Nobody is talking about using sudo make install. We are talking about installing extensions into the proper locations in your home directory which is both supported and recommended.
If you prefer to use AUR packages to maintain your extensions that is certainly a good and valid choice. However, it doesn’t mean that someone who chooses a different path is wrong or doing something unsupported.
Extensions are placed in ~home/.local/ share/Gnome-shell/extensions in a folder the name of the extension. they are not installed just read that is the correct way that can not harm your setup in any way.
@Christopher67 the top 3 are kill KDE, kill KDE, kill KDE,
Looks like Gnome 41 is officially here now in the stable repos. Thanks to anyone that tried it out in Testing to get it to this point. *note gnome-backgrounds is still out-of-date, but more than likely that’ll probably change, I may have just checked for updates too quickly
In case you have a very keen eye, you’ll notice Gnome gdm is absent from my checkupdates. This is because per the EndeavourOS wiki to get optimus manager working (click here), I had to install a package called gdm-prime from the AUR that is patched to make the optimus manager work. No clue if I can update safely or not until that package is updated, so I’m gonna wait a couple more days and see.
Edit: gnome-backgrounds has just been updated, so all of the Gnome 41 packages are fully up to date on Arch now! And working quite well might I add. This has been the smoothest Gnome upgrade I’ve ever done.
