Hi all,
Fresh installation and i have some weird graphics glitches on my KDE .
More details about my hardware :
#################### inxi -Fxxc0z ########################
Kernel: 6.12.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: LENOVO product: 82SN v: IdeaPad 5 Pro 16ARH7 serial: <superuser required>
Chassis: type: 10 v: IdeaPad 5 Pro 16ARH7 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
part-nu: LENOVO_MT_82SN_BU_idea_FM_IdeaPad 5 Pro 16ARH7 UEFI: LENOVO v: J4CN38WW date: 06/08/2023
Battery:
ID-1: BAT0 charge: 73.7 Wh (96.3%) condition: 76.5/75.0 Wh (102.0%) volts: 17.3 min: 15.4
model: LENOVO AP16L5J serial: <filter> status: charging
Info: 8-core model: AMD Ryzen 7 6800HS Creator Edition bits: 64 type: MT MCP arch: Zen 3+ rev: 1
cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1342 min/max: 400/4785 boost: enabled cores: 1: 1342 2: 1342 3: 1342 4: 1342
5: 1342 6: 1342 7: 1342 8: 1342 9: 1342 10: 1342 11: 1342 12: 1342 13: 1342 14: 1342 15: 1342
16: 1342 bogomips: 102254
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2,
DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681
temp: 39.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
bus-ID: 5-1:2 chip-ID: 174f:1811
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4 compositor: kwin_wayland
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: eDP-1 res: 2048x1280 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi rembrandt LLVM 18.1.8 DRM 3.59
6.12.7-arch1-1) device-ID: 1002:1681 display-ID: :1.0
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.12.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo driver: rtw89_8852be
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:b852
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s lanes: 1
bus-ID: 3-3:3 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled rfk-block: hardware: no
software: no address: N/A
Local Storage: total: 1.04 TiB used: 7.09 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDKBA1T0TFH size: 953.87 GiB speed: 63.2 Gb/s
lanes: 4 serial: <filter> temp: 28.9 C
ID-2: /dev/sda vendor: Kingston model: DataTraveler 3.0 size: 115.59 GiB type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 serial: <filter>
ID-1: / size: 952.86 GiB used: 7.06 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 32.6 MiB (3.2%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 952.86 GiB used: 7.06 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2
ID-4: /var/log size: 952.86 GiB used: 7.06 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2 file: /swap/swapfile
System Temperatures: cpu: 43.4 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 13.34 GiB used: 2.74 GiB (20.5%)
Processes: 354 Power: uptime: 29m wakeups: 0 Init: systemd v: 257 default: graphical
Packages: pm: pacman pkgs: 1052 Compilers: gcc: 14.2.1 Client: shell wrapper v: 5.2.37-release
inxi: 3.3.36
#################### hwinfo --short ########################
cpu:
AMD Ryzen 7 6800HS Creator Edition, 2095 MHz
AMD Ryzen 7 6800HS Creator Edition, 2084 MHz
AMD Ryzen 7 6800HS Creator Edition, 2075 MHz
AMD Ryzen 7 6800HS Creator Edition, 1094 MHz
AMD Ryzen 7 6800HS Creator Edition, 2086 MHz
AMD Ryzen 7 6800HS Creator Edition, 4090 MHz
AMD Ryzen 7 6800HS Creator Edition, 3630 MHz
AMD Ryzen 7 6800HS Creator Edition, 3216 MHz
AMD Ryzen 7 6800HS Creator Edition, 2933 MHz
AMD Ryzen 7 6800HS Creator Edition, 2900 MHz
AMD Ryzen 7 6800HS Creator Edition, 4030 MHz
AMD Ryzen 7 6800HS Creator Edition, 2080 MHz
AMD Ryzen 7 6800HS Creator Edition, 2096 MHz
AMD Ryzen 7 6800HS Creator Edition, 2100 MHz
keyboard:
/dev/input/event5 Logitech USB Receiver
/dev/input/event3 AT Translated Set 2 keyboard
mouse:
/dev/input/mice Logitech USB Receiver
/dev/input/mice ELAN2841:00 04F3:31AD Mouse
/dev/input/mice ELAN2841:00 04F3:31AD Touchpad
monitor:
CSOT T3 LCD Monitor
graphics card:
ATI VGA compatible controller
sound:
ATI Audio device
AMD Family 17h (Models 10h-1fh) HD Audio Controller
storage:
Micron Non-Volatile memory controller
network:
wlan0 Realtek WLAN controller
network interface:
lo Loopback network interface
wlan0 WLAN network interface
disk:
/dev/nvme0n1 Micron MTFDKBA1T0TFH
/dev/sda Kingston DataTraveler 3.0
partition:
/dev/nvme0n1p1 Partition
/dev/nvme0n1p2 Partition
/dev/sda1 Partition
/dev/sda2 Partition
usb controller:
AMD USB Controller
AMD USB Controller
AMD USB Controller
AMD USB Controller
AMD USB Controller
bios:
BIOS
bridge:
AMD Host bridge
AMD Host bridge
AMD Host bridge
AMD Host bridge
AMD PCI bridge
AMD Host bridge
AMD FCH LPC Bridge
AMD PCI bridge
AMD Host bridge
AMD Host bridge
AMD PCI bridge
AMD Host bridge
AMD Host bridge
AMD Host bridge
AMD PCI bridge
AMD Host bridge
AMD PCI bridge
AMD Host bridge
AMD Host bridge
AMD Host bridge
hub:
Linux Foundation 3.0 root hub
Linux Foundation 2.0 root hub
memory:
Main Memory
bluetooth:
unknown:
FPU
DMA controller
PIC
Keyboard controller
AMD Raven/Raven2/FireFlight/Renoir Audio Processor
O2 Micro SD/MMC Card Reader Controller
AMD IOMMU
AMD VanGogh PSP/CCP
AMD FCH SMBus Controller
video is here : https://drive.google.com/file/d/11L4LCgvJcokxLEU8Rje7CX2EpkbDY2tj/view?usp=sharing
