mbod
April 23, 2021, 4:44am
#1
Yesterday evening a new mesa update to version 21.0.3-1 came in which broke my graphics (amdgpu). I see graphics glitches all over the screen. I see the graphics glitches in gdm, lightdm, gnome and xfce.
Example:
Downgrading all mesa packages to previous version 21.0.2-1 fixes it.
(mesa lib32-mesa libva-mesa-driver mesa-vdpau
pebcak
April 23, 2021, 5:57am
#2
5.11.16-zen1-1-zen
Graphics: Device-1: AMD Renoir driver: amdgpu v: kernel
5.11.16-zen1-1-zen
[2021-04-23T07:41:44+0200] [ALPM] upgraded mesa (21.0.2-1 -> 21.0.3-1)
No issues on my end in Cinnamon after the update. But then I don’t have the other packages on my system.
mbod
April 23, 2021, 6:16am
#3
I have filed bug reports for it:
https://bugs.archlinux.org/task/70554#comment199086
EDIT:
I tested also without libva-mesa-driver
and mesa-vdpau
. They have no influence on the bug. The mesa
package alone is introducing the bug.
Strangely enough - no problems noted on my all AMD system. Must be selective!
inxi -G
02:31:01 WD= [~/Downloads]
└───freebird@nest ─▶$ inxi -G
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] driver: amdgpu
v: kernel
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa resolution:
1: 3840x2160~60Hz 2: 1800x2400~60Hz
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0 5.11.16-arch1-1 LLVM 11.1.0) v: 4.6 Mesa 21.0.3
btw - lightdm and xfce…
mbod
April 23, 2021, 8:39am
#5
My Graphcis setup. Just for the records.
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu
v: kernel
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu unloaded: fbdev,modesetting,vesa
resolution: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.40.0 5.11.16-zen1-1-zen LLVM 11.1.0) v: 4.6 Mesa 21.0.2
No issues here either on Polaris GPU with zen kernel.
Must be a unique combination of GPU model / family, BIOS version + config, and kernel driver + config.
Just finished checking out another (AMD) system - no problems found…
inx-i -G
┌05:17:18 WD= [~]
└───freebird@aerie ─▶$ inxi -G
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] driver: amdgpu v: kernel
resolution: 3840x2160~60Hz
Also
extra/mesa 21.0.3-1 (17.2 MiB 90.7 MiB) (Installed)
and
┌05:18:52 WD= [~]
└───freebird@aerie ─▶$ uname -rso
Linux 5.11.16-arch1-1 GNU/Linux
I had the exact same error with my RX5600XT. Downgrading mesa and lib32-mesa did the job.
No issue on my RX590 on KDE Plasma.
Edit:
[ricklinux@Arch ~]$ inxi -Ga
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 2d:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting alternate: ati,fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9")
s-diag: 523mm (20.6")
OpenGL: renderer: Radeon RX 590 Series (POLARIS10 DRM 3.40.0 5.11.16-arch1-1
LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Yeah… Also an RX5600XT here with the same issue…
also had to downgrade those packages
There’s a newer linux-firmware
in testing (20210315.3568f96-2) with a couple of amdgpu-related changes:
committed 06:09AM - 23 Apr 21 UTC
git-svn-id: file:///srv/repos/svn-packages/svn@413527 eb2447ed-0c53-47e4-bac8-5… bc4a241df78
Thank you mbod for picking up on this issue. I also have it, though had not identified the cause. (another win for the EndeavourOS forum)
…and today’s updated mesa 21.0.3-2 solves the issue.
I was just going to see if anyone tried the latest update as i just got it also.
mbod
April 25, 2021, 7:20am
#15
Issue is fixed with mesa version 21.0.3-2
system
closed
April 27, 2021, 7:20am
#16
