system-keyboard"
[ 8.044] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Consumer Control'
[ 8.044] (**) Logitech G502 HERO SE Consumer Control: always reports core events
[ 8.044] (**) Option "Device" "/dev/input/event23"
[ 8.044] (**) Option "_source" "server/udev"
[ 8.045] (II) event23 - Logitech G502 HERO SE Consumer Control: is tagged by udev as: Keyboard
[ 8.045] (II) event23 - Logitech G502 HERO SE Consumer Control: device is a keyboard
[ 8.045] (II) event23 - Logitech G502 HERO SE Consumer Control: device removed
[ 8.060] (II) libinput: Logitech G502 HERO SE Consumer Control: needs a virtual subdevice
[ 8.060] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input23/event23"
[ 8.060] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Consumer Control" (type: MOUSE, id 13)
[ 8.060] (**) Option "AccelerationScheme" "none"
[ 8.060] (**) Logitech G502 HERO SE Consumer Control: (accel) selected scheme none/0
[ 8.060] (**) Logitech G502 HERO SE Consumer Control: (accel) acceleration factor: 2.000
[ 8.060] (**) Logitech G502 HERO SE Consumer Control: (accel) acceleration threshold: 4
[ 8.061] (II) event23 - Logitech G502 HERO SE Consumer Control: is tagged by udev as: Keyboard
[ 8.061] (II) event23 - Logitech G502 HERO SE Consumer Control: device is a keyboard
[ 8.061] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.061] (**) Logitech G502 HERO SE Consumer Control: Applying InputClass "system-keyboard"
[ 8.061] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE Consumer Control'
[ 8.061] (**) Logitech G502 HERO SE Consumer Control: always reports core events
[ 8.061] (**) Option "Device" "/dev/input/event23"
[ 8.061] (**) Option "_source" "_driver/libinput"
[ 8.061] (II) libinput: Logitech G502 HERO SE Consumer Control: is a virtual subdevice
[ 8.061] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:046D:C08B.0003/input/input23/event23"
[ 8.061] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE Consumer Control" (type: KEYBOARD, id 18)
[ 8.061] (**) Option "xkb_model" "pc105"
[ 8.061] (**) Option "xkb_layout" "at"
[ 8.061] (II) config/udev: removing device HTLTEK Gaming keyboard Consumer Control
[ 8.062] (II) UnloadModule: "libinput"
[ 8.062] (II) config/udev: removing device HTLTEK Gaming keyboard Consumer Control
[ 8.062] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device removed
[ 8.073] (II) UnloadModule: "libinput"
[ 8.074] (II) config/udev: Adding input device HTLTEK Gaming keyboard Consumer Control (/dev/input/event27)
[ 8.074] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.074] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 8.074] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard Consumer Control'
[ 8.074] (**) HTLTEK Gaming keyboard Consumer Control: always reports core events
[ 8.074] (**) Option "Device" "/dev/input/event27"
[ 8.074] (**) Option "_source" "server/udev"
[ 8.075] (II) event27 - HTLTEK Gaming keyboard Consumer Control: is tagged by udev as: Keyboard
[ 8.075] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device is a keyboard
[ 8.075] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device removed
[ 8.100] (II) libinput: HTLTEK Gaming keyboard Consumer Control: needs a virtual subdevice
[ 8.100] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:04D9:A1CD.0005/input/input29/event27"
[ 8.100] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard Consumer Control" (type: MOUSE, id 16)
[ 8.100] (**) Option "AccelerationScheme" "none"
[ 8.100] (**) HTLTEK Gaming keyboard Consumer Control: (accel) selected scheme none/0
[ 8.100] (**) HTLTEK Gaming keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 8.100] (**) HTLTEK Gaming keyboard Consumer Control: (accel) acceleration threshold: 4
[ 8.101] (II) event27 - HTLTEK Gaming keyboard Consumer Control: is tagged by udev as: Keyboard
[ 8.101] (II) event27 - HTLTEK Gaming keyboard Consumer Control: device is a keyboard
[ 8.102] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.102] (**) HTLTEK Gaming keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 8.102] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard Consumer Control'
[ 8.102] (**) HTLTEK Gaming keyboard Consumer Control: always reports core events
[ 8.102] (**) Option "Device" "/dev/input/event27"
[ 8.102] (**) Option "_source" "_driver/libinput"
[ 8.102] (II) libinput: HTLTEK Gaming keyboard Consumer Control: is a virtual subdevice
[ 8.102] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:04D9:A1CD.0005/input/input29/event27"
[ 8.102] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard Consumer Control" (type: KEYBOARD, id 19)
[ 8.102] (**) Option "xkb_model" "pc105"
[ 8.102] (**) Option "xkb_layout" "at"
[ 8.102] (II) config/udev: removing device HTLTEK Gaming keyboard
[ 8.102] (II) event25 - HTLTEK Gaming keyboard: device removed
[ 8.134] (II) UnloadModule: "libinput"
[ 8.136] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event25)
[ 8.136] (**) HTLTEK Gaming keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.136] (**) HTLTEK Gaming keyboard: Applying InputClass "system-keyboard"
[ 8.136] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard'
[ 8.136] (**) HTLTEK Gaming keyboard: always reports core events
[ 8.136] (**) Option "Device" "/dev/input/event25"
[ 8.136] (**) Option "_source" "server/udev"
[ 8.140] (II) event25 - HTLTEK Gaming keyboard: is tagged by udev as: Keyboard
[ 8.140] (II) event25 - HTLTEK Gaming keyboard: device is a keyboard
[ 8.141] (II) event25 - HTLTEK Gaming keyboard: device removed
[ 8.178] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:04D9:A1CD.0004/input/input27/event25"
[ 8.178] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard" (type: KEYBOARD, id 15)
[ 8.178] (**) Option "xkb_model" "pc105"
[ 8.178] (**) Option "xkb_layout" "at"
[ 8.183] (II) event25 - HTLTEK Gaming keyboard: is tagged by udev as: Keyboard
[ 8.183] (II) event25 - HTLTEK Gaming keyboard: device is a keyboard
[ 8.186] (II) config/udev: Adding input device SHANWAN PS3 GamePad (/dev/input/js0)
[ 8.186] (II) No input driver specified, ignoring this device.
[ 8.186] (II) This device may have been added with another device file.
[ 8.186] (II) config/udev: removing device HTLTEK Gaming keyboard
[ 8.187] (II) event28 - HTLTEK Gaming keyboard: device removed
[ 8.242] (II) UnloadModule: "libinput"
[ 8.244] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/event28)
[ 8.244] (**) HTLTEK Gaming keyboard: Applying InputClass "libinput pointer catchall"
[ 8.244] (II) Using input driver 'libinput' for 'HTLTEK Gaming keyboard'
[ 8.244] (**) HTLTEK Gaming keyboard: always reports core events
[ 8.244] (**) Option "Device" "/dev/input/event28"
[ 8.244] (**) Option "_source" "server/udev"
[ 8.304] (II) event28 - HTLTEK Gaming keyboard: is tagged by udev as: Mouse
[ 8.304] (II) event28 - HTLTEK Gaming keyboard: device is a pointer
[ 8.305] (II) event28 - HTLTEK Gaming keyboard: device removed
[ 8.377] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.3/0003:04D9:A1CD.0007/input/input30/event28"
[ 8.377] (II) XINPUT: Adding extended input device "HTLTEK Gaming keyboard" (type: MOUSE, id 17)
[ 8.377] (**) Option "AccelerationScheme" "none"
[ 8.377] (**) HTLTEK Gaming keyboard: (accel) selected scheme none/0
[ 8.377] (**) HTLTEK Gaming keyboard: (accel) acceleration factor: 2.000
[ 8.377] (**) HTLTEK Gaming keyboard: (accel) acceleration threshold: 4
[ 8.437] (II) event28 - HTLTEK Gaming keyboard: is tagged by udev as: Mouse
[ 8.438] (II) event28 - HTLTEK Gaming keyboard: device is a pointer
[ 8.440] (II) config/udev: Adding input device HTLTEK Gaming keyboard (/dev/input/mouse1)
[ 8.440] (II) No input driver specified, ignoring this device.
[ 8.440] (II) This device may have been added with another device file.
[ 8.441] (II) config/udev: Adding input device SHANWAN PS3 GamePad Motion Sensors (/dev/input/event29)
[ 8.442] (II) No input driver specified, ignoring this device.
[ 8.442] (II) This device may have been added with another device file.
[ 8.442] (II) config/udev: removing device Logitech G502 HERO SE
[ 8.442] (II) event21 - Logitech G502 HERO SE: device removed
[ 8.510] (II) UnloadModule: "libinput"
[ 8.512] (II) config/udev: Adding input device Logitech G502 HERO SE (/dev/input/event21)
[ 8.512] (**) Logitech G502 HERO SE: Applying InputClass "libinput pointer catchall"
[ 8.512] (II) Using input driver 'libinput' for 'Logitech G502 HERO SE'
[ 8.512] (**) Logitech G502 HERO SE: always reports core events
[ 8.512] (**) Option "Device" "/dev/input/event21"
[ 8.512] (**) Option "_source" "server/udev"
[ 8.570] (II) event21 - Logitech G502 HERO SE: is tagged by udev as: Mouse
[ 8.571] (II) event21 - Logitech G502 HERO SE: device set to 2400 DPI
[ 8.571] (II) event21 - Logitech G502 HERO SE: device is a pointer
[ 8.571] (II) event21 - Logitech G502 HERO SE: device removed
[ 8.657] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:046D:C08B.0002/input/input21/event21"
[ 8.657] (II) XINPUT: Adding extended input device "Logitech G502 HERO SE" (type: MOUSE, id 11)
[ 8.657] (**) Option "AccelerationScheme" "none"
[ 8.657] (**) Logitech G502 HERO SE: (accel) selected scheme none/0
[ 8.657] (**) Logitech G502 HERO SE: (accel) acceleration factor: 2.000
[ 8.657] (**) Logitech G502 HERO SE: (accel) acceleration threshold: 4
[ 8.716] (II) event21 - Logitech G502 HERO SE: is tagged by udev as: Mouse
[ 8.716] (II) event21 - Logitech G502 HERO SE: device set to 2400 DPI
[ 8.717] (II) event21 - Logitech G502 HERO SE: device is a pointer
[ 8.717] (II) config/udev: Adding input device SHANWAN PS3 GamePad (/dev/input/event30)
[ 8.717] (II) No input driver specified, ignoring this device.
[ 8.717] (II) This device may have been added with another device file.
[ 8.717] (II) config/udev: Adding input device Logitech G502 HERO SE (/dev/input/mouse0)
[ 9.012] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.012] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.012] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.013] (--) NVIDIA(GPU-0):
[ 9.042] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.042] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.042] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.042] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.042] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.042] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.042] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.042] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.042] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.131] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.131] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.131] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.161] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.161] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.161] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.161] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.161] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.161] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.161] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.161] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.161] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.193] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.193] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.193] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.222] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.222] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.223] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.223] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.223] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.223] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.223] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.223] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.223] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.253] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.253] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.253] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.282] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.282] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.282] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.282] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.282] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.282] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.282] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.282] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.282] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.312] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.312] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.312] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.342] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.342] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.342] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.342] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.342] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.342] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.342] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.342] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.342] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.513] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.513] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.513] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 9.543] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 9.543] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 9.543] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 9.543] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.543] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.543] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.543] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.543] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.543] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.546] (II) NVIDIA(0): Setting mode "DVI-D-0: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 9.599] (II) NVIDIA(0): Setting mode "DVI-D-0: nvidia-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 9.972] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 9.972] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 9.972] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 10.002] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 10.002] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 10.002] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 10.002] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 10.002] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 10.002] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 10.002] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 10.002] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 10.002] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 12.442] (EE) event21 - Logitech G502 HERO SE: client bug: event processing lagging behind by 11ms, your system is too slow
[ 22.621] (EE) event21 - Logitech G502 HERO SE: client bug: event processing lagging behind by 15ms, your system is too slow
[ 23.181] (EE) event21 - Logitech G502 HERO SE: client bug: event processing lagging behind by 27ms, your system is too slow
[ 25.344] (EE) event21 - Logitech G502 HERO SE: client bug: event processing lagging behind by 27ms, your system is too slow
[ 25.344] (EE) client bug: timer event21 debounce: scheduled expiry is in the past (-2ms), your system is too slow
[ 25.344] (EE) client bug: timer event21 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[ 26.228] (EE) event21 - Logitech G502 HERO SE: client bug: event processing lagging behind by 11ms, your system is too slow
[ 26.228] (EE) event21 - Logitech G502 HERO SE: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 36.212] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 36.212] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 36.212] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 36.241] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 36.241] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 36.241] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 36.241] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 36.241] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 36.241] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 36.242] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 36.242] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 36.242] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 36.287] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 36.287] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 36.287] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 36.317] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 36.317] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 36.317] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 36.317] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 36.317] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 36.317] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 36.317] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 36.317] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 36.317] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 44.065] (II) NVIDIA(0): Setting mode "DVI-D-0: nvidia-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +2560+360 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 44.116] (II) NVIDIA(0): Setting mode "DVI-D-0: 2560x1440_75 @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +2560+360 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 44.232] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 44.232] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 44.232] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 44.261] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 44.261] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 44.261] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 44.261] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 44.261] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 44.261] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 44.262] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 44.262] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 44.262] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 44.294] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 44.294] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 44.294] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 44.323] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 44.323] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 44.323] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 44.323] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 44.323] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 44.323] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 44.324] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 44.324] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 44.324] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 44.360] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 44.360] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 44.360] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 44.389] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 44.389] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 44.389] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 44.389] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 44.389] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 44.389] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 44.389] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 44.389] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 44.389] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 319.330] (EE) event25 - HTLTEK Gaming keyboard: client bug: event processing lagging behind by 19ms, your system is too slow
[ 320.510] (EE) client bug: timer event21 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[ 320.510] (EE) client bug: timer event21 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[ 337.253] (II) event21 - Logitech G502 HERO SE: SYN_DROPPED event - some input events have been lost.
[ 337.253] (EE) event25 - HTLTEK Gaming keyboard: client bug: event processing lagging behind by 25ms, your system is too slow
[ 820.161] (EE) client bug: timer event21 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[ 820.161] (EE) client bug: timer event21 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[ 902.976] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 902.976] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 902.976] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 903.006] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 903.006] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 903.006] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 903.006] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 903.006] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 903.006] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 903.007] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 903.007] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 903.007] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 903.007] (EE) client bug: timer event21 debounce: scheduled expiry is in the past (-9ms), your system is too slow
[ 903.038] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): connected
[ 903.038] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): Internal TMDS
[ 903.038] (--) NVIDIA(GPU-0): Lenovo Group Limited LEN D32q-20B (DFP-0): 600.0 MHz maximum pixel clock
[ 903.068] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): connected
[ 903.068] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): Internal TMDS
[ 903.068] (--) NVIDIA(GPU-0): LG Electronics 32inch LG FHD (DFP-1): 600.0 MHz maximum pixel clock
[ 903.068] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 903.068] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 903.068] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 903.068] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 903.068] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 903.068] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 903.134] (EE) client bug: timer event21 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 925.487] (EE) event25 - HTLTEK Gaming keyboard: client bug: event processing lagging behind by 20ms, your system is too slow
[ 955.910] (EE) event25 - HTLTEK Gaming keyboard: client bug: event processing lagging behind by 13ms, your system is too slow
@AmandaONeill Can you please highlight the text in your previous post and then click the </> button? it will make it easier to read. Thank you!
oooh thats how you format it, thank you i never noticed it
No worries, when I first started to post on Discourse, I had to learn these thing as well.
Could you paste the output of
ls /etc/X11
Did you boot with or without parameter nomodeset
errr, thats about it
xinit xorg.conf.d
i can also boot normally again which i did
there seem to be a change on xorg causing that you need a switcher software sided to choose one or the other igpu/discrete on optimus systems.
And I see that you may do not have the xf86-video-intel driver installed? and only have the nvidia driver? that could cause the blank screen as system may try to use intel igpu and failed on that.
most common option:
after looking it up the xf86-video-intel driver is also installed.
this link is what i have tried before ands it caused my to nto be able to boot, tho what i did notice is that i still have bbswitch which apparently causes issues
the question is, do i need to do anything else other than uninstalling that specific compnent before i can continue with this short guide?
guide say that:
Warning:
it can be that optimus-manager is not showing up in GTK environments (I do not know why) but users say in this cases that optimus-manager-qt is working nice.
to clarify since your quote from the link was what prompted the previous post, are my two options here that
a. delete bbswitch and use optimus-manager or
b. keep bbswitch and use optimus-manager-gt instead?
i mention to things only, that having bbswitch and / or acpi_call installed can cause issues with optimus-manager ( optimus-manager-qt is depending on optimus-manager) so using optimus manager needs to have them uninstalled, if it does not work for you.
bbswitch and acpi_call are both optional dependencies for optimus-manager so not needed in all cases.
ooh i see i have just missunderstood than, i will uninstall bbswitch and see how it goes
no dice, even after removing bbswitch i had the same porblem
after removing it again i had the same notif telling me i dont have hardware acceleration turned on
sadly impossible, as i cant get into the desktop, neither with normal boot nor with nomodeset as long as optimus is installed
@AmandaONeill I am going to suggest that you give this kernel parameter a try. You do not need to be on your desktop to add it.
acpi_osi='Windows 2018'
Sometimes the black screen is caused by an ACPI (Advanced Configuration and Power Interface) error.
To add the parameter:
Press “E” on the grub screen and find the line with the “quiet” parameter.
Replace the word “quiet” with the parameter acpi_osi='Windows 2018'
Press F-10 to boot your computer.
This will not change the grub config permanently. If you find that this parameter works, then you will need to add it to grub.
could it be that nvidia-discrete-gpu is disabled inside efi-firmware (Bios) ?
sadly did not work
i tried to find this or any nvidia setting in my bios for that matter but did not find anything
and here is the full notif i have now after installing the nvidia driver via the recommend method
