Graphic driver installation for old Alienware M11xR1
Well, I had Kernel 6.6 LTS installed, but it didn’t change the resolution problem and even with Nouveau driver the system crashed regularly. I then installed a modified nvidia driver for kernel 6.6 from Github, but only got a black screen…
To be honest, I’m now fed up and have installed the Intel driver for H.264, which basically works. However, the video acceleration only works under X11 and not under Wayland.
The problem with the Intel graphics is that I can’t adjust the brightness. Previously this was only possible with the nvidia graphics.
Are there any ideas on how I can adjust the brightness of the laptop screen?
inxi output:
inxi -Gxaa
  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Dell
    driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports:
    active: LVDS-1 empty: DP-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:2a42
    class-ID: 0300
  Device-2: NVIDIA GT215M [GeForce GT 335M] vendor: Dell driver: nouveau
    v: kernel non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last:
    release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
    built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
    active: none empty: DP-2, HDMI-A-1, LVDS-2, VGA-2 bus-ID: 01:00.0
    chip-ID: 10de:0caf class-ID: 0300 temp: 49.0 C
  Device-3: Suyin Laptop_Integrated_Webcam_1.3M driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 064e:8101
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: modesetting
    alternate: fbdev,intel,nouveau,nv,vesa dri: crocus,nouveau gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 model: AU Optronics 0x105c built: 2010 res: 1366x768
    hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6")
    ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
    device: 0 drv: crocus device: 1 egl: 1.4 drv: nouveau device: 2 drv: swrast
    gbm: drv: crocus surfaceless: drv: crocus x11: drv: crocus
    inactive: wayland
  API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 24.1.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Mobile Intel GM45 Express (CTG)
    device-ID: 8086:2a42 memory: 1.46 GiB unified: yes
Unfortunately it seems like you need newer updated hardware. When you installed using nouveau it had the correct resolution for this laptop which is 1366x768
I’d suggest reading this if you haven’t already: https://wiki.archlinux.org/title/Intel_graphics
