Hello, Bugman here
I was doing some tests, and I’ve done something simple : replacing Xfce by Mate-Desktop. An EndeavourOS user may want to change desktop environment without installing it all again from scratch. Switching between desktop environment must be painless.
Here are the steps I followed in a VirtualMachine. I used an homemade git based ISO from 3rd september 2019 code.
Install EndeavourOS
Opened a terminal
Choose a quick and working repository by modifying /etc/pacman.d/mirrorlist
Installed mate with a yay -S mate mate-extra
Closed my Xfce-session
In LightDM, I choose Mate-Desktop
And I got an half broken Mate-Desktop session....
Annoying…
When I try to launch Mate Control center from command line, I got this error:
Failure loading - matecc.menu
Screenshot with error
I verified to see if it was an Archlinux bug using Anarchy Linux installer. And I got a working Mate session
Any idea to fix this bug? Thanks !
That’s strange, I just installed it and everything works.
JR29
September 4, 2019, 11:47am
#3
hello,no problem on my side
Ouch! Looks like my homemade ISO is kinda busted. Will try with another freshly made ISO and August official one ASAP.
this made my day - thank you
You’re welcome. Looks like my ISO is not in a good shape. Weird bug, indeed. Get out of my home, Murphy!
sudo pacman -S gnome-mate mate-extra
That way there are no problems, since Mate is a fork of Gnome, made by the great Perberos.
FredBezies:
Could be good rebooting the system just in case.
About the iso:
Did you change any config?
Did you run sudo fix_permissions.sh
before building the iso?
I rebooted, nothing changed.
No changes in config.
I remember running this script. Will make another ISO asap and test again.
Resiliencia:
There is no gnome-mate package, only mate one. I used it in my now dead french speaking documentation on how to install easily Archlinux.
According to your description you didn’t unistall xfce4, meaning, nothing was uninstalled that could cause an issue. Am i correct?
Did you try reinstalling mate and mate-extra again just in case?
I never used yay to install official packages, i doubt this can be related, but you can test using pacman…
For now i ran out of ideas… Let’s hope builing a new iso fix it for you.
Correct.
fernandomaroto:
Did not work.
fernandomaroto:
Won’t change anything.
Feedbacks: official august ISO + update and yay mate mate-extra = OK.
Trying a freshly made ISO with fix-permission.sh included = busted. Just done a sudo pacman -S mate mate-extra
What is going on?
Note: I added gnome-keyring as it was in a previous version of my error log but nothing changed. Environment display is broken.
Here is the xsession-error.log I had:
mate-session[1947]: WARNING: Unable to find provider '' of required component 'dock'
** (mate-panel:1966): WARNING **: 18:40:27.879: Menu tree loading got error:Failed to look up menu_file for "mate-applications.menu"
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.879: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(mate-panel:1966): GLib-GObject-WARNING **: 18:40:27.879: invalid (NULL) pointer instance
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.879: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.879: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (mate-panel:1966): WARNING **: 18:40:27.897: Menu tree loading got error:Failed to look up menu_file for "mate-settings.menu"
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.898: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(mate-panel:1966): GLib-GObject-WARNING **: 18:40:27.898: invalid (NULL) pointer instance
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.898: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(mate-panel:1966): GLib-GObject-CRITICAL **: 18:40:27.898: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(caja:1970): Gtk-WARNING **: 18:40:27.938: Failed to register client: GDBus.Error:org.gnome.SessionManager.AlreadyRegistered: Unable to register client
Gdk-Message: 18:40:35.645: mate-session: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
It only happens with development based ISO.
Official August ISO with updates on it works.
There ins’t any drastic change to archiso stuff. mate-control was updated a week or so ago
mate-control-center 2019-08-26
https://www.archlinux.org/packages/?q=mate&sort=-last_update
Maybe related… I’l build an iso when i have more time and check mate environment. I need to go for now.
fernandomaroto:
I have this update on my main Archlinux. And it works flawlessly. Very weird bug… Maybe tomorrow, we’ll find the answer!
JR29
September 4, 2019, 5:47pm
#17
on an iso of the day there is a display bug
Looks like I got the fix.
It is a bug added in /etc/environment file with this commit:
committed 08:41PM - 02 Sep 19 UTC
XDG_CONFIG_DIRS="/etc/skel/.config/xfce4"
In my working mate version - based on August official ISO, XDG_CONFIG_DIRS="/etc/skel/.config/xfce4"
cannot be found.
Adding it and trying to login again = busted display. Removing it? Mate works!
@joekamprad : looks like your commit is guilty… I will try with a git based image and see if removing XDG_CONFIG_DIRS="/etc/skel/.config/xfce4"
from /etc/environment fixes Mate display.
Will report ASAP.
And here is a video to show you why I think this commit is guilty.
I posted it on my mega.nz space:
https://mega.nz/#!67pliQZB!m-BW6bOw9ngaaQUFWjcJXWhsdWACfiUElTLIBZHkFhc
Sorry for my “bad” english
it is clear that changing default xdg dir to xfce4 configs will cause this problem if your DE will read also from xdg dirs… but thge change at GitHub is not ready for release, and also testing the ISO and calamares while we are developing things will be causing such problems.
So if you post something from testing current development status please do not post this as a general BUG for EndeavourOS, as it will give the wrong picture to someone reaching your post, and not knowing that you are testing something…
