Hi,
I’m running Manjaro Gnome as the host OS & using Gnome Boxes.
The Endeavour installer (online) gets stuck at 35% & becomes unresponsive. At this point my laptop starts to get hot & the fans kick up - this is unusual, it never gets worked up.
I waited about 15 mins at the 35% mark, but it doesnt progress. I have to force quit the process.
I tried twice over, making a new vm, but the result was the same.
I selected “Unknown OS” for the vm in Boxes because there is no choice for Endeavour - should I select something different?
hmm, im stuck.
There was a log but it was one where i had launched the installer & then cancel before actually beginning any install process - i did that just before posting on here.
When the actual issue happens I cant ‘cancel’ I have to force shutdown & then no log is saved on the usb stick.
I did note that the process gets to 35%, installing 150 packages, then pacman … various items, then finally it reaches “pacman (1/21) system user accounts…” & at that point it the slides stop, its frozen & the PC fans start increasing.
