I was facing gliteches while installing endeavouros-2019.08.17-x86_64.iso
Also, the EFI boot option doesn’t show Endeavour when dual booting with Windows.
endeavour-install.log:
http://ix.io/1S0Z
http://ix.io/1S0Z
look like composition of xfce it can turned off, there is a work around that should work, you got probably a amd gpu?
Maybe lack of storage?
16:32:07 [6]: Checking if "/dev/sdb1" can be resized.
16:32:07 [6]: .. NO, insufficient storage
Required storage B: 8589934592 "(8GiB)"
Available storage B: 140025856 "(0GiB)" for "/dev/sdb1" length: 1021952 sectorsUsed: 748464 fsType: "ntfs"
16:32:07 [6]: Checking if "/dev/sdb1" can be replaced.
Required storage B: 6442450944 "(5.5GiB)"
Available storage B: 523239424 "(0GiB)"
16:32:07 [6]: Checking if "/dev/sdb2" can be resized.
16:32:07 [6]: .. NO, filesystem "fat32" does not support resize.
16:32:07 [6]: Checking if "/dev/sdb2" can be replaced.
Available storage B: 104857600 "(0GiB)"
16:32:07 [6]: Checking if "/dev/sdb3" can be resized.
16:32:07 [6]: .. NO, filesystem "unknown" does not support resize.
16:32:07 [6]: Checking if "/dev/sdb3" can be replaced.
Please post your inxi
inxi -Fxxx0
Yes, AMD integrated GPU.
Host: archiso Kernel: 5.2.8-arch1-1-ARCH x86_64 bits: 64 compiler: gcc
v: 9.1.0 Desktop: Xfce 4.14.1 tk: Gtk 3.24.10 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: EndeavourOS
Type: Laptop System: Acer product: Aspire A315-41 v: V1.15
serial: <root required>
Mobo: RR model: Metapod_RR v: V1.15 serial: <root required> UEFI: Insyde
v: 1.15 date: 06/20/2019
Battery:
ID-1: BAT1 charge: 33.6 Wh condition: 35.3/37.0 Wh (95%) volts: 8.5/7.7
model: PANASONIC 0x41,0x50,0x31,0x36,0x4D,0x35,0x006A type: Li-ion
serial: 006A status: Discharging
Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 31952
Speed: 1368 MHz max: 1600 MHz boost: enabled Core speeds (MHz): 1: 1368
2: 1382 3: 1595 4: 1595 5: 1406 6: 1380 7: 1368 8: 1368
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:15dd
Display: tty server: X.Org 1.20.5 driver: amdgpu
resolution: 1920x1080~60Hz
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.2.8-arch1-1-ARCH
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus ID: 01:00.1 chip ID: 10ec:8168
IF: enp1s0f1 state: down mac: 98:28:a6:1a:d8:b1
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 2000 bus ID: 02:00.0
chip ID: 168c:0042
IF: wlp2s0 state: down mac: 6e:c4:e8:a2:24:90
IF-ID-1: enp3s0f3u2 state: unknown speed: N/A duplex: N/A
mac: b6:14:53:bd:80:e1
Local Storage: total: 938.88 GiB used: 2.9 MiB (0.0%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: WL1DNSG4 rev: ACM2 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 109
size: 7.37 GiB serial: 00241D8CE554BC50895701EE rev: PMAP scheme: MBR
ID-1: / size: 10.00 GiB used: 2.9 MiB (0.0%) fs: overlay source: ERR-102
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 43 C
Fan Speeds (RPM): N/A
Processes: 218 Uptime: 3m Memory: 3.32 GiB used: 563.2 MiB (16.6%)
Init: systemd v: 242 target: multi-user.target Compilers: gcc: 9.1.0
Shell: zsh v: 5.7.1 running in: xfce4-terminal inxi: 3.0.35
liveuser@archiso ~ %
for onscreen distortion this can help Xfce 4.14 Vega video graphics issue and fix
xfconf-query -c xfwm4 -p /general/vblank_mode -s off
xpresent can help too…
Are you trying to install it to the usb drive which is 8 GB? I see your hard drive is 1 Terrabyte.
I was installing it on hard drive.
It looks like it was trying to install on /dev/sdb? Your hard drive is /dev/sda.
I’ll retry with new installation disk!
That’s what it looks like to me. You have two issues. One being the garbled video because of the GPU and the other is the installation.
Your motherboard is UEFI so make sure you are installing with EFI set up. How are you creating the usb live ISO?
using dd method
If you have further issues when trying a new installation disk as @Resiliencia said “Please post the whole dmesg and xorg.log”
Thanks.
I was able to install endeavour successfully after manual partitioning & using new installation media.
But, as soon as I log in to the system, the screen becomes dead.
Also, Ctrl+Alt+Fn
combinations not showing anything.
I’m sorry to hear that it hasn’t gone according to plan. Are you able to edit the grub screen and add pci=noacpi
and try.
