Graphics Driver problem after update (multipule systems affected)
Need some assistance tracking down an issue that affected over half of my home systems after an update
Symptoms: After a yay update, ALL my computers that had Intel/AMD graphics suddenly lost hardware acceleration. (That’s 5 systems). Everything from a 5700 XT to the integrated graphics on a i5-3470. Now, that last one was never great but it didn’t used to max out my CPU just to watch a youtube vid (and be choppy at that). Another symptom is that cool-retro-term (my term of choice) refused to open with the following message:
libEGL warning: failed to get driver name for fd 19
failed to get driver name for fd 20
libEGL warning: egl: failed to create dri2 screen
Using a variable-width font in the terminal.  This may cause performance degradation and display/alignment errors.
Both point size and pixel size set. Using pixel size.
QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlagsQSurfaceFormat::FormatOption(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize 8, stencilBufferSize 8, samples -1, swapBehavior QSurfaceFormat::DoubleBuffer, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile  QSurfaceFormat::NoProfile)
Aborted                    (core dumped) cool-retro-term
Other programs that rely on hardware acceleration (such as moonlight) will pester about there not being any.
Remediation: I tried everything I could think of; Checking to make sure amdgpu module was loaded, verified correct drivers were installed and not somehow uninstalled during the update. Looked over the logs with journalctl to make sure there wasn’t some hardware issue. So far, the only fix was reinstalling the system. I would prefer not to do that on the four remaining.
As stated before, the hardware is all over the place. Older DIY, three dell desktop/minipc systems of various models, and an acer laptop. The only systems that were not affected was the gaming rigs with nvidia cards and one All-in-one that had a mobile nvidia chip.
Let me know what info you need and how to get it and I will dump it here.
Could you at least tell us which packages were upgraded and when?
Edit: You can install pacutils and use the command paclog to get that info.
Looks like you could be having the same problem as me and others in this post: OpenGL using llvmpipe as renderer, ignoring RX 6750 XT?
Looks like a very similar error output and core dump as I am getting over here:
Still no solution on my end after at least a couple of weeks.
Edit: Thanks to the discussion on this thread, I found my issue was nomachine. Uninstalling solved it. Here’s the link to my solution. Hope it helps you:
