Is it possible to choose which greeter do i want to install in Calamares?
As I see, we can install only slick one, and then change it after the system will be installed.
You could add your preferred greeter (or any other packages you want to have in your installed system) to the user_pkglist.txt
that you find in the home directory of the liveuser.
Then launch Calamares and uncheck the box for the packages you don’t want to install.
This may help too:
https://discovery.endeavouros.com/installation/customizing-the-endeavouros-install-process
